When you submit a job through the FME Flow Run Workspace page, it fails with the following message:
There was an error submitting the jobHowever, the same job may be successfully submitted via Schedule or Automation. This article covers common troubleshooting steps for this scenario.
Initial Troubleshooting
1. Is the submission error returned no matter which workspace you submit to?
Try a workspace from the Samples repository or another service (e.g., Job Submitter, Data Download, etc.).
2. Are there any messages labeled ERROR, WARN, or SEVERE in the system logs?
Check the following logs:
- <FME Flow System Share>\Resources\Logs\tomcat\catalina.log
- <FME Flow System Share>\Resources\Logs\core\fmeserver.log
- <FME Flow System Share>\Resources\Logs\core\fmeprocessmonitorcore.log
- <FME Flow System Share>\Resources\Logs\service\jobsubmitterservice.log
3. Are there any errors in the browser Developer Tools?
See Debugging Toolbox: Developer Tools for instructions.
Common Issues
HTTP/SSL
It is common for Job Submission issues to be related to HTTPS/SSL configuration.
Are the Service URLs correct?
If you perform any post-install configuration changes, such as:
- SSL Configuration
- Changing the FME Flow Web URL/port
You must also update the Service URLs. The service URL format should match the URL you use to access the FME Flow web interface.
- Log in to the FME Flow from a browser.
- Navigate to Services (Admin > System Configuration > Network & Email > Services).
- Click on Change All Hosts.
- In the URL Pattern field, make sure the correct port, protocol, and hostname are specified. If unsure, verify that the Service URLs match the FME_SERVER_WEB_URL parameter in the fmeFlowConfig.txt config file (default location is C:\Program Files\FMEFlow\Server).
- Click OK when done, and try submitting a job.
Has the certificate been imported into the trusted cacerts?
You may receive job submission errors if an SSL certificate is self-signed or hasn't been imported into the FME Flow cacerts truststore.
In Developer Tools or localhost_access_log.log (tomcat):
'500 (Internal Server Error)' In the fmeprocessmonitorcore.log (core):
javax.net.ssl.SSLHandshakeException: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target
To resolve this issue, export your certificate from the web browser as Base-64 encoded X.509 (CER) and import this file into <FMEFlow>\Utilities\jre\lib\security\cacerts. See PKIX Path Issues when Configuring HTTPS/SSL for FME Flow.
Has the certificate expired?
You may receive job submission errors when an FME Flow SSL certificate has expired.
In Developer Tools or catalina.log (tomcat):
javax.net.ssl.SSLHandshakeException: java.security.cert.CertificateExpiredException: NotAfter: Tue May 12 14:15:56 EDT 2020To resolve this error, issue a new certificate and install it in FME Flow; then, restart all services. See Configuring FME Flow for HTTPS: Updating an expired Certificate.
Has FME Flow been deployed with an internal or private Azure Load Balancer?
If FME Flow is deployed in Azure with an internal or private Azure Load Balancer, you may be unable to submit jobs consistently.
In Developer Tools or localhost.log (tomcat), you may see a '500 Internal Server Error' reported with a message similar to:
java.net.ConnectException: Connection timed out: connectThere is an Azure limitation on accessing the Load Balancer from the same VM and Network interface. You can resolve this issue via one of the following methods:
- Configure separate backend pool VMs per application.
- Configure the application on dual-NIC VMs so each application uses its own network interface and IP address.
1. Add a second NIC to FME Flow Core virtual machine(s)
This blog outlines workarounds for this limitation.
Adding a second NIC to the FME Flow core/web VM and routing outbound traffic through the second NIC resolves this issue.
For steps, please refer to Azure documentation: Add network interfaces to or remove network interfaces from virtual machines.
Configure the VM operating system to use multiple network interfaces properly: Windows, Linux
2. Use Azure Application Gateway
Azure Application Gateway is a web traffic load balancer that enables you to manage traffic to your web applications. It does not have the same limitations as Azure Load Balancer.
Does the workspace contain a User Parameter called "token"?
Open the workspace in FME Form and review its User Parameters. If there is a parameter named "token", this is an FME Flow reserved word. Try renaming the parameter, republishing it to FME Flow, and submitting it again
For more information, please see the community post on Authentication failed: Account is disabled when trying to run a job on FME Server
As of FME 2025.2, the term "Published Parameters" has been renamed in both FME
Form and FME Flow.
In FME Form, "Published Parameters" are now called
Visible Parameters and "Private
Parameters" are now called Hidden Parameters.
In FME Flow, "Published Parameters" are now simply called
User Parameters.
This terminology is still in the process of changing, so older versions may
still
reference "Published Parameters".
Are you using IE and accessing FME Flow through single sign-on (SSO)?
There is a documented job submission issue (FMEFLOW-16583) while using FME Flow, Internet Explorer, and SSO. Upon submitting a job, Developer Tools reports a '401 Unauthorized' error. The fmeserver.log (core) will log an authentication error:
Failed login by user guest due to insufficient credentials.To work around this issue, use a different browser (e.g., Google Chrome) or disable SSO.
Does the account running the FME Flow System Services have full access to the FME Flow System Share?
Ensure that the system account running the FME Flow System Services has the required permissions to the System Share. In particular, double-check that it can read/write to the 'Queue' folder (resources > logs).
Symptoms of this issue:
- No logging is taking place (resources > logs)
- There are errors related to the 'queue' in the fmeserver.log
To resolve this issue, grant the service account full control of your FME Flow System Share. For details on all the permissions required by the service account, read our Directory and Account Permissions documentation.
FMEFlowJobSubmitter
Are you using an FMEFlowJobSubmitter transformer in your workspace and experiencing the error "There was an error submitting the job"? Please see the full troubleshooting guide for this transformer: FME Flow Troubleshooting: FMEFlowJobSubmitter
Other Community Posts
Are you still experiencing issues?
Please consider posting to the FME Community Q&A if you are still experiencing issues that are not addressed in this article.
There are also different support channels available.
