FME Flow Troubleshooting: Web Connections
Liz Sanderson
Liz Sanderson
Full Guide: FME Flow Troubleshooting Guide
Are you encountering issues connecting a web service to FME Flow (formerly FME Server)?
Many workspaces that run from FME Flow require you to connect to and authenticate with a web service. FME Flow allows you to securely upload, store, and reference your own authentication parameters with Web and Database Connections. And just like in FME Workbench, connections to web services are safely stored as self-contained objects. Once uploaded to FME Flow, the Web Connections page provides a convenient management hub.
Web and Database Connections previously shared the same troubleshooting article. We have since broken the article into separate articles so we could expand on each topic and it would be easier to find via search. Please navigate to FME Flow Troubleshooting: Database Connections article for troubleshooting database connections in FME Flow.
Common issues:
Getting Started
If you're looking for general information about web connections, please see Web Connections and FME
General Troubleshooting
Has the connection been uploaded from FME Form, and is it up to date?
Has the Web Service been configured correctly from FME Workbench?
When a web connection fails in FME Flow only after some time, but still connects from FME Workbench, this is a telltale sign that your web connection is not authorized for FME Flow. Many web services require specific configuration on FME Flow to authenticate.
You'll need to create a new App from the web service you are trying to connect to. After creating the App, update the client and secret in the FME Workbench web service, then reupload the web connection to FME Flow. For more instructions, please review the documentation for Managing Web Services.
(TIP: In most cases, the Web Service Redirect URI should be "<yourFMEFlow>/fmeoauth")
Have you checked the FME Flow fmeoauth.log for errors or warnings?
This log can be found from the FME Flow Web UI, under Resources > Logs > service > current > fmeoauth.log
If you are receiving a web connection error while running a job, have you tried Log Debug
To use Run Workspace with Log Debug enabled, set the Log Debug toggle to True under the Advanced parameters. Then, click "Run.
To enable Log Debug for all jobs for the same workspace, open the workspace in FME Workbench. Next, check Log Debug under Tools > FME Options > Translation > Log Settings. Then, republish to FME Flow and rerun the job. Check the job log again. Log Debug mode may provide more information, like access token expiry times and API call details. Remember to turn Log Debug off once you're done troubleshooting, as it can impact job performance.
Relevant Logs
See Troubleshooting with Logs for where to find log files.
Logs > core > current > fmeconnection.log, fmeserver.log
Common Issues
“After upgrading FME Flow, my web connection stopped working”
See our known issues in the currently supported versions here
If the problem does not correspond to a known issue, please ensure all original network settings have been migrated to the upgraded FME Flow.
"How do I give permission for other users to use my web connections?”
Unauthorized request by user due to lack of proper permissions
Often, this error comes down to user permissions to connections and resources. Please review FME Flow Connections Runtime Error: Unauthorized request by user due to lack of proper permissions for possible causes and how to resolve the error.
 "How can multiple users share web connections on FME Flow?"
The solution for sharing connections often begins with desktop connection management. Once workspaces are uploaded, they can easily share connections by referencing the same connection name. For best practices, consult Making Database and Web Connections Public.
“How do I enable an OAuth web connection to authenticate from my private network?”
Not all web services require a Public DNS. Some examples of web connections that do not require a public DNS include ArcGIS Online and Microsoft Graph.
Some web services require a Public DNS. There are a few ways to do this, so we recommend consulting your organization’s IT services first. For documentation on the process, please consult "Enabling FME Flow for Public Access."
“My web connection works in FME Workbench, but not FME Flow”
Republish the web connection from FME Workbench.
For OAuth web connections, consult Configuring FME Flow to use OAuth-based Web Connections.
  • Authorize the web connection in FME Flow.
  • Configure the web service in FME Flow. Some web services require further configuration to be compatible with FME Flow, such as:
  • Remove the web service, republish from FME Workbench, and reauthorise from FME Flow.
Publishing to FME Flow produces a message "Error Communicating with FME Flow, FME Flow may not be running..."
There are different causes for this error, including the following:
1. FME Flow services are not running
  • Restart FME Flow and FME Services. Once you have confirmed FME Flow is running, try publishing again
2. FME Flow has been installed on a non-standard port number
  • If a non-standard port was used, correct the URL: Make sure to enter the non-standard port in the URL: http://<host>:<port>
3. You are using a proxy server to access the internet.
You may need to configure FME Workbench to use the proxy server when publishing workspaces to FME Flow using the Web Connection:
  1. Configure FME Workbench to use your system proxy settings by navigating to Utilities (Tools 2025.0 and earlier) > FME Options > Network and selecting the 'Use system proxy settings' checkbox. If required by your proxy server, fill in the authentication information.
  2. Verify that the proxy settings are functioning correctly in FME Workbench by navigating to Help> Check for Updates. If FME cannot check for updates, then you may need to ensure that your system is configured to use your proxy server. Save your workspace if necessary
  3. Restart FME Workbench.
  4. Try publishing your workspace to FME Flow again.
Additional Resources
Are you still experiencing issues?
Please consider posting to the FME Community Q&A if you are still experiencing issues that are not addressed in this article. There are also different support channels available.
Have ideas on how to improve this?
You can add ideas or product suggestions to our Ideas Exchange.
