Tutorial: Update Databases Using an FME Server App
Liz Sanderson
Liz Sanderson
FME Version
  • FME 2019.x
FME makes it easy to update your database, either through a single feature edit or bulk edits. Once published to FME Server, FME Server Apps allow you to share FME workflows with anyone, no FME Server account required. This enables users to easily make changes to the database, even when in the field. This tutorial covers three different databases: Oracle, Microsoft SQL Server, and PostGIS, and could be modified for other databases. For each database, two scenarios are demonstrated:
  1. Bulk edits: This bulk insert is useful when you anticipate a large number of edits being made so that FME Server does not get tied up with multiple calls. Instead, data is pushed to FME Server in groups.
  2. Single feature edits: Respond to single feature database edits and push features individually. This is good when you have a low volume of individual edits.
Requirements
  • Externally Accessible FME Server 2019 or later
  • FME Desktop 2019 or later
  • Access to Oracle, Microsoft SQL Server, or PostGIS.
Articles
Bulk Edits:
Bulk Edits Oracle
Bulk Edits SQL
Bulk Edits PostGIS/PostgreSQL
Single Edits:
Single Edits Oracle
Single Edits SQL
Single Edits PostGIS/PostgreSQL
Further Reading
Data Attribution
The data shown here originates from open data made available by the City of Vancouver, British Columbia. It contains information licensed under the Open Government License - Vancouver.
Comments
0 comments
