AutodeskA360Connector Deprecation
Liz Sanderson
Liz Sanderson
A360 Drive was retired by Autodesk in October 2020 and replaced by Autodesk Drive. Currently, the A360 API that the AutodeskA360Connector uses still works, but it may be deactivated by Autodesk without notice, resulting in the A360Connector failing in all versions of FME. Because of this instability and the lack of an available API for Autodesk Drive, we will be deprecating the AutodeskA360Connector in FME Desktop 2023. Note that we may deprecate it sooner should access be discontinued.
Download Files
Please download all files you wish to retain from A360 as soon as possible, as they may be removed from Autodesk without notice.
As of August 11th, 2022, the AutodeskA360Connector can still connect to Autodesk, but access may be deactivated without notice. Before the AutodeskA360Connector is deprecated, you can use it to download your files.
Support
If you notice that the AutodeskA360Connector no longer works, please contact Support or comment on this article, and we will update this notice.
