ArcGIS Online Web Connection Troubleshooting
Liz Sanderson
Liz Sanderson
As of FME 2024.0, support for Esri ArcGIS Online (AGOL), ArcGIS Enterprise Portal, and ArcGIS Server Feature Service formats has transitioned to a unified approach using the new Esri ArcGIS Feature Service (Format). This format replaces the legacy reader/writer formats for each of the three services.
Starting in FME 2026.3, the legacy formats will be hidden in the Quick Add menu. Instead, equivalent functionality is now provided by the downloadable Esri ArcGIS Connector package, available on FME Hub. The package also includes new web services and key transformers such as the ArcGISOnlineConnector, ArcGISAttachmentConnector, and ArcGISBranchVersionManager. The package can be installed directly through the Quick Add menu in FME Workbench. Once installed, the new Esri Feature Service format will appear in the Gallery as a unified method for interacting with all three types of Esri ArcGIS Feature Services.
For details on this transition, including guidance on updating existing workspaces, please refer to the article: Working with Esri ArcGIS Feature Services in FME.
Are you encountering issues connecting to ArcGIS Online (AGOL) from FME? Please read below for some common troubleshooting tips and resources.
For information on ArcGIS Enterprise, please see the article How to Create an ArcGIS Enterprise Portal Web Connection (OAuth 2.0).
Content Overview
General Troubleshooting
For FME Flow:
  • Has the connection been uploaded from FME Workbench, and is it up to date?
    • The new Esri ArcGIS Connector package connections need to be uploaded and authorized on FME Flow
  • Have you checked the FME Flow fmeoauth.log for errors or warnings?
    • This log can be found from the FME Flow Web UI, under Resources > Logs > service > current > fmeoauth.log
  • Have you checked the FME Flow fmeconnection.log and fmeserver.log files for errors and warnings?
    • These logs can be found from the FME Flow Web UI, under Resources > Logs > service > current > fmeoauth.log
Getting Started
If you are not yet familiar with FME web connections and web services, please review Web Connections and FME
If you are having issues with your ArcGIS Online web connection (including the underlying web service), then it will help to have a good understanding of ESRI's OAuth 2.0 flow. ESRI’s documentation on the OAuth 2.0 flow used by FME Form is available here. The process is essentially the same for FME Flow’s Server-enabled workflow, but a different redirect URI is used.
It’s important to note that there are two tokens involved in the process: an authorization token and a refresh token. ArcGIS Online authorization tokens only last 30 minutes. Once the authorization token has expired, FME Flow attempts to use a refresh token (also provided by ArcGIS Online) to obtain a new authorization token.
Network complexity introduced by locked-down environments, proxies (outgoing), reverse proxies (incoming), and cloud environments all have the potential to interrupt this process and prevent it from completing successfully at different steps.
If the answers to common issues below do not help resolve your problem, you may need to work with your IT department to monitor network traffic and determine where in the OAuth 2.0 flow the process is failing. A good initial test is to simply try logging into ArcGIS Online from a web browser on the machine where FME Form or FME Flow is installed.
Common Issues - FME Workbench and FME Flow
Before reviewing these issues, we highly recommend walking through the process of How to Create an ArcGIS Online Web Connection from start of finish.
“I see the error ‘401 Client Error: Unauthorized for URL’ in my translation or job log.”
This is typically due to an expired ArcGIS Online connection or an invalid ArcGIS Online web service.
See ArcGIS Online Web Connection Error: 401 Client Error: Unauthorized for URL.
First, try to reauthorize the web connection in FME Workbench or FME Flow, depending on where the issue occurs. If that doesn’t correct the issue, confirm your web connection and web service have been set up correctly. See How to create ArcGIS Online Web Connection for FME Flow (OAuth 2.0)
"I receive the error ‘Invalid redirect_uri Error: 400’ when I try to authorize my ArcGIS Online web connection.”
For FME Workbench, check the Redirect URI parameter in the ArcGIS Online web service. It needs to exactly match the Redirect URI in your ArcGIS Online app. FME 2025.2 and later introduced external browser authentication with Proxy Redirect. This is the recommended approach for OAuth 2.0 Authorization Code web services. The redirect URI is: https://fmeauth.safe.com/v1/oauth2
If you are on an older version of FME Workbench (before 2025.2), an internal FME browser is used for authentication. You can instead use http://localhost or Esri's OOB URL urn:ietf:wg:oauth:2.0:oob as the redirect URI.
For FME Flow, confirm that the Redirect URI in the FME Flow web service matches the Redirect URL in the ArcGIS Online App settings. The URL is <YOUR_FME_FLOW_URL>/fmeoauth.
Please see How to Create an ArcGIS Online Web Connection (OAuth 2.0) for complete instructions.
“My web connection no longer works. I receive the error ‘Access to this application has been blocked.’ in my translation or job log .”
This behavior is linked to ArcGIS Online web connections that make use of FME's out-of-the-box ArcGIS Online web service. Your ArcGIS Online environment may have been changed to no longer allow connections from external apps, such as the one used by the ArcGIS Online web service that comes with FME. We recommend that you create your own ArcGIS Online Web Connection and Service.
Please see: Known Issue: ArcGIS Online connection - unable to set up or previously working connection no longer functional
“My connection times out while writing features to ArcGIS Online.”
Occasionally, writing too many features in a single transaction can cause the connection to time out, which halts the transaction. This could be because the request sent to ArcGIS Online is too large, which can occur due to complex geometries, many attributes, or very large attribute values.
You may receive the following error:
ERROR |ArcGIS Online Feature Service Writer: Could not connect to server. Check that you are connected to the internet and that no firewall is blocking outbound connections. The error was 'HTTPSConnectionPool(host='<URL>', port=443): Max retries exceeded with url
In combination with:
(Caused by ProtocolError('Connection aborted.', ConnectionAbortedError(10053, 'An established connection was aborted by the software in your host machine', None, 10053, None)))'
OR
(Caused by ProtocolError('Connection aborted.', ConnectionResetError(10054, 'An existing connection was forcibly closed by the remote host', None, 10054, None)))'
Reduce the Features Per Request parameter to a smaller number to improve connection stability. You can find this in the Advanced settings in the Esri ArcGIS Online Reader and Writer.
Even with a very small Features per Request size, some customers still experience issues after a certain number of requests. FME Workbench 2023 has introduced an Asynchronous Writes option to the advanced parameters of the ArcGIS Online Feature Server Writer. Setting this option to Yes may help resolve this issue in FME Workbench and FME Flow.
Documentation on the ArcGIS Online Feature Server Writer parameters is available here.
“I was able to authorize my connection, but the workspace fails with 'Could not connect to server'."
If your internet connection is not an issue and you can log in to ArcGIS Online from the same machine where FME is installed, request the current list of ArcGIS Online Domain requirements from Esri. Confirm with your organization's IT that no ArcGIS Online domains are blocked by your firewall.
Common Issues - FME Flow Only
For more general FME Flow web connection troubleshooting please read FME Flow Troubleshooting: Web Connections.
"I can't click the Authorize button to authorize my ArcGIS Online web connection (button is deactivated)."
Make sure that you have entered a valid Client ID, Client Secret, and Redirect URI in the ArcGIS Online web service used by your web connection. Please see How to create ArcGIS Online Web Connection for FME Flow (OAuth 2.0).
“My web connection doesn’t stay authorized in FME Flow. I can authorize it, but it stops working shortly thereafter and I receive a ‘498 invalid token’ error.”
ArcGIS Online authorization tokens last 30 minutes. If the connection does not stay authorized, it is likely because the authorization token cannot be refreshed. There are two main reasons:
  1. The ArcGIS Online web connection and web service have not been set up correctly. See How to create ArcGIS Online Web Connection for FME Flow (OAuth 2.0). Make sure that the token URLs in the FME web service have not been modified. While using organization-specific ArcGIS Online URLs, like www.myorganization.maps.arcgis.com, in the web service token URLs may allow you to authorize the connection initially, they can cause problems with the token refresh process. Do not modify the www.arcgis.com token URLs when creating a new web service.
  2. The ArcGIS Online web connection is being used on multiple FME instances. For example, on two different FME Flow instances or on FME Form and FME Flow. This is a known issue in ArcGIS Online. While many customers can do this without issue, ArcGIS Online may send a new refresh token to one of the FME instances, invalidating the refresh token on the other. In this scenario, whichever FME instance receives the new refresh token will typically continue to work; however, the connection will begin to fail on other FME instances that use it. If you encounter this scenario, please create a separate ArcGIS Online OAuth app and web connection for each FME instance. If you have multiple FME Flow instances each needing a separate ArcGIS Online connection, using a deployment parameter for the connection in your workspace may help. Please read Getting Started with Deployment Parameters to learn more.
“I receive an ‘OAuth Service FAILED’ error trying to authorize my ArcGIS Online web connection.”
If the Redirect URI in the FME Flow web service matches the Redirect URL in the ArcGIS Online application settings, then:
  • Make sure the URL itself is correct. The URL is in the format <YOUR_FME_FLOW_URL>/fmeoauth.
  • Try going to the URL in a web browser - in this case, you should receive the ‘OAuth Service FAILED’ error. If you receive a 404 error or other error, the URL is incorrect.
  • Make sure you are including the fully qualified domain name. For example, https://myfmeflow.myorg.com/fmeoauth instead of https://myfmeflow/fmeoauth.
  • If you still receive an error, try your FME Flow server’s IP address instead of the domain name.
Another cause of this error is an incorrectly configured proxy. Confirm you have set up your proxy correctly in FME Flow. Please see the FME Flow Proxy documentation.
If you are confident you have configured the proxy correctly and are still receiving the error, there may be DNS issues. Try using the proxy server’s IP address as the hostname in the FME Flow proxy settings. The error in the fmeoauth.log file below is another symptom of this.
929026:Error: http://exampleproxy.net
COM.safe.fmeserver.api.FMEServerException: 929026:Error: http://exampleproxy.net
“I receive a timeout trying to authorize or use my ArcGIS Online web connection in a job.”
It’s possible that the OAuth 2.0 process isn't completing successfully due to your organization’s network or firewall configuration.
If your organization uses a proxy, make sure it is correctly configured in the FME Flow UI. Please see the FME Flow Proxy documentation.
The FME Flow Core must be able to communicate with ArcGIS Online and the URLs involved with the OAuth 2.0 process. The Core provides the token to any FME Flow Engines needing it for a web connection. Log in to the FME Flow Core host machine and open a web browser. Confirm that:
  • You can successfully log into ArcGIS Online
  • You are using the fully qualified domain name (FQDN) for the redirect URI in both the ArcGIS Online app and the FME Flow web service. Especially if your organization has restrictive network rules. For example, https://myfmeflow.myorg.com instead of https://myfmeflow.
  • You can manually reach the ArcGIS Online OAuth URLs below
Authorization Code URL:
https://arcgis.com/sharing/rest/oauth2/authorize?response_type=code&redirect_uri=urn:ietf:wg:oauth:2.0:oob&client_id=<Your_Client_ID>
That should return an ArcGIS Online authorization code to use in the Token URL below:
https://www.arcgis.com/sharing/rest/oauth2/token?redirect_uri=urn:ietf:wg:oauth:2.0:oob&client_id=<Your_Client_ID>&client_secret=<Your_Client_Secret>&grant_type=authorization_code&code=<Authorization_Code>
If you cannot access ArcGIS Online URLs outside FME using a web browser, please discuss this with your IT department. They may need to make changes to allow your FME Flow Core host machine to communicate with ArcGIS Online.
“When I try to update my ArcGIS Online web service on FME Flow using the web UI, I receive an error about invalid input parameters.”
This issue affects FME Server versions 2021.2 through 2022.2. It has been resolved in build 2022.2 22785 and later.
ArcGIS Online Web Connections created from the ArcGIS Online Web Service template do not work on FME Flow. The workaround is to remove the template ArcGIS Online web service from FME Flow. Please see: Known Issue: Web Services on FME Server are Invalid
Additional Resources
Are you still experiencing issues?
Please consider posting to the FME Community Q&A if you are still experiencing issues that are not addressed in this article. There are also different support channels available: How to Create a Great FME Flow Support Case
Have ideas on how to improve this?
You can add ideas or product suggestions to our Ideas Exchange.
