Viewing and Inspecting SQL Server Data
Liz Sanderson
Liz Sanderson
Connecting to a database in FME varies slightly from selecting a file or file/folder-based format. The process involves specific parameters related directly to the database.
The basic database connection parameters are:
  • Server (Host) Name
  • Network Port Number
  • Database (Service) Name
  • Username
  • Password
These parameters may differ for each database format. Connecting to SQL Server requires only four of these parameters; it does not require a port number, but it does require an authentication method.
Microsoft SQL Server offers two authentication methods: SQL Server Authentication and Windows Authentication. In SQL Server Authentication, credentials are created and stored in SQL Server. In Windows Authentication, identification is confirmed through the Windows principal token; therefore, a username and password are not required.
Video
Step-by-Step Instructions
Follow these steps to connect to the SQL Server database in FME. It is possible to connect to the database using two different methods; parameters for both methods are outlined in steps 2a and 2b.
1. Start FME Data Inspector
Select File > Open Dataset from the menu bar to open the selection dialog.
Set the Format to Microsoft SQL Server Spatial.
2. Define the Dataset
There are two methods to connect to database services: Embed Connections and Database Connections (also referred to as Named Connections). Embed connections require the user to enter the connection parameters each time they want to read from or write to a database. Database connections provide a secure and simple way to store and reuse connection parameters. With database connections, it is possible to select the saved connection when desired, rather than having to manually re-enter the connection parameters each time. For more information on database connections, please refer to Using Database Connections.
2a. Embed Connection
Select "Embed Connection Parameters" as the Connection, and then open the Parameters. To connect to SQL Server, the following connection parameters are required:
  • Server: sql.fmetraining.ca
  • Database: fmedata
  • Authentication: SQL Server Authentication
  • Username: fmedata
  • Password: SQLtraining2016
  • Table List: fmedata2016.Neighborhoods
To locate the fmedata2016.Neighborhoods table, click the ellipsis to open the Select Table List window and choose the table.
The schema for this table is fmedata2016. Schemas are used to organize and manage tables; they can also provide a more efficient way to filter through tables in a list.
2b. Database Connection
Select Add Database Connection.
Once selected, FME will open the Add Database Connection parameters window. To connect to SQL Server for this tutorial, the following connection parameters are required:
  • Name: SQL Training Database
  • Database: fmedata
  • Username: fmedata
Click Save to close the connection parameters dialog. Click to open the Parameters… dialog; otherwise, FME will prompt you to check the parameters. Here, we can select which table we want to inspect. Select fmedata2016.Neighborhoods by clicking the ellipsis button for the Select Table List window.
Finally, click OK on all dialogs to view the Neighborhoods table.
Result
The Neighborhoods table, both its geometry and attributes, is now displayed in Data Inspector.
Data Attribution
