FME makes it easy to update your database, either through a single feature edit or bulk edits. Once published to FME Flow, FME Flow Apps allow you to share FME workflows with anyone, no FME Flow account is required. This enables users to easily make changes to the database, even when in the field. This tutorial covers three different databases: Oracle, Microsoft SQL Server, and PostGIS, and could be modified for other databases. For each database, two scenarios are demonstrated:
Bulk edits: This bulk insert is useful when you anticipate a large number of edits being made so that FME Flow does not get tied up with multiple calls. Instead, data is pushed to FME Flow in groups.
Single feature edits: Respond to single feature database edits and push features individually. This is good when you have a low volume of individual edits.
Requirements
Externally Accessible FME Flow
FME Workbench
Access to Oracle, Microsoft SQL Server, or PostGIS.
Articles
Bulk Edits:
Single Edits:
Single Edits PostGIS/PostgreSQL
Additional Resources
Data Attribution
The data shown here originates from open data made available by the City of Vancouver, British Columbia. It contains information licensed under the Open Government License - Vancouver.
