FME Flow Security
Liz Sanderson
Liz Sanderson
This article is intended to provide a high-level overview of FME Flow Security.
For technical instructions on how to enhance security for FME Flow, please see the FME Flow Best Practices Guide for IT Ops and Server Admins.
Authentication
Authentication is the process used to verify the identity of the person accessing the application. FME Flow supports both user- and token-based authentication, configurable via the FME Flow Web UI or programmatically through the REST API.
User Security
Users can be created directly on the system, or FME Flow can be integrated with Windows Active Directory or other LDAP-based directories. When accessing FME Flow, users are granted access to different components and must enter their credentials to log in and use this functionality.  If using Windows Active Directory, optionally the Administrator can also enable Integrated Windows Authentication (IWA), commonly referred to as single sign-on, removing the need for users to enter their user credentials in the Web UI.
For enhanced security, the System Administrator can configure a password policy, password expiry, and password recovery for system user passwords (not directory servers). The password policy is enabled by default and is customizable; optionally, you can specify a minimum number of characters, along with other controls on what the password should/should not contain.
Password expiration is disabled by default, but if enabled, it forces users to reset their password after the specified period. To enable password recovery a System Email must be configured and all users must have an email address associated with their account.
Token Security
FME Flow can receive requests from outside a user session through the REST API, for example, if you are developing a custom application, or through transformation services, for example, when you submit a job using a webhook URL or workspace app.
Token Security provides an encrypted string passed with the request, bypassing the need to log in to FME Flow interactively. Tokens can be granted a restricted set of permissions, stored securely, and set to expire.
Log In Sessions
FME Flow keeps the user session alive for as long as the application is running in the browser. Encourage users to log out of FME Flow when they are not using it.
The System Administrator can disable Multiple Web Sessions. This will restrict users to a single session, forcing FME Flow to log a user out of any previous session opened in another browser.
Authorization
Authorization is the process used to determine what activities a user is permitted to undertake.
Role-Based and User-Based Access
FME Flow includes a role-based control framework; a role is a group of one or more users, allowing System Administrators to grant a set of permissions to a role that apply to all users assigned to it. This is configured in the User Management page of the FME Flow Web UI.
Alternatively, you can assign permissions to an individual user account. Through role/user permissions, you can grant access to different items and functionality in FME Flow, restricting the tasks users can perform.
Workspace and Data Access
Workspaces are managed in a folder system known as repositories. In FME Flow, role- and user-based access lets you grant workspace permissions at the repository level, including options to download, read, publish, run, and remove.
Data can be uploaded to FME Flow:
  • With the workspace and stored in the same repository
  • Through the data upload service, in which case it is stored in the TEMP folder
  • Uploaded via the Web UI or REST API into another Resources folder
Data stored with the workspace can be used only by that workspace, and the same repository-level permissions apply as above. Data uploaded temporarily is accessible to the user who performs this action. The System Administrator can grant varying permissions to all folders in Resources, including read and download, list, write, upload, and remove. Users can also share resource folders they create with other roles/users via the Web UI.
If a workspace is referencing a file stored in a network-based resource outside of FME Flow’s System Share, read/write access is not controlled by the user/role; instead, the service account running the FME Flow Web Application, Core, and Engine Service must have read/write permissions to this file path.
Password Encryption
System user account passwords and tokens, along with other passwords stored in FME Flow, such as web/database connections and workspace user parameters, are encrypted and stored in the system database. The FME Flow database password specified in the installer is encrypted by default and stored in the fmeDatabaseConfig.txt.
The key used for encryption can be configured in the FME Server Web UI under System Configuration > Security > System Encryption. Enabling restricted mode creates a key unique to your FME Flow installation. Passwords stored in the system database will be automatically re-encrypted, but you must manually re-encrypt the database password.
If you choose to connect and import users from a Directory Server, these user passwords are not stored on FME Flow and reside with the LDAP Server / Identity Provider.
Web Application Security
FME Flow ships with a third-party Web Application Server; you can find the version shipped with each FME Flow release here. Optionally, you can provide your own Web Application Server.
By default, FME Flow uses standard HTTP* requests and responses. You can configure FME Flow to use HTTPS with customer-supplied certificates to encrypt communication between the client and FME Flow.
FME Flow Hosted and containerized FME Flow deployments are configured for HTTPS by default with a certificate provided during the installation.
Risk Assessments
FME Flow undergoes regular penetration and security assessments. If your organization has conducted a security scan that has reported a vulnerability or you have any other security concerns, please submit a case to Safe Software Support.
Other Resources
