GDAL Deprecations in FME
Liz Sanderson
Liz Sanderson
FME uses GDAL libraries and drivers for both raster and vector formats. As we upgrade the GDAL library to include new formats, some formats are being deprecated or removed by GDAL, so FME will have to follow suit. In some cases, we have found workarounds, but in others, there will be no new replacement functionality. For a list of available GDAL formats for your version of FME, please see the documentation.
More deprecations are expected in upcoming FME releases, and this article, along with the FME Deprecations article, will be updated as they occur.
If you are having issues with your workflow with one of these formats or require an alternative, please contact Support.
Workarounds
If you are using these older formats, please upgrade the reader or writer in your workspace to utilize the new format.
  • Instead of NTv1 use NTv2
  • Instead of MongoDB, use MongoDB3
Deprecations
The following readers/writers will no longer be available in the FME version under which they are listed. If you require these formats, please use an older version or contact Support to discuss an alternative.
FME 2026.3
  • R Statistical Data (RData) Array as Raster (RDATARASTER)
  • SGI Image (SGI)
  • X11 Pixmap (XPM)
  • Magellan BLX Topographical (GDAL_BLX)
  • NASA Earth Resources Laboratory Applications Software (GDAL_ELAS)
  • OziExplorer OZI OZF2/OZFX3 (GDAL_OZI)
FME 2025.0
  • Azavea Raster Grid (GDAL_ARG)
FME 2022.0
  • Fuji Bio-Imaging Analyzer Systems (BAS) (GDAL_FUJIBAS)
  • Image Display and Analysis (WinDisp) (GDAL_IDA)
  • Erdas 7.x .LAN and .GIS (GDAL_LAN)
  • Intergraph Raster (INGR)
  • IBM Cloudant (CLOUDANT)
  • CouchDB (COUCHDB)
FME 2021.1
  • Arc/Info Export E00 GRID (GDAL_E00GRID)
