Enabling FME Flow for Public Access
Richard Mosley
Richard Mosley
FME Flow is often installed on an internal network with restricted access; however, some functionality, such as Webhooks or Flow Apps, may require communication with the public Internet.
There are many tools to secure a server for public access, including Reverse Proxy Servers, Application Gateways, Firewall Rules, Networking Rules, and Load Balancers. Safe Software does not provide a recommended configuration for this setup, and you will need to discuss with your IT team which solution best suits your organization. This article documents the information you’ll need to proceed with your chosen solution.
HTTPS Configuration
The web application ports 80/443 must use HTTP/HTTPS. FME Flow can be configured with HTTPS by installing a certificate on each Web Application. To configure FME Flow with SSL, please read Configuring FME Flow for HTTPS.
Please ensure your cert matches FME Flow’s DNS name.
HTTPS Configuration with a Reverse Proxy or Load Balancer
If you are using a reverse proxy or a load balancer to configure FME Flow for public access, you can choose between several different configuration options.
  • Only FME Flow has SSL (TLS/SSL passthrough)
  • Only your reverse proxy or load balancer has SSL (TLS/SSL termination)
  • Both FME Flow and your reverse proxy/load balancer have SSL (End-to-end TLS/SSL, TLS/SSL bridging)
TLS/SSL Termination
If your reverse proxy or load balancer is already SSL-configured, you may choose to use TLS/SSL termination and not configure FME Flow with SSL. This means traffic is decrypted at the load balancer/reverse proxy and passed to Flow without encryption. For TLS/SSL termination, the reverse proxy can be on the same machine as FME Flow (as with using NGINX) or on a separate server.
To correctly configure for TLS/SSL termination, see the Enabling FME Flow for Public Access page in our admin guide.
End-To-End TLS/SSL or TLS/SSL Bridging
If you require traffic to be encrypted on your internal network, end-to-end TLS/SSL or TLS/SSL bridging may be required. To set this up, you will need to configure FME Flow for HTTPS, then configure the load balancer/reverse proxy to point to Flow.
If you are using a non-CA cert like a self-signed certificate, you may have to import one or more certs (such as your reverse proxy/load balancer certificate or Flow’s certificate) into the FME Flow trust store. See Configuring FME Flow for HTTPS for instructions.
If this is necessary, but has not yet been successfully completed, you may experience PKIX Path Issues.
Webhooks
Webhooks use standard HTTP/HTTPS ports, typically 80/443.  To use this functionality outside your internal network, you must grant access to the service URL (used to run jobs directly) or the webhook URL from an automation trigger:
Service URL: https://myflow.com/<service>/ where the service is fmejobsubmitter, fmedatadownload, or fmedatastreaming. This URL can be found from the Run Workspace > Actions > Create Webhook.
Automation Webhook URL - REST API V3: https://myflow.com/fmerest/v3/automations/workflows/<UUID>/<UUID>/message. This URL can be found in Automations > Webhook Trigger.
As of FME Flow 2025.1, the V3 REST API has been deprecated. The current API will remain accessible, but no new features or general bug fixes will be implemented. Starting with FME Flow 2026.1, the V3 API will be removed. We encourage all users to prepare their systems for this change.
The V4 REST API offers enhanced security and usability, including new and reorganized endpoints, as well as the removal of certain endpoints. For information on migrating from V3 to V4, please see the FME Flow REST API V4 documentation and click on the heading Migrating from REST API V4.
Automation Webhook URL - REST API V4: https://myflow.com/fmeapiv4/automations/<UUID>/<UUID>/message. This URL can be found in Automations > Webhook Trigger.
WebSockets
WebSockets initiate traffic on HTTP/HTTPS before being redirected to the WS/WSS protocol, so both protocols need to be opened to the public internet.
For more information on WebSocket ports, see the Enabling FME Flow for Public Access page in our admin guide.
For more information on all of FME Flow's ports, reference the FME Flow Ports documentation.
The WebSocket server is part of the FME Flow Core process, so in installations where the FME Flow Core and FME Flow Web Application Server Service are on different machines, public WebSocket traffic must be routed to the core machine.
Routing Traffic to FME Flow
For a list of FME Flow's URL paths that need to be whitelisted and/or forwarded to Flow from a reverse proxy/load balancer, or if FME Flow cannot route traffic back to the reverse proxy/load balancer, please see the Enabling FME Flow for Public Access page in our admin guide.
FME Flow Service URLs
If you are using a reverse proxy or load balancer, FME Flow’s service URLs need to be changed to the reverse proxy/load balancer’s DNS name because clients will be unable to connect directly to the web application server.
To change all service host names from the FME Flow Web UI, open the Services page under Admin > System Configuration> Network & Email, then select "Change All Hosts." If necessary, you may also need to add your port number (example: 8443).
Troubleshooting
FME Flow Troubleshooting: Proxies
FME Flow Troubleshooting: SAML
SAML Authentication Failure
PKIX Path Issues when Configuring HTTPS/SSL for FME Flow
FME Flow on Azure: Unable to run jobs when using internal or private Azure Load Balancer
Additional Resources
Enabling FME Flow for Public Access (Admin Guide)
FME Flow Best Practices Guide for IT Ops and Flow Admins
FME Flow Security
FME Flow Ports
Use a Reverse Proxy with FME Flow
Set Up the Load Balancer and Configure with FME Flow
SAML Configuration - FME Flow
