Overview of Spatial Support on the Cloud Databases
Liz Sanderson
Liz Sanderson
Overview of Spatial Support on the Cloud databases
Relational Databases
Managed Databases
Industry-standard databases are offered as a managed service on AWS, Azure, and Google Cloud.
Database Cloud Platform Support Spatial Support FME Support
Maria DB (10.1.2+)
  • AWS
  • Azure
Spatial Types: Geometry and Geography
Supported Types: All main types.
Spatial Functions: All major functions.
Read, write and query.
MySQL ( 8.0+)
  • AWS
  • Azure
  • Google
Oracle
  • AWS
Oracle Spatial and Oracle Locator are supported.
PostgreSQL
  • AWS
  • Azure
  • Google
All clouds support the PostGIS extension.
SQL Server
  • AWS
  • Azure
  • Google
Cloud-Native Databases
Cloud-native databases are created by cloud providers and designed from the ground up to leverage the cloud architecture. They are often based on existing database engines but are optimized for the cloud with a focus on performance and availability.
Database Spatial Support FME Support
AWS Aurora RDS
Aurora supports both the MySQL and PostgreSQL database engines. Both of these engines have spatial data types enabled (PostGIS and MySQL).
Supported Types: All main types (e.g. Points, Lines, Polygons)
Spatial Functions: All PostGIS and MySQL functions.
Azure SQL Database
This is based on SQL Server with the same spatial support.
Spatial Functions: All SQL Server functions.
Google Cloud Spanner
Cloud Spanner does not natively support geospatial queries. Google’s S2 library can be leveraged which uses spherical geometry and is used by Google itself on Google Maps.
This was deprecated in FME 2022
Data Warehouses
Data warehouses are interactive tools for analyzing large datasets. They enable you to store large volumes of data cheaply and provide an interface where you can run fast, complex queries across the data.
AWS Athena Type of Support: Native
Supported Types: Points, Lines, Polygons, Multipoint, Multilines, Multipolygons and Geometry Collections
Spatial Functions: Over 30 functions
Query S3 datasets
AWS Redshift Type of Support: Native
Spatial Types: Geometry and 2D support only.
Supported Types: Points, Lines, Polygons, Multilines and Multipolygons
Spatial Functions: Over 40 functions
Google Big Query Type of Support: Native
Spatial Types: Geography
Supported Types: Points, Lines, Polygons.
Spatial Functions: Over 30 functions.
Snowflake Type of Support: Native
Supported Types: Point, MultiPoint, LineString, MultiLineString, Polygon, MultiPolygon, GeometryCollection, Feature, FeatureCollection
NoSQL Databases
NoSQL databases enable the storage and querying of vast amounts of unstructured data.
AWS Dynamo DB No support. There used to be support for geohashes via an official library, this project has now been archived. Read and write.
Azure Cosmos DB Type of Support: Native
Spatial Types: Geography and Geometry
Supported Types: Points, Linestrings, Polygons, Multipolygons. Spatial Functions: Within, Distance, Intersects.
Google Cloud Firestore Type of Support: No native support, but there is support for geohashing via a 3rd party library.
Spatial Functions: Within, Distance, Bearing
