Known Issues in Retired Versions of FME
Liz Sanderson
Liz Sanderson
When working with FME, encountering unexpected behaviors or limitations can be frustrating. To help navigate these challenges, this article provides a comprehensive list of known issues affecting all retired versions of FME. For a list of issues in supported versions of FME, see Known Issues in FME.
Each issue includes details on its impact, available workarounds, and whether a fix has been implemented. Our goal is to ensure transparency and provide solutions wherever possible, so you can keep your workflows running smoothly.
This article will not be maintained as these issues are no longer in supported versions of FME.
Known Issues in FME 2021.x and Older
For a list of issues for current versions of FME, see Known Issues in FME.
Feature Product Description Workaround Affects Status
Sorter Transformer FME Desktop Sorter fails with space in attribute name when passed as a parameter
FMEDESKTOP-11986
Simply use the attribute name in the Sorter.
2021.x
Resolved
2022.0
Automations FME Server In an Automation workspace action, the published parameters inside a collapsible Group Box are missing when you try to expand it.
FMESERVER-17030
The Group Box's Collapsed State has three options that can be configured in FME Workbench's Parameter Manager: Automatic, Open, and Closed. Use the Automatic state to prevent the Group Box from being blank in Automations.
2021.2
2021.1
2021.0.3
2021.0.2
Resolved
2022.0
FME Flow Installation FME Server During installation, you specified a database password containing a special character and on FME Server login you cannot connect to core.
DEVOPS-1037
DEVOPS-1468
See Known Issue: FME Server Database Schema Creation Fails When Password Specified During Install Contains Special Character
2021.2
2021.1
2021.0.3
Resolved
2022.0
JDBC Database Connection FME Server The JDBC Connection String specified in a distributed/fault-tolerant install is ignored. In the fmeDatabaseConfig.txt the connection string is jdbc:postgresql://:5432/fmeserver.
DEVOPS-1721
Edit the DB_JDBC_URL in the fmeDatabaseConfig.txt to point to your connection string and restart FME Server to apply the change.
2021.2
Resolved
2022.0
Web Connections FME Server Trying to edit an FME Server Web Connection in the Web UI there is an error "Some input parameters are malformed".
FMESERVER-17724
This error occurs if the FME Server Web Service definition was published to FME Server from FME Workbench 2021.2+. However, if the web service was uploaded by a restore you will not encounter this problem. To resolve the issue, delete the web service definition and publish it from an older version of FME Workbench and you should be able to make changes through the Web UI. Alternatively, edit the Web Connections in FME Workbench and re-publish them.
2021.2
Resolved
2022.0
Web Connections FME Server Attempting to publish/upload a user-defined web service you encounter the error "Unable to create derived service from a non system web service".
FMESERVER-17883
This issue occurs when the associated template web service is already uploaded to FME Server. Go to Files & Connections > Web Connections > Manage Web Services and remove this service.
2021.2
Resolved
2022.0
Users and Roles FME Server When creating a new user in FME Server, FME Server does not validate the data on the backend, which can result in the username being overwritten via a POST request.
FMESERVER-18291
See Known Issue: Lack of server-side validation when creating a new user in FME Server
2021.2.x
2021.1
2021.0
2020.x
Resolved
2021.2.6
ArcGIS Portal Service Reader FME Desktop When trying to select a Feature Service in a Group in the ArcGIS Portal Feature Service Reader, you receive the error "An unknown error has occurred".
FMEENGINE-72228
Use the ID to select the layer
Open the feature service that you want to add in a web browser, in the web URL, there is an "id="
Copy the value to the "Feature Service" parameter for the ArcGIS Portal Reader inside brackets e.g. (64d00a7c2ed14b0f9da3857d83bd40aa)
2021.2.3
2021.2.2
Resolved
2021.2.4
Users and Roles FME Server When deleting a user account and transferring ownership of items, previously shared/granted permissions are revoked once ownership of item is transferred and previous owner account is deleted.
FMESERVER-17670
See Known Issue: FME Server REST API V4 Deleting User Account Issue
2021.2.2
2021.2.1
2021.2.0
2021.1
2021.0
Resolved
2021.2.3
ArcGIS Portal Service Web Connection FME Desktop For ArcGIS Portal, if the password contains special characters such as @,#,$,%,&,* or !. The following error message encountered "Check your credentials and try again. The error code from the server was '400' and the message was: 'Unable to generate token. Invalid username or password.'" is displayed. The issue is encountered with both Web-tier and Portal-tier authentication i.e.
Generate Token
Basic
Digest
NTLM / Kerberos
FMEENGINE-70895
Use Web connection for ArcGIS Portal(Oauth) to connect to the portal instance. (Works for Generate Token or SAML Authentication only)
2021.2.1
2021.2.0
2021.1
2021.0
2020.2
Resolved
2021.2.2
Tokens FME Server FME Token Service will hang if concurrent requests are sent to it. Example: http://localhost/fmetoken/
FMESERVER-17522
Use the REST API or the UI to create tokens
2021.2.0
2021.1
Resolved
2021.2.1
Automations FME Server When connecting an Automation component to a Workspace Action, the Workspace dropdown menu stays disabled/greyed out and you can't select a workspace.
FMESERVER-17453
Switch the Action parameter to a different type, and revert it back to what you mean to set it as.
2021.2.0
Resolved
2021.2.0.1
Backup and Restore FME Server After upgrading to FME Server 2021.x , workspaces containing the FMEServerJobSubmitter fail to submit jobs with 'Reason - unable to connect to FME Server'.
FMESERVER-17662
Option 1: Import your SSL Certificate via Internet Options Option 2: Remove and re-publish the Web Service Definition Option 3: Embed connection details
2021.x
Workaround
FME Flow Installation FME Server While installing the 32-bit FME Server, the installation seems successful, but FME Server will not start. In Windows Services, the FME Database Service will not be visible.
FMESERVER-17228
See Known Issue: 2021.0+ 32-bit FME Server Install Not Working Properly
2021.x
Deprecated
Other
Microsoft Excel Writer FME Server When setting an Excel spreadsheet's output path to a local or UNC path with a space, it will be incorrectly written into the repositories folder. Example: C:\Path Space\file.xlsx gets written to C:\ProgramData\Safe Software\FME Server\repositories\Space\file.xlsx Use two double quotation marks around the path. Example: ""C:\Path Space\file.xlsx"".
2021.1.3
2021.1.2
2021.1.1
Resolved
2021.2
Geocoder Transformer FME Desktop Geocoder: Unavailable to add a new Geocoder transformer from the Transformer Gallery or Quick Add. Existing workspaces will still run with the Geocoder, but it may be listed under "Upgradable Transformers" to upgrade to an FME package version. However, the updated Geocoder package is available in FME 2021.2 and is newer.
FMEENGINE-70732
Copy a Geocoder transformer from a previous build of FME 2021.1 or upgrade to FME 2021.1.3 or newer.
2021.1.2
Resolved
2021.1.3
Web Connections FME Server We found an issue with our Web Connections that were stored in FME Server. If you notice a web connection not working in FME Server we advise upgrading. This was found in an ArcGIS Online connection but will affect all connections.
FMESERVER-17219
Upgrade to FME Server 2021.1.2 or newer.
2021.1.1
2021.1.0
2021.0
Resolved
2021.1.2
FME Form Installation FME Desktop When trying to license FME Desktop 2021.0 or .1, you get an error message stating “This version of FME Form is no longer supported for trial licensing," and you're unable to specify your fixed or floating license in FME Licensing Assistant.
IS-9491
Move existing licensing files or specify the license through the Command Line. See Known Issue: Unable to License Using FME Licensing Assistant in FME 2021.x
2021.1
2021.0
Resolved
2021.2
Backup and Restore FME Server An error similar to the following is returned when you attempt to run an FME Server backup:
An error occurred: COM.safe.fmeserver.configuration.
migration.FMEConfigurationException: org.apache.commons.compress.
archivers.zip.Zip64RequiredException:
path/to/file/file.ext's size exceeds the limit of 4GByte.
FMESERVER-16787
The backup process was unable to zip files larger than 4GB. Manually move the file mentioned to another location, run the backup process, and restore the file manually.
2021.0.3
2021.0.2
2021.0.1
Resolved
2021.1
Database Connections FME Server Jobs fail because of a Database Connection error with messages such as ''unable to open database file' or file 'cannot be located'. The connection file is stored in FME Server’s Resources.
FMESERVER-16510
Edit the database connection to reference the database file path directly.
replace: $(FME_SHAREDRESOURCE_DATA)/MyFolder/MySQLiteFile.sl3
with:
/data/fmeserver/resources/data/MyFolder/MySQLiteFile.sl3
2021.0.1
2021.0
Resolved
2021.0.2
AttributeManager Transformer FME Desktop "Bad variant access" error when renaming numeric attributes. Typically this error has been seen when using the AttributeManager but could occur with the AttributeCreator or other related transformers.
FMEENGINE-70052
Upgrade to FME 2021.0.3.2 or newer
2020.2.5
Resolved
2021.0.3.2
FME Workbench FME Desktop You may experience a workspace hang or "Error running translation". This occurs when FME is building bulk mode feature from regular features in the following options:
FeatureJoiner
AttributeKeeper (Create Bulk Features=Yes)
FFS Writer (Enforce Strict Schema=Yes)
SQLite Non-Spatial Writer
MapInfo Extended Writer or input features have attributes with missing values for some chunks of bulk mode features and not others resulting in a crash if the schema changes.
FMEENGINE-70071
Upgrade to FME 2021.1.0.1 or newer
2021.1
Resolved
2021.1.0.1
VertexCreator Transformer FME Desktop When using the VertexCreator in Add Point mode to create point features, the output features are lines instead of points. This will most frequently occur with CSV and Excel input data sources.
FMEENGINE-70231
This is a conflict with intentional behaviour that automatically generates points when latitude/longitude attributes are detected. See Known Issue: VertexCreator creates lines instead of points
2021.1
2021.0
Resolved
2021.2
FME Server Apps FME Server The "Run Workspace" page header is visible in FME Server Apps and it overlaps with custom banner images.
FMESERVER-17123
Upgrade to FME Server 2021.1.0.1 or newer
2021.1
Resolved
2021.1.0.1
FME Workbench FME Desktop Selecting feature types to read for a Single Merged Feature Type reader using the Feature Types to Read parameter in the Navigator pane causes "Failed to Retrieve Feature Type" error.
FMEDESKTOP-11429
Enable Prompt for User Parameters in the toolbar or through the Run menu and select the feature types to read through the Translation Parameter Values dialog.
2021.0
Resolved
2021.1
User Parameters FME Desktop User Parameter for Choice missing the option to import values from Reader or Writer formats
FMEDESKTOP-11422
Upgrade to FME 2021.1 build 21554 or newer
2021.0
Resolved
2021.1
AttributeFilter Transformer FME Desktop AttributeFilter version 4: When using attribute values with characters separated by a space, they are not filtered
FMEENGINE-70115
Upgrade the transformer to version 5 or upgrade to FME 2021.0.3.2 build 21332 or FME 2021.1.0.1 build 21614 or newer.
2021.0
Resolved
2021.1.0.1
2021.0.3.2
Jobs FME Server When a job is submitted it does not run and remains in the 'Queued' state.
FMESERVER-16503
Try either of the following options:
  • Assign engines to the default queue
  • Create a job routine rule to the new queue
2021.0
Resolved
2021.0.1
Streams FME Server On the Engines page one or more engines are not running jobs and the Queue is Assigned to stream "". The engine cannot be reassigned to a different queue.
FMESERVER-16513
See Known Issue: Removing a stream does not reassign the engines back to the Default queue
2021.0
Resolved
2021.0.1
Active Directory FME Server After creating a new Active Directory Connection and enabling Single Sign-On it fails, in the fmeserver.log there is a WARN message 'No SASL mechanism was specified in configuration'
FMESERVER-16571
See Known Issue: Single Sign-On fails with WARN 'No SASL mechanism was specified in configuration'
2021.0
Resolved
2021.0.1
Single Sign On FME Server You have installed FME Server with a distributed database type Oracle or Microsoft SQL Server and Single Sign-On login fails, while manual Active Directory Login succeeds.
FMESERVER-16763
2021.0
Resolved
2021.1
Reader Feature Types FME Server
"After publishing a workspace to FME Server that contains a merged feature type reader it is not possible to run the workspace via the Run Workspace page or Automations.
FMESERVER-16357
FMESERVER-16348
Upgrade
2020.2
Resolved
2021.0
Custom Transformers FME Server Workspaces with linked custom transformers will fail if the custom transformer is in the repository or workspace folder.
FMESERVER-15940
Upload the custom transformer to a shared resource folder
2020.2.0
2020.1
Resolved
2020.2.1
Installation FME Desktop As of FME 2020 and newer, the SQL Server Native Client 2012 will no longer be included in the installation. As such you may encounter issues with connecting to an Enterprise (SDE) Geodatabase. If you are unable to connect to an SDE Geodatabase after upgrading to FME 2020.X, or newer, please install the SQL Server ODBC client.
For more information about supported SQL Server clients for ArcGIS, please see the following page: https://desktop.arcgis.com/en/system-requirements/latest/database-requirements-sqlserver.htm
2020.x
Workaround
Installation FME Desktop If attempting to connect to SQL Server on a new system with no previous install of FME Desktop 2020.0, you may encounter a missing driver error. If you are unable to connect to a SQL Server database, install the MSOLEDBSQL driver that is present in the FME Desktop installer. Searching in your FME install directory for 'MSOLEDBSQL' should bring up the installer. If you run that installer, and re-launch FME Workbench it should connect to SQL Server as expected.
2020.x
Workaround
Database Connections FME Desktop As of FME 2020.x, certain JDBC Database formats were split from their original format family, and as a result, no longer share database connection details between Non-JDBC and JDBC database formats.
When opening workspaces created in an older version of FME with these types of database connections you’ll notice a message in the Format dropdown “Microsoft SQL Server Non-Spatial (JDBC) (replaced by MSSQL_JDBC_NONSPATIAL_2)”. This will indicate the need to recreate the Database Connection in most cases.
As such, database connections created in pre-2020.x FME builds will have to be remade for the specific Database format.
Eg: A database connection created in 2019 for SQL Server, could be used for both the JDBC and non-JDBC SQL Server format. In 2020.x, you will have to make a new JDBC database connection to use it with SQL Server.
2020.x
Unplanned
Web Connections FME Server After upgrading your FME Server to 2020.0 or newer, when users run workspaces that contain any web or database connections the translation will fail with the error “Unauthorized request by user due to lack of proper permissions”. We made some security improvements regarding Web or Database connections for FME Server 2020. Therefore, after upgrading you will be required to reconfigure the necessary permissions. Please see this article for more information.
2020.x
Workaround
Engines FME Server After install, FME Server continually tries to launch two engines, however I am only licensed for a single engine. This results in errors reported in the fmeserver.log and subsequently System Events. However when I try and change the engine count to one, it always reverts back to two. Drop the engine count from 2 to 0 first and then change the count back up to 1 and this change should now be applied successfully.
2020.x
Workaround
SMEServerNotifier FME Server If the FMEServerNotifier transformer is used in FME Desktop 2019 to notify an FME Server 2020 topic it will not work. This is because the FME Server REST API V1 was deprecated in 2020 and the FMEServerNotifier used V1 in 2019. If you use FME Desktop 2020 to notify an FME Server 2020 topic it will work.
2020.x
Deprecated
FME Server Web UI FME Server When trying to view a file stored in a network-based resource in the FME Server web UI it returns 'Path <sharedresource>/<filename>.ext is not a valid path'. Edit the shared resource to include a trailing slash at the end of the file path.
2020.x
Workaround
Email FME Server If an IMAP email server is only enabled to use TLS1.2, then FME Server will not be able to connect to it. To fix this modify the FMEProcessMonitorCore file:
1. Find your processMonitorConfigCore.txt file (it should be in your install directory which is by default located C:\apps\FMEServer\Server or C:\Program Files\FMEServer\Server)
2. Create a backup of this file (it's good to have if we want to revert this).
3. Open it as an admin and find # Start FME Server Publisher Plugin (imap) then insert -Dmail.imap.ssl.protocols=TLSv1.2 -Dmail.imaps.ssl.protocols=TLSv1.2 after -Dmail.imaps.fetchsize=1048576
2020.x
Workaround
User Parameters FME Server On FME Desktop, we create a relative path to find data if the data is located in the same folder as the workspace or a subfolder of the workspace. Once the workspace is uploaded to FME Server, sometimes these relative paths are not removed. One way to check if this issue is affecting you is to open up your workspace in a text editor and see if you can find the parameter value FME_MF_DIR_ENCODED. 1. Save your workspace in a new location
2. Update your readers to ensure that the relative path is removed. Save the workspace again.
3. Upload the workspace to FME Server.
2020.x
Workaround
FME Server Apps FME Server When an SVG image is uploaded into a Workspace or Gallery App it looks ok on the edit page, but once the App is created the image does not load. Use a PNG or JPG image instead.
2020.x
Unplanned
FeatureReader Transformer FME Desktop Reading features fails when using the FeatureReader if feature type names contain spaces. Reading is successful using a regular reader for the same feature type. Use the regular reader or upgrade to the latest release of FME 2020.
2020.0
Resolved
2020.0.0.1
GML Reader FME Desktop GML reader generates the message "xml-geometry-ref Geometry Builder: unable to adopt the below geometry because construction for its own geometry has already been finalized". This is most likely because it contains xlink_href="". We added support to xlinked, referenced geometry in 2019.1. Previous versions of FME ignored this. Use GML reader's ignore schema mode, or upgrade to the latest release or beta of FME
2020.0
Resolved
2020.1
FME Hub FME Desktop Issue affects non-offical packaged formats. For example, in Workbench try to add a reader of type "Japanese Fundamental Geospatial Data". You can find it in the formats list, but when you select it, the formats field doesn't accept it. No workaround. Upgrade to 2020.0.2.1 b20238
2020.0
Resolved
2020.0.2.1
FME Workbench FME Desktop When accessing Tools>FME Options, FME may become unresponsive and crash. This is a result of an identified issue with FME Desktop 2020.1 (builds 20594, 20596, 20608) and ArcGIS Pro 2.6 There are a few ways to workaround this issue:
Use FME 2020.1 32-bit with ArcGIS Desktop 10.8.1, OR
Use FME 2020.0 with ArcGIS Pro 2.6, OR
Use FME 2020.1 64-bit with ArcGIS Pro 2.5
2020.0
Resolved
2020.1.2
FME Workbench FME Desktop The correct feature count appears on the Reader feature types with spaces in name but no feature cache will appear in any downstream transformers when using Partial Runs.
When this behavior occurs in a workspace where some Reader feature types contain spaces and some do not, features may appear to 'disappear' within the workflow. This behavior affects FME 2020.1 (builds 20591, 20596, all platforms).
Disable Feature Caching
Purge feature caches from Reader feature types and perform Partial Runs from a downstream transformer
2020.0
Resolved
2020.1
Environment Variables FME Desktop Using FME 2020.1.x and FME_TEMP environment variable set to a root volume (eg. D:\ ), FME Workbench, Data Inspector or Licensing Assistant, will crash when starting up.
In the Windows Event Viewer, an application error is logged with the faulting module name: fmeutil.dll
Please make a top-level directory on the drive (e.g. D:\FMETEMP) and set FME_TEMP to this directory.
2020.0
Resolved
2020.2
Licensing FME Desktop Using FME 2020.1 (builds 20594 to 20624) and connecting to a floating license, the FME Licensing Assistant reports "This application cannot be used with the current license". This is error is due to the presence of an expired temporary license. An example of the dialogue you may see: To resolve this issue, you can remove the temporary license by finding the *.fmelic file in one of the following directories:
C:\ProgramData\Safe Software\FME\Licenses
<fme-install-folder>/licenses
C:\users\<user>\Documents\FME\Licenses
You can open the *.fmelic file in a text editor to see if it has an expiry date and then delete the file. You should be able to continue using your floating license.
2020.0
Resolved
2020.1.3
ArcGIS Online/Portal Writer FME Desktop In FME Desktop 2020.2.x, when creating a new ArcGIS Online/Portal writer, you can not select an existing feature service within a shared group. For an existing feature service writer shared with a group, you may encounter an error as well. Use the ID to select the layer
Copy the value to the "Feature Service" parameter for the ArcGIS Online writer inside brackets e.g.  (64d00a7c2ed14b0f9da3857d83bd40aa)
2020.0
Resolved
2021.0
Google KMZ Writer FME Desktop Using FME Desktop 2020.2.x writing out with Fanout Dataset Fanout Expression with the .kmz file extension resulted in an error and no data being written out. Files with “.” at beginning of the filename. Do not set kml_document attribute on output features. Or do not use “.” in filenames instead use “_”
2020.0
Resolved
2020.2
Publishing FME Server When publishing a workspace to FME Server via FME Desktop, if the FME Server username contains international characters or the password contains international characters such as 本å ä ö à, FME Workbench will give an authentication error. Create an FME Server username and password without these characters, or use a different account to publish. Logging into FME Server is unaffected.
2020.0
Resolved
2021.0
Installation FME Server In the FME Server Web UI when I try and view Resources or Broadcast Messages it says “We could not find what you wanted”. In Automations I cannot set the protocol type for triggers or external actions. You can either upgrade to 2020.0.0.1 or you will need to update a web application config file to correctly reference the database URL. For more information and full instructions on how to do this please see this article: https://knowledge.safe.com/articles/109765/known-issue-fme-server-resourcesautomations-could.html.
2020.0
Resolved
2020.0.0.1
Automations FME Server When building an Automations you see 'No Connections Available' while configuring a workspace that contains a database parameter. If you configure the job via the Run Workspace page the connection appears. Instead of using the default user parameter, create a text user parameter and link it database parameter. Step by step instructions on this can be found here.
2020.0
Resolved
2020.1
Publishing FME Server When attempting to re-publish a workspace to FME Server (e.g. a workspace that is already uploaded to FME Server - not just via the re-publish button) if the workspace is registered to the Notification Service and the 'Parameter to Get Topic Message' is set the workspace will fail. Reason was: The following readers or writers are included in an enabled service, but are not present in the workspace: <FORMAT_PARAM> Delete the workspace from FME Server, and then publish it again. Alternatively, change workflows to no longer use the Notification Service. See the best answer on this Community post for details on how this could be done.
2020.0
Resolved
2020.1.3
FME Server Apps FME Server In FME Server 2020.2 when I view my Gallery App there are no browser icons shown. No workaround. Upgrade to 2020.2.1
2020.0
Resolved
2020.2.1
Custom Transformers FME Server Workspaces with linked custom transformers will fail if the custom transformer is in the repository or workspace folder. To fix this issue you can upgrade your FME Server or follow one of the workarounds listed in this article.
2020.1
2020.0
Resolved
2020.2
Proxy FME Server In FME Server 2020.1.1, if you have enabled a proxy in the UI and set up exceptions for the FME Server, FME Server will respect them, unless there is a Python in the workspace. If you open fmeServerConfig.txt.
Under the heading FME SERVER SETTINGS START, add the following line:
ENABLE_ENGINEPROXY=false
2020.1.x
2020.0
Resolved
2020.1.3.2
Merged Feature Types FME Server After publishing a workspace to FME Server that contains a merged feature type reader it is not possible to run the workspace via the Run Workspace page or Automations. Either upgrade or see this article for a workaround.
2020.0
Resolved
2020.2
ArcGIS Online / ArcGIS Portal Feature Services FME Desktop When writing to an existing ArcGIS Portal or ArcGIS Online Feature Service layer, there are errors reported in FME log files: Encountered an unexpected error. The error code from the server was '500' and the message was: 'JSONObject[""globalId""] not found.'. Details: ''
FMEENGINE-67222
See Known Issue: ArcGIS Online / ArcGIS Portal feature services: common errors writing to existing feature services mismatched schema/data types
2020.x
2019.x
Resolved
2021.0
Emailer Transformer FME Desktop When using the Emailer in FME Desktop, if the SMTP authentication email password contains international characters such as äåø, the workspace will fail with the error:
2020-10-23 15:52:48| 1.3| 0.1|WARN |Emailer: <class 'UnicodeEncodeError'>: 'ascii' codec can't encode characters in position 0-2: ordinal not in range(128).
This is caused by an unresolved bug in the Python 3 standard library. For more information on this bug see  https://bugs.python.org/issue29750https://bugs.python.org/issue29750. This issue was not present in FME 2018 or older because these versions used the Python 2.7 library which has looser text encoding practices.
To resolve this issue, please change your email password to remove these characters. If you are unable to change your password, please downgrade to FME 2018 or older to use Python 2.7.
2019.x
Workaround
Installation FME Desktop macOS Catalina may identify downloaded installers as a risk, and prevent opening via double-click There are several ways to get around this!
#1 Instead of double-clicking the FME Desktop Installer icon, right click and select "Open". This will present a slightly different dialog which presents a warning, but allows the user to select "Open" anyway and continue with installation after providing password credentials.
#2 Go to Settings / Security & Privacy after receiving the error message, and under General / Allow Apps Downloaded From .. select "Open Anyway" next to "FME Desktop Installer"
#3 Optionally, you can also get around this from the command line by removing the quarantine Extended Attribute on the file:
xattr -d com.apple.quarantine /path/to/file
2019.x
Resolved
2020.0
FME Workbench FME Desktop Some users may experience application crashes with combinations of older Windows operating systems (specifically Windows 7) and third party applications such as Photoshop and Civil3D after installation of FME 2019.x. Upgrade to FME 2019.1.3+. Note prior versions of FME (2018.x) do not exhibit this behaviour either.
2019.1
2019.0
Resolved
2019.2
File Geodatabase Writer FME Desktop FME 64-bit fails to write to Geodatabase (File and SDE) with ArcGIS Pro 2.4 and 2.5. The following is an error message you may encounter:
An error occurred while attempting to insert a row into the table '<tablename>' using a cursor.
The error number from ArcObjects is: '-2147418113'
The error message from ArcObjects is: {}
There are a couple of workarounds to resolve this with FME 2019 64-bit:
1. Use ArcGIS Desktop with 64-bit Background Geoprocessing
OR
2. To continue using FME with ArcPro, switch the Python Compatibility to “Esri ArcGIS Pro 2.1 to 2.5 Python(3.6)”.
For FME 2019.x and higher, iIf you have no user defined Python (start-up/shutdown scripts or Python Caller) in your workspace, then please add a small startup Python script. To do this go to Navigator > Workspace Parameters > Scripting > Startup Python and add one line:
print()
The option is required as an additional step due to our effort to reduce the workspaces with “Python 2.7” since Python 2.7 is deprecated
2019.x
Resolved
2020.0
File Geodatabase Writer FME Desktop When creating a File Geodatabase using the latest Esri ArcPro release (2.4/2.5 beta), and writing to it via FME's Esri Geodatabase (File Geodatabase API) format, an error will occur. The error message may look like:
ERROR |Geodatabase Error (-2147219115): The row contains a bad value.
ERROR |FileGDB Writer: Could not create feature class 'TestPolygon'
ERROR |A fatal error has occurred. Check the logfile above for details
WARN |Geodatabase Error (-2147418113): Unexpected operation.
WARN |FileGDB Writer: Could not disable Load Only Mode for feature type 'TestPolygon'
Use a File Geodatabase created in ArcGIS Desktop or use the Esri File Geodatabase (FGDB) writer.
2019.x
Resolved
2020.0
GeoJSON Writer FME Desktop GeoJSON writer produces an invalid GeoJSON root structure if writing more than one feature type. The GeoJSON writer currently wraps the JSON feature collections with an array when multiple feature types are output. The GeoJSON standard mandates a FeatureCollection object as the root so this is incorrect (it is valid JSON but not valid GeoJSON). Write one feature type per GeoJSON output document. This can be done using one writer per feature type or dataset fanout on feature type name. In this case the root object is a FeatureCollection and our output is valid.
2018.0
2017.x
Resolved
2018.1
Database Connections FME Desktop A user may encounter an error inconsistently while retrieving database or web connections either via FME Options or within a Reader/Writer:
Error message: "Error retrieving connections"
Java Virtual Machine (JVM) memory issues on 32-bit Windows may prevent addition of certain readers/writers, or the correct application of web or database connections in FME 2018.0 Desktop x86.
64-bit FME 2018.0 does not exhibit this issue. Unless you require 32-bit FME for format support, we recommend using the 64-bit installer.
If you do require 32-bit formats, setting the following FME environment variables should resolve the issue in 2018.0:
SET FME_JVM_MAX_HEAP_SIZE=128M
SET FME_JVM_MIN_HEAP_SIZE=128M
If you are still experiencing intermittent connection issues, try altering the heap size:
Go to the Control Panel > System and Security > System > Advanced System Settings > Environment Variables:
Create 2 NEW SYSTEM Environment variables
FME_JVM_MAX_HEAP_SIZE=64M
FME_JVM_MIN_HEAP_SIZE=64M
If 64M doesn't work, try: 32M, 64M, 96M, 96M, 150M, 256M, 512M.
2018.x
Resolved
2019.0
FME Desktop Installation FME Desktop After upgrading to macOS Big Sur, FME Workbench does not open when trying to launch from /Applications/<FME Version>/
DOT-5737
See Known Issue: FME not launching on macOS Big Sur
2020.2.x
2020.1
2020.0
2019.x
2018.x
Resolved
2020.2.4
FME Workbench FME Desktop After upgrading to macOS Monterey, FME workspaces are failing to run. Error messages can vary depending on what action you are trying
FMEENGINE-71121
See Known Issue: FME fails to run on macOS Monterey
2021.1.x
2021.0
2020.x
2019.x
2018.x
Resolved
2021.1.3.1
Autodesk AutoCAD Map 3D Object Data Reader FME Desktop "AUTOCAD_OD: Unable to add reader Failed to load object data handling module. No object data will be read"
FMEENGINE-66765
See Known Issue: Failed to load object data handling module adding Autodesk AutoCAD Map 3D Object Data Reader
2020.x
2019.x
2018.x
Resolved
2021.0
Comments
0 comments
