Amazon Web Services (AWS) provides a comprehensive set of cloud computing tools, many of which require data to be useful. The FME platform has a wide range of functionality available for working with AWS. In addition, the FME Flow Hosted product runs entirely within AWS.
FME and AWS Integrations
The following is a list of what AWS components can be integrated with FME. In addition, links to any tutorials and documentation we have.
| AWS Component | FME Component | Tutorials & Documentation |
| S3 |
FME Form: Using the S3Connector transformer, list, download, upload, and delete data from an S3 bucket. FME Flow: Watch an S3 Bucket or upload to a bucket. |
| EC2 |
Install FME on an EC2 virtual machine instance. FME Cloud is hosted in EC2 |
| SQS |
FME Form: Using the SQSConnector transformer, send, receive, delete, and count messages. FME Flow: Trigger an automation when an SQS message arrives, or send an SQS message. |
| SNS |
FME Form: Using the SNSSender transformer, notify a topic. FME Flow: Trigger an automation when a topic is notified or notify a topic. |
| Aurora | Amazon Aurora readers and writers. |
| Athena | AmazonAthenaConnector transformer used to query S3 buckets |
| Redshift | Amazon Redshift Spatial and Non-Spatial readers and writers |
| DynamoDB | Amazon DynamoDB reader and writer |
Starting in FME 2025.2, many formats that support both spatial and non-spatial data have been combined into a single reader or writer. For an up-to-date list of the formats this change has been applied to, please see Combined Spatial and Non-Spatial Readers and Writers.
How to Create an Amazon Web Services Web Connection
The S3Connector, SNSSender, SQSConnector, AmazonAthenaConnector, and DynamoDB reader/writer all use the Amazon Web Services web connection. To learn how to set up the connection, follow the instructions below.
1. Open FME Workbench
In FME Workbench, navigate to Tools > FME Options (Windows) or FME Workbench > Preferences (macOS).
In the FME Options dialog, switch to Web Connections, then click on the plus sign (+) to create a new connection.
2. Create the Web Connection
In the Edit Web Connection dialog, set Web Service to Amazon Web Services, then give the connection a meaningful name. Next, you’ll need to log into your Amazon console and obtain your Access Key ID and Secret Access Key. Once you have obtained those, enter them into the Web Connection dialog. Finally, set your Region. Click OK to finish creating the web connection.
3. Use the Web Connection
This web connection can be used throughout FME workflows and uploaded to FME Flow. To use the web connection, add one of the various Amazon transformers, readers, or writers to the canvas, then, for Connection, click on the drop-down and select the newly created Amazon Web Services connection.
