FME Deprecations
Liz Sanderson
Liz Sanderson
FME evolves over time, and as part of this process, certain features, plugins, and libraries may be deprecated due to changes in availability, support, or API access. This article provides a comprehensive list of deprecated features, including the year of deprecation and any recommended replacements or actions. If you rely on any of these features, refer to the provided alternatives to ensure compatibility with the latest versions of FME. For a list of Safe Software created custom transformers that have been deprecated, see FME Hub Transformer Deprecations.
Deprecation List
Deprecated Feature Year Deprecated Recommended Action / Replacement
GoogleIoTConnector Transformer 2026.2 None
IBMIoTConnector Transformer 2026.2 None
FME DateTime Function 2026.1 ISO DateTime Functions (eg. @CurrentDateTime() replaces @DateTimeNow() functionality)
FME DateTime Format 2026.1 ISO format
Qubicle Binary Voxel File (QB) Reader 2025.2 None
DirectTweeter Transformer 2025.2 HTTPCaller and X API
TweetSearcher Transformer 2025.2 HTTPCaller and X API
TweetStreamer Transformer 2025.2 HTTPCaller and X API
TwitterStatusFetcher Transformer 2025.2 HTTPCaller and X API
Bentley i-model Interchange (.i.dgn) 2025.2 None
FME Form Embedded Help Window 2025.1 Use the browser-based help window
Hand-written Mapping Files (.fme) 2025.1 Use FME Workbench to author. See Hand-Written Mapping File .fme Deprecation
FME Flow REST API V3 2025.1 Migrate to V4 starting in 2025.0. See FME Flow REST API V3 Deprecation
"Use my API Key" option in AI Assist (RegEx, Python, and SQL editors) 2025.0 Update workflows to remove the user-provided API key to use Safe Software's AI service.
IFC STEP/XML 2025.0 Use Industry Foundation Classes (IFC) Reader/Writer
IFC with Data Views 2025.0 Use Autodesk Revit Reader/Writer
Adobe Illustrator – Avenza MAPublisher Writer 2025.0 Adobe Illustrator (IEPS) Writer
Here Venue Map (GML) Reader/Writer 2025.0 Use the regular GML reader.
Python 3.8 2025.0 Use FME 2024.2 or prior for Python 3.8 or update workspaces to use Python 3.9+
Windows Server 2016 Operating System 2025.0 Use FME 2024.2 or older for Windows Server 2016 or upgrade to Windows Server 2019.
GTI Technology's GTViewer Reader/Writer 2025.0 None
Offline Documentation in FME Form 2025.0 Use online documentation or download offline documentation. See Offline Help Documentation Removed from FME Form 2025.0
Debian 11 Operating System 2025.0 Use FME 2024.2 or older for Debian 11 or upgrade to Debian 12.
Virtual Reality Modeling Language (VRML97/VRML 2.0) Reader 2024.1 None
FME AR Mobile App on Android Devices 2024.1 Use FME AR mobile app on Apple iOS devices. See FME AR Mobile App on Android Deprecation.
FME Mobile App (formerly FME Data Express) on Android and iOS Devices 2024.1 Use FME Flow Apps. See FME Mobile Deprecation.
FMEFlowResourceConnector Transformer 2024.1 Update workspaces to use the HTTPCaller to call the relevant REST API directly instead.
FMEFlowLogFileRetriever Transformer 2024.1 Update workspaces to use the HTTPCaller to call the relevant REST API directly instead.
FMEFlowJobWaiter Transformer 2024.1 Update workspaces to use the HTTPCaller to call the relevant REST API directly instead.
FME Objects .NET 4 API 2024.0 See FME Objects .NET 4 API Deprecation
Point Cloud Support C++ SDK 2024.0 None
GMLnoSchema FME Hub Reader 2024.0 Use the regular GML reader in 'ignore schema' mode.
Python 3.7 2024.0 Use FME 2023.2 or prior for Python 3.7 or update workspaces to use Python 3.9+
WebSocketSenderWebSocketReciever Transformers  2024.0 Update workflows to use FME Flow Automation WebSockets or the PythonCaller.
Ubuntu 20.04 LTS,
Red Hat Enterprise Linux 8,
Oracle Linux 8,
Rocky Linux 8 Operating Systems
2024.0 None
MapTextLabeller Plugin provided by Safe Software 2024.0 Plugin available from MapText. See MapTextLabeller Plugin Availability Changes.
TclCaller Transformer & Tcl Scripts 2024.0 Use FME 2023.2 and prior, or switch to use Python.
RasterObjectDetector Transformer 2024.0 Use FME 2023.2 or older
Stamen Background Maps 2023.1 All versions of FME are affected; see Stamen Background Maps Deprecation
FME Server JavaScript API 2023.0 See JavaScript API Deprecation.
Oracle WebLogic Web Service 2023.1 Use Apache Tomcat
Trimble Connect (Token Service) Web Service 2023.1 Use the Trimble Connect TID Sign-In, see Trimble Connect (Token Service) Web Service Deprecation
FMEServerJobSubmitter Transformer 2023.0 FMEFlowJobSubmitter Transformer
FMEServerJobWaiter Transformer 2023.0 FMEFlowJobWaiter Transformer
FMEServerLogFileRetriever Transformer 2023.0 FMEFlowLogFileRetriever Transformer
FMEServerNotifier Transformer 2023.0 FMEFlowNotifier Transformer
FMEServerResourceConnector Transformer 2023.0 FMEFlowResourceConnector Transformer
Unauthenticated Web Service Access 2023.0 Provide a token to run workspaces without providing user credentials
Actian Ingres (Spatial) & (Non-Spatial) Reader/Writer 2023.0 Contact Support
AutodeskA360Connector Transformer 2023.0 See AutodeskA360Connector Deprecation.
FME Server Console 2023.0 Use the REST API or FME Flow CLI
IBM Netezza Spatial & Non-Spatial Reader/Writer  2023.0 See Using the FME JDBC (Java Database Connectivity) Format
LDAP/Active Directory Reader 2023.0 None
Python 3.6 2023.0 Upgrade code to Python 3.7+
SAIF Reader 2023.0 None
Adobe Flash (SWF) (FLASH) Writer 2022.0 None
ArcSDEGridSnapper & ArcSDEQuerier Transformers 2022.0 None
Autodesk SQLite Spatial (FDO) [SQLITE3FDO] Reader/Writer 2022.0 Use SpatialLite
Canadian Council on Geomatics Interchange Format (CCOGIF) Reader/Writer 2022.0 None
CouchDB (COUCHDB) Reader/Writer 2022.0 See GDAL Deprecations.
Erdas 7.x .LAN and .GIS (GDAL_LAN) via GDAL Format Reader 2022.0 See GDAL Deprecations.
Esri ArcPad AXF Reader 2022.0 None
Esri Geodatabase (Personal Geodb) (GEODATABASE_MDB) Reader/Writer 2022.0 Use the new 64-bit Esri Personal Geodatabase (Personal DB) reader. No writer option
FME Integration Console 2022.0 None
Fuji Bio-Imaging Analyzer Systems (BAS) (GDAL_FUJIBAS ) via GDAL Format Reader 2022.0 See GDAL Deprecations.
Google Cloud Spanner (CLOUDSPANNER_JDBC) Reader/Writer 2022.0 Use a different cloud-based database, see Overview of Spatial Support on the Cloud Databases
IBM Cloudant (CLOUDANT) Reader/Writer 2022.0 See GDAL Deprecations.
Image Display and Analysis (WinDisp) (GDAL_IDA) via GDAL Format Reader 2022.0 See GDAL Deprecations.
Intergraph GeoMedia Access Warehouse (FM0) Writer 2022.0 Replace with the GeoPackage format or use 32-bit FME 2021.2 or prior.
Intergraph Raster (INGR) Reader/Writer 2022.0 See GDAL Deprecations.
Leica Independent Data Exchange Format (IDEX) Reader/Writer 2022.0 See GDAL Deprecations.
MapInfo SpatialWare (SPATIALWARE) Reader/Writer 2022.0 None
SQLite Spatial (GDAL) [SPATIALITE] Reader/Writer 2022.0 Use SpatialLite, see Choosing the Correct SQLite or SpatiaLite Format
Tableau Data Extract (TDE) Writer 2022.0 Use the Tableau Hyper writer
FME Server Workspace Viewer 2022.0 Limited access, see Workspace Viewer Deprecation for more information.
Built-in Geocoder Transformer 2021.2 Update workflow to use the Geocoder package instead
Arc/Info Export E00 GRID Reader via GDAL Format Reader 2021.1 Use another GDAL Format
Autodesk Recap Writer 2021.1 None
Esri Legacy ArcGIS Image Server Reader 2021.1 Use alternate raster reading formats.
FME Augmented Reality Reader/Writer 2021.1 None
Garmin MapSource Reader/Writer 2021.1 Use other Garmin formats
MapQuest Web Map Tile Service Background Map 2021.0 Use a different background map
BC MoF Electronic Submission Framework (ESF) Reader/Writer 2021.0 Upgrade to the new XSD-Driven reader/writer
FME Hub support in FME Desktop 2014 2021.0 Go to the FME Hub website to download content directly.
FME Server C++ API 2021.0 REST API
FME Server Java API 2021.0 REST API
FME Server .Net API 2021.0 REST API
MRFCleaner Transformers 2021.0 None
Pervasive PSQL Reader/Writer 2021.0 None
TOBIN TBRBM II Data Distribution Format Writer 2021.0 None
MapBox Classic Style Background Maps 2020.1 Upgrade to FME 2020.2 or newer
Amazon Athena Reader 2020.0 Update workflow to use the AmazonAthenaConnector instead
APNS Subscriber 2020.0 Use FME 2019.2 or older or migrate workflows to Amazon SNS
Google Sheets API v3 June 8, 2021 Update to Google Sheet API V4
REST V1 and V2 2020.0 REST API V3
Socrata DataSync Writer 2020.0 Update workflow to use the Socrata package
Esri Legacy ArcSDE Raster Reader/ Writer 2019.0 Use the Esri Geodabase (ArcSDE Geodb Raster) format
Esri Legacy ArcSDE (SDE30) Reader/Writer 2019.0 Use the Esri Geodatabase (ArcSDE) format
GCMMessenger and GCM Subscriber 2019.0 Use Google Firebase Cloud Messaging
Geographic Data Files (GDF) Writer 2019.0 Use another spatial format
Google Fusion Tables Reader/Writer  2019.0 None
JavaScriptCaller Transformer 2019.0 Change workflow to Python
MongoDB Reader/Writer 2019.0 Update workspaces to use MongoDB3
Python 2.7 2019.0 Port all Python 2 code to Python 3.x
Feature Data Objects (FDO) Providers 2017.1 Have FME Desktop 2019.x installation to run FDO Provider-dependent workspaces alongside an FME Desktop 2020 or newer version.
FME Server Repository Reader/Writer 2017.0 Has been removed entirely for 2022.0. Use the FMEServerResourceConnector transformer
FME Server Stream Reader/Writer 2017.0 Has been removed entirely for 2022.0. See the Stream Processing tutorial.
Autodesk MapGuide (Version 6.5 and older) SDF Reader/Writer 2016.0 Use SDF3
