Trimble Connect (Token Service) Web Service Deprecation
Christian Berger
Christian Berger
Trimble Connect Token-based authentication was replaced by Trimble and now uses Trimble Identity (TID). TID is the sign-in functionality used for fast, secure access to Trimble software products and follows the OAuth standard.
As a result, the original token-based Trimble Connect Web Service that was originally posted to the FME Hub has been deprecated and replaced by the Trimble Connect (safe.trimble-connect) Web Service that comes bundled with the TrimbleConnectConnector package on the FME Hub.
Support
Please contact Support or comment on this article if you run into any issues with the TrimbleConnectConnector or the OAuth Trimble Connect web service.
