Getting Started with FME Flow Apps
Liz Sanderson
Liz Sanderson
FME Flow Apps offer a no-code solution for delivering a self-serve portal to end users. Users can configure custom parameters, including the ability to upload and download data on-demand.
Why use FME Flow Apps?
You might use FME Flow Apps because you need to:
  • Deliver a self-serve portal where users can select an area of interest and download the associated dataset.
  • Provide a place where your clientele can upload data for processing.
  • Create a tool for peers to validate their data.
  • Provide a form for data collection.
  • Build a data conversion tool to submit data in one format and transform it into another.
Terminology
Workspace Apps: "Apps" that run workspaces from a web browser. Workspace apps are shared as URLs and may be presented through customizable web pages.
Gallery Apps: Groupings of workspace and automation apps and other links that are accessed from single, customizable web pages, and shared as URLs.
Automation Apps: "Apps" that run automations from a web browser. Automation apps are shared as URLs and may be presented through customizable web pages.
Flow Apps: The collective term for workspace, automation, and gallery apps.
Articles
Getting Started with Workspace Apps
Learn the basics of the different parameters you can set while building a workspace app.
Getting Started with Gallery Apps
Learn the basics of the different parameters you can set while building a gallery app.
Getting Started with Automation Apps
Learn the basics of how to build an Automation and configure parameters for an automation app.
Working with the FME Flow Runtime Parameters
In this tutorial, you will learn how to use FME Flow parameters to fetch the name of the user who logged in to run an FME workspace app and email them the output data from the workspace.
Dynamic Parameter Configurations in FME Flow Apps
In this tutorial, you will learn how to dynamically generate parameter options in Workspace Apps using external datasets and systems.
Create a Simple Web Application Form for Data Collection
In this tutorial, you will learn how to create a workspace app that will be used to collect survey responses. The input data is collected and written out to an Excel spreadsheet.
Data Distribution for Raster Data
In this tutorial, you will learn how to build a workspace app that will be run under the data download service to deliver aerial imagery based on a user-selected area of interest.
Data Distribution for Point Cloud Data
In this tutorial, you will learn how to create a workspace app that runs under the data download service. The underlying workspace makes use of the geometry user parameter, allowing users to select an area of interest at runtime and receive zip file containing a point cloud that covers the selected area.
Build Manual Trigger Automation App
In this tutorial, you will learn how to use the Manual Trigger to build an Automation app off of a multi-action automation.
Update Databases Using an FME Flow App
This series covers three different databases: Oracle, Microsoft SQL Server, and PostGIS. For each database, two scenarios are demonstrated; bulk edits and single feature edits.
Bulk Edits Oracle: Update a Database Using an FME Flow App
Single edits Oracle: Update a Database Using an FME Flow App
Bulk Edits SQL Server: Update a Database Using an FME Flow App
Single Edits SQL Server: Update a Database Using an FME Flow App
Bulk Edits PostgreSQL: Update a Database Using an FME Flow App
Single edits PostgreSQL: Update a Database Using an FME Flow App
Web Mapping with Mapbox GL JS
In this tutorial, you will learn how to use the HTMLReportGenerator transformer to integrate Mapbox directly into an FME workspace to create custom web map, and deliver this to end-users via a data streaming workspace app.
Cityworks and FME: Pothole Reporting Demo
In this tutorial, you will learn how to create a series of workspace apps to integrate Cityworks and FME. The workflow follows a pothole reporting system as it flows through Cityworks from report to completion.
FME Flow Apps: Add to Home Screen
In this article, you will learn how to add FME Flow Apps to your home screen on a mobile device.
Tutorials with Interactive Demos
Data Validation - FME Flow App
In this tutorial, you will learn how to build a workspace app for data validation. Users can upload an AutoCAD DWG file containing water main data and an HTML report will be streamed back to the web browser displaying both a map and table listing any invalid geometry.
[Try Live Demo]
Easy Translator - FME Flow App
In this tutorial, you will learn how to build a workspace app for data conversion. Users can upload data and the workspace will translate it to any of FME’s supported file formats.
[Try Live Demo]
Data Distribution - FME Flow App
In this tutorial, you will learn how to build a workspace app for data distribution. Users can choose which layers they want to download, the extents by drawing a polygon on a map, as well as the format and coordinate system of the output data.
[Try Live Demo]
HTML Page with Link to Download Excel File - FME Flow App
In this tutorial, you will learn how to build a workspace app for data streaming. The app reviews the annual labor market outlook for British Columbia. Users can select the year to report and HTML page is returned in the response displaying a table of Industries and the number of job openings.
[Try Live Demo]
Check out our website for all other FME Demos. Note not all the demos listed on this page make use of FME Flow apps, some are custom-written scripts.
Additional Resources
[Documentation] Flow Apps
[Webinar] Creating No Code Web Apps with FME Flow
[Webinar] A Step-By-Step Guide to Building Codeless Web Apps
Troubleshooting
FME Flow Connections Runtime Error: Unauthorized request by user due to lack of proper permissions
