Bulk Edits SQL Server: Update a Database Using an FME Flow App
Toyosi Akinselure
Toyosi Akinselure
FME Flow can create Flow Apps that allow users to run a workspace and enter parameters without the need to log in. These apps allow users to update datasets on the fly while out in the field using their mobile phones. This article shows how to set up Microsoft SQL and FME Flow to respond to bulk feature database edits. If a small number of edits are being made, a single insert can also be set. This is described in the following article Single Edits SQL: Update a Database Using an FME Flow App
Requirements
  • Access to a Microsoft SQL Spatial connection
Step-by-Step Instructions
Part 1: FME Workbench
Before we begin, open the two workspaces in FME Workbench to change the parameters to our own Microsoft SQL database.
1. Open FME Workbench
If you completed the Single Edits SQL article, you can skip to Part 1 - Step 4 as you will already have the table loaded into your database.
First, we need to create a table in our database. Open CreateTableInSQL.fmwt and expand the Microsoft SQL writer in the Navigator window. Double-click on Connection to open the connection parameters.
In the Edit ‘Microsoft SQL [SQL_SPATIAL]’ dialog, click the drop-down next to Connection and click Add Database Connection.
Then add your Microsoft SQL database connection parameters. For more information on setting up a Microsoft SQL database connection, please see the article Viewing and Inspecting SQL Data. Once the connection has been added, ensure it is selected, and click OK.
2. Change Table Parameters
There is one more thing to change before we can run this workspace. Double-click on the Microsoft SQL Writer feature type to open the Feature Type parameters. Change the Table Qualifier name to the username of your database. For this example, we are using the dbo username. Once that is updated, click OK.
3. Run the workspace
Save the workspace and then run it. This will create a new table in your Microsoft SQL database called Tree_Survey.
Go into your Microsoft SQL database, or inspect the output in FME to confirm that the table was written correctly.
4. Open the Second Workspace
Close the first workspace and then open BulkUploadTreeSurvey.fmw. This workspace reads in an Excel spreadsheet containing an entire neighborhood’s worth of a tree survey. The workspace will also read in the database table that we just created. Then using both data sources, the workspace will determine whether or not the data already exists in the database. Then based on the result, it will INSERT, UPDATE, or DELETE the Excel data in the database.
Let’s go through what this workspace does:
a. Reads in the Excel spreadsheet containing all of the tree surveys for each neighborhood
b. Reads in the Tree_Survey database table created with CreateTableInSQL.fmwt. Then tests Tree_ID from the Excel spreadsheet exists in the database. If Tree_ID doesn’t exist, it will move on to the INSERT section. If the Tree_ID exists, it will move on to the UPDATE or DELETE section.
c. Tests to see if the tree has been removed, based on the Removed attribute. If yes, then it triggers the DELETE workflow. If no, then it moves to UPDATE.
d. Sets the database operation with the FME specific attribute fme_db_operation. Additionally, it cleans up any unneeded attributes.
e. Writes out to the same Microsoft SQL database table as the FeatureReader, and sets the database operation based on the fme_db_operation in the earlier AttributeManagers.
f. Cleans up attributes in preparation to write out to a log file.
g. Writes out the Database Operation, Date and which attributes were written to the database in a Microsoft Excel file. This file can be used to monitor changes to the database.
5. Update FeatureReader
In this second workspace, open the FeatureReader parameters and change the Connection to the Microsoft SQL connection you created in the previous workspace. Additionally, click the ellipsis next to Feature Types to Read and select the Tree_Survey in your database. Click OK to close the FeatureReader.
When you update the FeatureReader ensure that the output port yourusername.TREE_SURVEY is connected to the FeatureJoiner Right input port.
6. Update the Microsoft SQL Writer
Next, we will need to update the connection parameters for the Microsoft SQL Writer. In the Navigator window, change the Microsoft SQL connection to your connection, the same way as the previous workspace.
Once the connection is created, open up the Microsoft SQL Writer Feature Type and change the Table Qualifier to the username you used in the previous workspace, in this example, we are using dbo. Also change Table Name, if necessary.
7. Test the Workspace
Before we publish this workspace to FME Flow, it is a good idea to test it locally. Ensure that Prompt for User Parameters is enabled and then run the workspace.
In the Translation Parameter Values dialog, select any ONE feature type from the Excel file. You can choose more than one, but it will cause the workspace to run slower.
You can ignore the Microsoft Excel File parameter, this will become relevant in FME Flow.
Uncheck Save As User Parameter Default Values
Once the parameters are entered, click Run. This will trigger an INSERT in the database since this is new data. You can inspect the database to confirm this update. As well, you can also view the Microsoft Excel TreeLog, which will include the parameters we just set, the database operation INSERT and today’s date and time.
If you want to test DELETE and UPDATE, rerun the entire workspace and select the SAME Survey to Read parameter as before.
8. Publish to FME Flow
Once you have confirmed that this workspace runs successfully with your database connection, it is time to publish it to FME Flow.
Before publishing to FME Flow, you need to decide if you want your Excel log file to be available to the user running the Flow App. If you do not, you can either leave the Excel file to be updated locally on your machine OR you can set it up to update in the FME Flow Resources folder.
To update the file to save it to FME Flow, expand the TreeDatabase-LogReport writer in the Navigator window. Then double-click on the Destination Microsoft Excel File parameter to open up the edit dialog. In the edit dialog, click on the drop-down next to Destination Microsoft Excel File, then choose User Parameter > FME Flow Parameters > FME_SHAREDRESOURCE_DATA. Then after $(FME_SHAREDRESOURCE_DATA) type in \FlowApps\TreeDatabase-LogReport.xlsx
$(FME_SHAREDRESOURCE_DATA)\FlowApps\TreeDatabase-LogReport.xlsx
Click OK. Save the workspace, and then click on the Publish icon in the top toolbar.
In the Publish to FME Flow dialog, create an FME Flow connection if you do not already have one. Then ensure this workspace is saved to a Repository called FlowApps. Be sure to upload your Microsoft SQL connection. Then register with the Job Submitter service if you want your log file private and/or the Data Download service if you want the log file to be public. The Data Download service will download the log Excel file every time the app is run.
Part 2: FME Flow
With the workspace published, we can create an FME Flow App. An FME Flow App allows users to run an FME Flow workspace without logging in. It also allows the user to run the workspace on their mobile phone. For more information on FMEFlow Apps, please see the article Getting Started with FME Flow Apps.
1. Log into FME Flow
Log into FME Flow with an account that has privileges to create FME Flow Apps. Once logged in, go to the Flow Apps section and then click on Create.
Additionally, you can create an FME Flow App through the Run Workspace Page Advanced section.
2. Create FME Flow App
On the Create Flow App page, give your app a name and short description. Then select the Repository and Workspace.
Choose which Service you want to use. Remember if you want your log file public, use the Data Download service, if you want it private, use the Job Submitter.
Next, check the Expiration date. By default, apps are set to expire in 10 years. It might be a good idea to set this expiration date to a shorter time. This expiration time can be changed at any time.
Finally, ensure that User Can Upload is enabled. This allows the user to upload a new Excel file to the app.
Now expand the Parameters section, and double-check the defaults for the app. If your parameters have values next to them, click on the Reset button. By setting all the values to blank, this will ensure that the user doesn’t miss a parameter when they enter their own values. Also ensure that all of the desired parameters are being shown in the app, which is indicated by the green checkmark next to each parameter.
Finally, you can expand the Customize Appearance section and add color, text, or images to your final app page.
Once you are satisfied with your app, click OK. You will get a URL that links to your app.
3. Test App
Click on the URL that was provided at the end up the app setup.
To share the FME Flow App with anyone, the FME Flow must be accessed externally, not internally, using localhost.
If you navigated away from the page with the URL, you can access it again by going to Flow Apps on the side menu and then clicking on the URL icon next to your app name.
To test the Flow App, enter the following parameters:
Survey to Read: HASTINGS-SUNRISE_Trees
Source Microsoft Excel Files(s): Browse to your downloads, locate BulkSQLTreeSurvey and the Data folder and then select Vancouver_Trees.xlsx
To upload a file, click on the Click to Browse Resources box, then in the popup dialog, click the Upload button and then browse to your file. Once the file is uploaded, click OK.
Once your parameters are set, click on Run.
You can also change the parameters to trigger a DELETE or UPDATE by rerunning the app and selecting the same Survey to Read.
Data Attribution
The data shown here originates from open data made available by the City of Vancouver, British Columbia. It contains information licensed under the Open Government License - Vancouver.
