Configuring FME Flow for SAML Authentication
Richard Mosley
Richard Mosley
FME Flow has implemented SAML authentication for security. You can configure FME Flow to use a variety of Identity Providers, and our documentation provides information on what's required of FME Flow. Here you can find step-by-step instructions for working with a few common providers. Most IdPs require SSL configuration, so if FME Flow is not configured with HTTPS, please follow the documentation.
Once enabled, when a user signs in with SAML authentication, the user will be added to FME Flow and assigned the permissions configured in the SAML configuration. Note: all users who have access to the SAML application you create will have login rights to FME Flow.
Why use SAML Authentication
Security Assertion Markup Language (SAML) is a protocol for authenticating web applications. This can be useful not only within a company to adhere to a security practice, but also can be beneficial when connecting to an FME Flow or a Flow App outside of the internal network, where traditional Active Directory is not usable. Most SAML providers also offer another layer of security known as Multi-Factor Authentication (MFA). This added layer sits on top of the Identity Provider (IdP) SAML authentication and requires no additional configuration from FME Flow.
Articles
User Attribute Mapping
Attributes are user details stored in your SAML Identity Provider (IdP) and can be sent to your Service Provider (SP), i.e., FME Flow. This feature enables you to map these IDP user attributes to FME Flow user profile values. We have instructions for two common IdPs-
Publishing Workspaces from FME Workbench
To publish workspaces from FME Workbench to FME Flow via the Publishing Wizard,
  • Check "Use Alternate Login Method", provide the following, and click "Continue"
    • FME Flow URL: The URL of the FME Flow to which you want to connect.
    • Log In with: Specify "SAML".
  • On the login page for your SAML identity provider, enter your credentials.
  • Proceed with the next dialog.
Additional Resources
FME Flow SAML Documentation
