Tutorial: Getting Started with ArcGIS Online and Portal
Sienna Emery
Sienna Emery
As of FME 2024.0, support for Esri ArcGIS Online (AGOL), ArcGIS Enterprise Portal, and ArcGIS Server Feature Service formats has transitioned to a unified approach using the new Esri ArcGIS Feature Service (Format). This format replaces the legacy reader/writer formats for each of the three services.
Starting in FME 2026.1, the legacy formats will be hidden in the Quick Add menu. Instead, equivalent functionality is now provided by the downloadable Esri ArcGIS Connector package, available on FME Hub. The package also includes new web services and key transformers such as the ArcGISOnlineConnectorArcGISAttachmentConnector, and ArcGISBranchVersionManager. The package can be installed directly through the Quick Add menu in FME Workbench. Once installed, the new Esri Feature Service format will appear in the Gallery as a unified method for interacting with all three types of Esri ArcGIS Feature Services.
For details on this transition, including guidance on updating existing workspaces, please refer to the article: Working with Esri ArcGIS Feature Services in FME.
In FME, you can connect to Esri ArcGIS Online and Portal in many ways. Depending on your requirements, you can use feature service readers and writers, ArcGIS APIs you can call with HTTPCaller, and webhooks that capture events as they occur using FME Flow (formerly FME Server) automations. We also have an ArcGISOnlineConnector to manage other files stored in ArcGIS Online and Portal.
Connecting
ArcGIS Online and Portal each support different types of authentication.
ArcGIS Online
In ArcGIS Online, a web connection authenticates access. While FME has template web services to connect quickly to ArcGIS Online, do not use them in production. Instead, create a new Esri ArcGIS Online web service that uses your own app credentials. Please see the article How to Create an ArcGIS Online Web Connection (OAuth 2.0) for detailed steps.
ArcGIS Portal
In ArcGIS Portal, you can use several methods to authenticate.
The ArcGIS Portal Feature Service documentation provides an overview of the authentication methods available in FME. Web connections are recommended, as they are secure and reusable. As with ArcGIS Online, create a new Esri ArcGIS Portal web service using your own app credentials. Please see How to Create an ArcGIS Enterprise Portal Web Connection (OAuth 2.0) for detailed steps.
Read, Write, and Transform Data
FME Workbench lets you read, write, update, and remove features in ArcGIS Online and Portal. Once you read data from ArcGIS Online or Portal, you can transform it and write it out to hundreds of different formats. To learn more, please visit the articles below.
ArcGIS Online
ArcGIS Portal
Trigger Workflows When Changes Occur
FME Flow can run your workspaces when an event happens in ArcGIS Online or Portal. This technology is called webhooks. Using FME Flow Automations and webhooks, you can sync data between ArcGIS Online, Survey123, Field Maps, and non-Esri applications. You can also do tasks like sending email notifications when a layer changes or is shared externally. To learn more, please visit the articles below,
ArcGIS Online
ArcGIS Portal
Troubleshooting
