Tutorial: Getting Started with PostGIS and PostgreSQL
Liz Sanderson
Liz Sanderson
This tutorial introduces using PostGIS and PostgreSQL with FME. Databases are useful for long-term data storage, rather than short-term data transfers, so the key operations are getting data into and out of that storage. For more information about how to work with databases in FME, as well as specific FME terminology for databases, see the Working with Databases & Data Warehouses and FME article.
The three key operations that occur with a database are:
  • Data imports
  • Data updates
  • Data distribution
All of the activities above involve not only transforming the data into the correct format but also into the correct schema (data model).
The tutorial series will cover connecting to a PostGIS/PostgreSQL database, reading from PostGIS, and writing to PostGIS. All of these examples are also applicable to using the PostgreSQL format.
Database Access
Safe Software has provided a PostgreSQL training database for reading data in FME. However, this database is read-only. For tutorials where you will be writing to PostgreSQL, you will need to have PostgreSQL installed on your computer or access a cloud-based version. Please see Creating a PostgreSQL/PostGIS Training Database with FME for instructions on creating your own training database.
Articles
Viewing and Inspecting PostGIS Data
How to connect to a PostGIS or PostgreSQL database and have the connection persist through different FME sessions.
Converting from PostGIS
Read data from PostGIS, set some common database reader parameters, then write it to an Esri File Geodatabase.
Migrate data from the Safe Software-provided PostGIS training database into your own database to prepare for the articles that cover PostGIS/PostgreSQL.
Converting to PostGIS: Create, Drop or Truncate a Table
How to write to a new PostGIS table.
Converting to PostGIS: Write to an Existing Table
Details how to write to a database table that already exists through importing table schemas.
Updating a PostgreSQL Database Using UPSERT
Learn how to UPSERT data into a PostgreSQL database in FME 2022.0 or newer.
Writing Multiple Geometry Types to an Existing PostGIS Table
PostGIS can have multiple geometry columns; learn how to write multiple columns in FME.
Additional Information
