Working with Zero-ETL and FME
Tandra Geraedts
Tandra Geraedts
As organizations demand faster access to data, many are looking beyond traditional Extract, Transform, Load (ETL) pipelines toward approaches that deliver information in real time, without duplicating or staging it along the way. Zero-ETL is one term driving this shift. For teams using FME, adopting a Zero-ETL approach doesn't mean abandoning existing workflows; you can extend FME's integration capabilities toward direct, on-demand access to live data.
This article introduces how FME supports Zero-ETL patterns in practical, operational terms. It is intended for both practitioners building FME workflows and decision-makers evaluating whether a Zero-ETL approach fits their data strategy.
By the end of this article, you will understand how to:
  • Distinguish Zero-ETL from traditional ETL and Reverse ETL
  • Expose real-time data through FME Flow Data Virtualization instead of duplicating it
  • Connect directly to high-velocity data streams
  • Automate event-driven responses as data changes
  • Transform data in flight, without a staging layer
  • Apply governance and validation without slowing real-time data down
Understanding Zero-ETL in FME Terms
Zero-ETL is often discussed alongside ETL and Reverse ETL. The following concepts appear frequently in this context and map directly to FME capabilities.
ETL (Extract, Transform, Load): The traditional workflow of extracting data from source systems, transforming it, and loading it into a destination such as a data warehouse. FME Form workspaces have always been built around this pattern, and it remains the right approach for batch or scheduled integration.
Reverse ETL: The opposite flow — extracting data from a centralized store and loading it back into operational business systems. FME Form workflows and FME Flow Automations can run this pattern on demand or on a schedule.
Zero-ETL: An approach that bypasses traditional pipelines to establish a direct connection between a data source and its destination, prioritizing real-time access over data movement. In FME, this is achieved through Data Virtualization, event-driven Automations, and Streams rather than scheduled batch jobs.
Data Virtualization: A method of accessing data on demand, without copying or relocating it first. FME Flow's Data Virtualization turns FME workspaces into secure, queryable API endpoints, so requesting applications always receive current data.
Change Data Capture (CDC): A pattern used by many native cloud Zero-ETL services to detect and propagate changes from a source database automatically. FME complements this pattern by acting on database change events through Automations, and by transforming and routing the resulting data.
Event-Driven Automation: A process that runs automatically in response to a trigger, rather than on a fixed schedule. FME Flow Automations can respond to webhooks, WebSocket messages, or frequent polling of an API or database.
Data Streaming: The continuous ingestion of high-velocity data as it's generated. FME Flow Streams keep a workspace running against a message broker such as Kafka, MQTT, or RabbitMQ, processing messages as they arrive.
FME and Zero-ETL at a Glance
Zero-ETL Pattern Examples How FME Connects
On-Demand APIs REST/OpenAPI endpoints, live dashboards FME Flow Data Virtualization
High-Velocity Streams Apache Kafka, MQTT, RabbitMQ KafkaConnector and similar stream-mode connectors via FME Flow Streams
Event-Driven Triggers Webhooks, WebSocket messages, database change events FME Flow Automations, WebSocketConnector
In-Flight Transformation Format conversion, schema mapping, enrichment FME Form transformers: HTTPCaller, OpenAPICaller, SchemaMapper
Governance & Validation Access control, schema and attribute validation Data Virtualization security controls, validation transformers
FME Flow can be hosted entirely within AWS, Azure, or Google Cloud, so Zero-ETL workflows can run alongside native cloud services like Aurora-to-Redshift integration or BigQuery federated queries without requiring a separate platform.
The Role of FME in Zero-ETL
Exposing Real-Time Data Through Data Virtualization
Rather than exporting data into a staging area before it can be used, Data Virtualization lets FME Flow serve data directly from the source, on request. This is the clearest expression of Zero-ETL in FME: no duplicated copies, no scheduled load, just current data delivered the moment it's requested.
FME Flow can:
  • Turn any FME workspace into a secure, queryable REST API endpoint
  • Support full CRUD (create, read, update, delete) operations against live sources
  • Automatically document APIs using OpenAPI standards, with a built-in Swagger interface
  • Cache and process requests asynchronously to support production-scale traffic
  • Serve as a single access layer shared by multiple applications, avoiding duplicate staging tables or exports
Learn More:
Customer Story: Tapestry built its data fabric platform around FME as the integration layer for its Retail+ and Supply+ products. Rather than staging and batching customer data, FME extracts data directly from on-site databases and delivers it into Tapestry's cloud platform in near real time, giving retailers and suppliers a live, shared view of inventory and performance. This data virtualization approach lets a single Chief Science Officer accomplish what would otherwise require a four-person team, a 300% increase in resource efficiency, while retailers gain up to a 400% return on investment by monetizing shared data with suppliers.
Connecting Directly to High-Velocity Data Streams
Some data doesn't arrive on a schedule: it arrives continuously, sometimes as thousands of messages per second. Traditional ETL jobs aren't built to keep up with this volume. FME Flow Streams are.
FME Flow can:
  • Maintain a continuously running workspace against a message broker such as Kafka, MQTT, or RabbitMQ
  • Filter and reduce high-volume feeds so only relevant records are processed or stored
  • Enrich streaming messages with spatial or reference data as they pass through
  • Scale stream processing across multiple engines for higher throughput
Learn More:
Customer Story: Sweco used FME's ability to read directly from a Kafka topic to build a proof of concept that combines multiple live logistics feeds and visualizes them on a web map in real time without first loading the data into an intermediate store.
Automating Event-Driven Responses in Real Time
Zero-ETL also covers reacting to data the moment it changes, not only when it arrives. FME Flow Automations are built for this: workspaces run when something happens, rather than on a fixed schedule.
FME Flow can:
  • Trigger workspaces automatically from webhooks, WebSocket messages, or API/database polling
  • Chain multiple workspaces so the output of one step triggers the next
  • Respond to database change events without a separate scheduled sync job
  • Run entirely within AWS, Azure, or Google Cloud environments
Learn More:
Customer Story: The City of Sainte-Thérèse needed to communicate shifting winter parking and snow-removal zones to 26,000 residents every day, previously a manual process. Using FME Flow, the city automated the full loop: extracting field data collected by public works supervisors and publishing it directly to a live web map and PDF with no manual step in between. The resulting map became the city's most-visited page, accounting for 96% of all site map traffic, and cut winter parking-related inquiries by 50%.
Transforming Data In Flight, Without a Staging Layer
Removing the ETL step doesn't mean removing transformation; it happens as data moves, not after it lands. FME workspaces provide this transformation layer for Zero-ETL patterns.
FME can:
  • Convert formats, restructure schemas, and enrich data as it passes between systems
  • Parse poorly structured source data (for example, free-text fields) into usable, typed attributes
  • Route transformed data to multiple destinations simultaneously
  • Use parallel processing engines to absorb burst-driven spikes in demand economically
Learn More:
Customer Story: As covered above, Tapestry also relies on this in-flight transformation: point-of-sale data arriving as inconsistent, poorly structured text strings is parsed and standardized by FME as it flows into the platform, rather than being cleaned up in a separate batch step afterward.
Validating and Governing Data Without Slowing It Down
Removing pipeline steps doesn't remove the need for data quality and access control; it just means governance has to happen in real time, alongside the data, instead of at the end of a batch job.
FME can:
  • Apply authentication, permissions, and filters to control exactly what a Data Virtualization API exposes
  • Validate attributes and schema structure before serving or writing data
  • Flag or reject non-conforming records automatically, even in a continuous stream
  • Apply consistent governance rules across every real-time destination
Learn More:
Customer Story: Racker, a human services agency serving thousands of clients across three New York counties, used FME to eliminate a four-month backlog in therapy billing by automating data extraction and validation across three separate electronic health record systems and cutting processing time to one hour while ensuring every record met billing and compliance requirements before it moved downstream. Racker also uses FME to govern identity and access: automated workflows enforce multi-factor authentication and role-based access across HR and recruiting systems, replacing manual, ticket-based account management that had left room for delayed or inconsistent access control.
Conclusion
Zero-ETL doesn't ask organizations to give up the transformation, validation, and governance work that ETL has always handled; it asks for that work to happen in real time, at the point of access, instead of in a scheduled batch. FME supports this shift through Data Virtualization, Streams, and Automations, working alongside native cloud Zero-ETL services rather than replacing them.
For practitioners, this means building real-time data services with the same no-code FME Form interface already used for batch workflows. For decision-makers, it means the option to move toward real-time data delivery incrementally, without discarding existing FME investments or locking into a single cloud provider's native Zero-ETL offering.
