Tutorial: Getting Started with Any AI in FME
Crystal Wang
Crystal Wang
Artificial Intelligence (AI) services are transforming how we analyze, enrich, and automate data. Whether you’re working with OpenAI, Amazon, Azure, Google, or other AI providers, FME makes it possible to leverage their power directly in your data integration workflows.
In FME Hub, you’ll find a growing set of transformers to connect to AI, such as:
And more! Search FME Hub for “AI” to discover the latest.
FME’s flexibility goes well beyond the connectors developed by Safe Software. Users can create their own AI connections through APIs whenever they need full control over how new services are integrated. At the same time, Safe Software and our Partner Network accelerate this process by publishing ready-to-use custom transformers on the FME Hub, giving users instant access to prebuilt integrations. AI Transformers can be added straight from the Quick Add menu in Workbench, which allows organizations to spend their time designing workflows rather than building every connector from scratch.
Why Use FME with AI?
Pairing FME with AI enables you to:
  • Automate bulk AI calls: process many prompts in one workflow
  • Build apps for end users to query AI using FME Flow Apps
  • Enrich data: run data through AI to classify, summarize, and generate insights
  • Enhance outputs: integrate AI-generated text, reports, or images into your data products
  • Predict and analyze: use AI in your workflow for trend detection, predictive modelling, and survey result classification
  • Creative automation: generate scripts, SQL queries, images, or text datasets based on a dynamic input
As AI technology continues to improve, the possibilities are only limited by your imagination. Below, you will find many resources for using AI within FME.
Getting Started
To use these transformers, you will need to sign up with the respective AI service provider and then generate an API key.
  • Sign up with your preferred AI provider (eg. OpenAI, Azure AI, Google AI, etc.)
  • Generate an API key for authentication
  • Install the relevant transformer(s) from FME Hub to connect to the AI service within FME
Tutorials
Getting Started with AI in FME: AI Service Authentication
Learn how to successfully connect an FME workspace to an AI provider.
Getting Started with AI in FME: Prompt Engineering With Text Generation and Structured Outputs
Learn the basics of prompt engineering in FME workflows, such as when to choose text vs. structured outputs, how to structure and send data to an AI model in FME, and more.
Getting Started with AI in FME: Extracting Insights from Unstructured Documents
Learn how to analyze a PDF using AI to return key information such as summaries, insights, and structured metrics.
Getting Started with AI in FME: Classifying Unstructured PDF Files
Learn how to clean, classify, summarize, and validate unstructured documents using the OpenAIConnector transformer.
Getting Started with AI in FME: Web Searching
Learn how to use the web search functionality in the OpenAIConnector transformer to automate web queries and retrieve relevant web content to generate summaries.
Getting Started with AI in FME: File Searching
Learn how to use the file search functionality in the OpenAIConnector transformer to summarize a financial report PDF and extract specific values such as quarterly revenue.
Using Generative AI for Geospatial Data Processing in FME (with 6 Examples)
Learn how to use the OpenAIChatGPTConnector to help with processing geospatial data.
Using the OpenAIImageGenerator
Learn how to use the OpenAIImageGenerator transformer. We will create an FME Workspace that generates images based on text data in an input file.
Webinars
Visit the FME webinar page to see upcoming and on-demand webinars hosted by Safe Software!
Peak of Data & AI Encore: AI for Metadata and Smarter Workflows [August 2025]
Join us to learn how to use AI to automatically generate metadata, identify inefficiencies, and apply intelligent design principles – so your FME workflows stay clean, scalable, and future-ready. See you there!
Peak of Data & AI Encore: AI-Enhanced Workflows for the Real World [July 2025]
By attending, you’ll get a high-level view of what’s possible when FME and AI come together – and how to begin applying it in your own work.
5 Things to Consider When Deploying AI in Your Enterprise [June 2025]
Join us as we break down five key considerations that will help you make smart, scalable decisions when bringing AI into your enterprise.
All-Data, Any-AI Integration: FME & Amazon Bedrock in the Real-World [April 2025]
Join us for an exclusive webinar featuring special guest speakers from Amazon, Amberside Energy, and Avineon-Tensing as we explore the power of Amazon Bedrock and FME in AI-driven geospatial workflows.
All-Data Any-AI Integration: Innovations with FME and Google [February 2025]
Come and see firsthand how Google combines its expertise in managing spatial data with the integration power of FME.
AI Agents Made Simple: Unleash the Power of All Your Data with Any AI [February 2025]
Learn to build agents that simplify complexity, boost efficiency, and deliver actionable insights – all in a no-code environment.
Moving Forward
Consider registering for our Getting Started with AI in FME training! The course will introduce a series of tutorials that build on each other, starting with connecting FME to AI services and progressing to key concepts like prompt engineering, file searching, classification, and reasoning.
This tutorial page will continue to grow as we publish new AI resources, webinars, and hub transformers. Bookmark it as your starting point for “Any AI with FME”.
