Comparison of Esri-Based Readers and Writers in FME
Liz Sanderson
Liz Sanderson
FME supports a number of Esri-based readers and writers. In order to utilize some formats within FME, it is necessary to have additional software installed and properly licensed on the same machine. Specifically, working with certain Esri formats requires the installation of a supported and licensed version of ArcGIS Pro, ArcGIS Enterprise, ArcGIS Server, or ArcMap. For more information on supported Esri versions, please see Notes on FME and Esri Versions and Compatibility.
ArcGIS Dependent Formats
These formats require a supported and licensed version of Esri ArcGIS Pro, ArcGIS Enterprise, ArcGIS Server, or ArcMap to be installed on the same machine as FME.
FME Format Name Short Name Comments
Esri ArcGIS Layer ARCGIS_LAYER_DATASET
Esri ArcGIS Map Document ARCGISMAP
Esri Knowledge ESRI_KNOWLEDGE_GRAPH
Esri Mobile Geodatabase ESRI_MOBILE_GEODATABASE
Esri Geodatabase (File Geodb) GEODATABASE_FILE
Esri Geodatabase (File Geodb Mosaic Dataset) GEODATABASE_FILE_MOSAIC_DATASET
Esri Geodatabase (File Geodb Raster Catalog) GEODATABASE_FILE_RASTER_CATALOG
Esri Geodatabase (File Geodb Raster Dataset) GEODATABASE_FILE_RASTER_DATASE
Esri Geodatabase (ArcSDE Geodb) GEODATABASE_SDE
Esri Geodatabase (ArcSDE Geodb Mosaic Dataset) GEODATABASE_SDE_MOSAIC_DATASET
Esri Geodatabase (ArcSDE Geodb Raster Catalog) GEODATABASE_SDE_RASTER_CATALOG
Esri Geodatabase (ArcSDE Geodb Raster Dataset) GEODATABASE_SDE_RASTER_DATASET
Esri Geodatabase (XML Workspace Document) GEODATABASE_XML
Non-ArcGIS Dependent Formats
These formats do not require an Esri ArcGIS product to be installed on the same machine as FME. However, they may have other dependencies, which are listed under Comments.
FME Format Short Name Comments
Esri-JSON (Esri JavaScript Object Notation) ESRIJSON
Esri .hrd RAW Raster ESRIHDR
Esri ArcGIS Binary Grid (AIG) ARCVIEWGRID
Esri ArcGIS Online (AGOL) Feature Service ARCGISONLINEFEATURES
Esri ArcGIS Portal Feature Service ARCGISPORTALFEATURES
Esri ArcGIS Server Feature Service ARCGISFEATURES
Esri ArcInfo Coverage ARCINFO
Esri ArcInfo Export (E00) E00
Esri ArcInfo Generate ARCGEN
Esri ArcPad Exchange Format (AXF) ARCPADAXF
  • Deprecated in FME 2022.0
Esri ASCII Grid ESRIASCIIGRID
Esri Geodatabase (OpenFile Geodb) OPENFILEGDB
  • Uses OpenFile Geodatabase GDAL driver
  • Does not require any Esri license or special installed libraries
  • Can read and write File Geodatabases to Windows, Linux, and Mac
  • See the Documentation for a list of what is supported.
Esri Geodatabase (File Geodb Open API) FILEGDB
Esri Geodatabase (Personal Geodb) PERSONAL_GEODATABASE
GEODATABASE_MDB (deprecated FME 2022.0)
  • Requires a Microsoft Access ODBC Driver
Esri Indexed 3D Scene Layer (I3S) I3S
Esri Mapping Specification for CAD (MSC) ESRIMSD
Additional Resources
