Legacy FME Technical Specifications
Liz Sanderson
Liz Sanderson
This article contains legacy support information for earlier versions of FME.
Current Version
For technical specifications of the current release, please view FME Platform Technical Specifications.
FME 2026.2 Platform Support
Operating Systems
Operating Systems FME Form FME Flow
Windows Operating Systems
Windows Server 2025 Production Recommended
Windows Server 2022 Production Production
Windows Server 2019 Production Production
Windows 11 Recommended Conditional Support
Windows 10* Not Supported Not Supported
Linux Operating Systems
Ubuntu 24.04 LTS Recommended Recommended
Ubuntu 22.04 LTS Production Production
Debian 13 Production Production
Debian 12 Production Production
RHEL 10 (EPEL 10) Production Production
Rocky / Oracle Linux 10 Production Production
RHEL 9 (EPEL 9) Production Production
Rocky / Oracle Linux 9 Production Production
Mac Operating Systems
macOS 26 Tahoe Recommended Not Supported
macOS 15 Sequoia Production Not Supported
macOS 14 Sonoma** Not Supported Not Supported
Containerization
Docker Not Supported Supported
Kubernetes Not Supported Supported
*Note that FME 2025.2 was the last version of FME to support Windows 10. Users on Windows 10 must upgrade to Windows 11 or a supported Windows Server edition before deploying this release.
**Note that FME 2025.2 was the last version of FME to support macOS 14 Sonoma. Users on macOS 14 Sonoma must upgrade to macOS 15 Sequoia or newer before deploying this release.
Virtualization
FME Flow should run on almost any virtualization provider's platform on any supported operating system. FME Form additionally requires GUI support (most leading vendors, such as AWS and DigitalOcean provide this, but a small number of other services may not).
Languages
Please note that in languages other than English, not all product components have been translated. In addition, non-English versions may have later release dates. The release dates and scope of translation vary based upon the provider – please contact them directly for full details.
Language FME Form
Provided by:
FME Flow
Provided by:
English Default language Default language
French Graphland
Veremes
Graphland
Veremes
German con terra con terra
Japanese Pacific Spatial Solutions N/A
Spanish con terra con terra
Safe Software also provides AI-powered translations in the form of Language Packs on our Downloads page. The languages currently supported by Safe Software for 2026.2 include: German, French, Hindi, and Dutch, with more language translations, such as Chinese, in progress for future releases.
Please contact Safe Support with any Language Pack inquiries.
FME 2026.1 Platform Support
Windows
FME 2026 Form and Flow can only be installed on 64-bit Windows. Please refer to this article for details on migrating to 64-bit FME.
Windows 11 Yes Yes
Windows 10* No No
Windows Server 2025 Yes Yes
Windows Server 2022 Yes Yes
Windows Server 2019 Yes Yes
*Note that FME 2025.2 was the last version of FME to support Windows 10. For FME 2026.1+, please use Windows 11 or newer.
Mac
Note: FME on macOS does not support case-sensitive file systems.
macOS 26 Tahoe  Yes No
macOS 15 Sequoia Yes  No
macOS 14 Sonoma* No No
*Note that FME 2025.2 was the last version of FME to support macOS 14 Sonoma. For FME 2026.1+, please use macOS 15 Sequoia or newer.
Linux
Ubuntu 24.04 LTS (Recommended distribution) Yes Yes
Ubuntu 22.04 LTS Yes Yes
Debian 13 Yes Yes
Debian 12 Yes Yes
Red Hat Enterprise Linux 10 (EPEL 10 repository required) Yes Yes
Rocky Linux 10 (EPEL 10 repository required)   Yes Yes
Oracle Linux 10 (EPEL 10 repository required)    Yes Yes
Red Hat Enterprise Linux 9 (EPEL 9 repository required) Yes Yes
Rocky Linux 9 (EPEL 9 repository required)   Yes Yes
Oracle Linux 9 (EPEL 9 repository required)     Yes Yes
Containerization
Container FME Form FME Flow
Docker No Yes
Kubernetes No Yes
Virtualization
FME 2025.x Platform Support
Windows
FME 2025 Form and Flow can only be installed on 64-bit Windows. Please refer to this article for details on migrating to 64-bit FME.
Windows 11 Yes Yes
Windows 10 Yes Yes
Windows Server 2025 (Beginning FME 2025.2*) Yes Yes
Windows Server 2016** No No
*Note that only FME 2025.2 has been tested on Windows Server 2025. For FME 2025.1 or older, Windows Server 2022 is recommended.
**Note that FME 2024.2 was the last version of FME to support Windows Server 2016. For FME 2025.0+, please use Windows Server 2019 or newer.
Mac
macOS 26 Tahoe (Beginning FME 2025.2*) Yes No
macOS 14 Sonoma Yes No
*Note that only FME 2025.2 has been tested on macOS 26 Tahoe. For FME 2025.1 or older, macOS 15 Sequoia or 14 Sonoma is recommended.
Linux
Debian 12 Yes Yes
Debian 11 No No
*Note that FME 2024.2 was the last version of FME to support Debian 11. For FME 2025.0+, please use Debian 12.
Containerization
Docker No Yes
Kubernetes No Yes
Virtualization
FME 2024.x Platform Support
Windows
FME 2024 Form and Flow can only be installed on 64-bit Windows. Please refer to this article for details on migrating to 64-bit FME.
Windows 11 Yes Yes
Windows 10 Yes Yes
Windows Server 2016 Yes Yes
*Note that FME 2024.2 will be the last version of FME to support Windows Server 2016. For FME 2025.0, please use Windows Server 2019 or newer.
Mac
macOS 15 Sequoia (Beginning FME 2024.2)* Yes  No
macOS 13 Ventura Yes No
*Note that only FME 2024.2 has been tested on macOS 15 Sequoia; for FME 2024.1 or older, macOS 14 Sonoma or macOS 13 Ventura is recommended.
Linux
Ubuntu 24.04 LTS (Recommended distribution beginning FME 2024.2) Yes Yes
Ubuntu 22.04 LTS (Recommended distribution until FME 2024.2)     Yes Yes
Debian 11 Yes Yes
Debian 12  Yes Yes
*Note that Ubuntu 20.04 LTS, Red Hat Enterprise Linux 8, Oracle Linux 8, and Rocky Linux 8 are no longer supported in FME 2024.0. Please use FME 2023.2 or older. If you have any questions or concerns, please contact Support.
**Note that FME 2024.2 will be the last version of FME to support Debian 11. For FME 2025.0, please use Debian 12.
Containerization
Docker No Yes
Kubernetes No Yes
Virtualization
FME 2023.x Platform Support
Windows
FME 2023 Form and Flow can only be installed on 64-bit Windows. For details on migrating to 64-bit FME please refer to this article.
Windows 11 Yes Yes
Windows 10 Yes Yes
Windows Server 2012 R2 No No
Note: Windows Server 2012 R2 is not supported for FME 2023. Please download FME 2022.2 if using Windows Server 2012.
Mac
macOS 12 Monterey Yes No
Linux
Ubuntu 20.04 LTS (Recommended distribution)     Yes Yes
Debian 11 Yes Yes
Red Hat Enterprise Linux 8 (EPEL 8 repository required) Yes Yes
Rocky Linux 8 (EPEL 8 repository required)   Yes Yes
Oracle Linux 8 (EPEL 8 repository required)     Yes Yes
*Note that Ubuntu 20.04 LTS, Red Hat Enterprise Linux 8, Oracle Linux 8, and Rocky Linux 8 will no longer be supported in FME 2024.0. If you have any questions or concerns, please contact Support.
Containerization
Docker No Yes
Kubernetes No Yes
Virtualization
FME Flow should run on almost any virtualization provider's platform on any supported operating system. FME Form additionally requires GUI support (most leading vendors such as AWS and DigitalOcean provide this, but a small number of other services may not).
FME Mobile
FME AR
Operating System App Version Requirements Devices
Android Version 1.5.0 Requires ARCore 7.0+ List of supported devices
Apple Version 2023.2 Requires iOS 16.1+ iPhone, iPad
FME Mobile
Android 2.4.0 Android 6.0+ Most smart devices
Apple 2.4.0 iOS 16.1+ iPhone, iPad
FME 2022.x Platform Support
Windows
FME 2022 Desktop and Server can only be installed on 64-bit Windows. For details on migrating to 64-bit FME please refer to this article.
Operating Systems FME Desktop FME Server
Windows 11 Yes Yes
Windows 10 Yes Yes
Windows Server 2012 R2 Yes Yes
Mac
macOS 11 Big Sur Yes No
Linux
Ubuntu 18.04 LTS Yes Yes
Debian 11 Yes Yes
Debian 10 Yes Yes
Red Hat Enterprise Linux 7 (EPEL 7 repository required) Yes Yes
CentOS 7 (EPEL 7 repository required) Yes Yes
Oracle Linux 7 (EPEL 7 repository required) Yes Yes
Containerization
Container FME Desktop FME Server
Docker No Yes
Kubernetes No Yes
Virtualization
FME Server should run on almost any virtualization provider's platform on any supported operating system. FME Desktop additionally requires GUI support (most leading vendors such as AWS and DigitalOcean provide this, but a small number of other services may not).
FME Mobile
FME AR
Android | Google Play Store
Android Version 1.4.0 Requires ARCore 7.0+ List of supported devices
Apple Version 1.8.0 Requires iOS 13.0+ iPhone, iPad, iPod Touch
FME Data Express
Android 2.3.0 Android 6.0+ Most smart devices
Apple 2.3.0 iOS 11.0+ iPhone, iPad, iPod Touch
FME 2021.x Platform Support
Windows®
  • Windows 10
  • Windows 11*
  • Windows Server 2019
  • Windows Server 2016
  • Windows Server Server 2012 R2
  • Windows Server 2022*
FME Desktop can be installed on 32-bit or 64-bit Windows. FME Server must be installed on 64-bit Windows. Refer to this FAQ for more details.
* Support added with FME 2021.2
Linux® x64
  • Ubuntu 18.04 LTS (Recommended Distribution)
  • Linux Mint 19
  • Debian 10
  • Red Hat Enterprise Linux 7 (EPEL 7 repository required)
  • CentOS 7 (EPEL 7 repository required)
  • Oracle Linux 7 (EPEL 7 repository required)
Mac Operating System (MacOS®) - Desktop
  • macOS 12 Monterey *
  • macOS 11 Big Sur
  • macOS 10.15 Catalina
(note: FME on OS X does not support case-sensitive filesystems)
Containerization
  • Docker
  • Kubernetes
Virtualization
FME Server should run on almost any virtualization provider's platform, on any supported operating system. FME Desktop additionally requires GUI support (most leading vendors such as AWS and DigitalOcean provide this, but a small number of other services may not).
Custom Installation of FME Server
The recommended installation option for FME Server is either Express or Distributed. If you need to perform a custom installation of FME Server, then you can learn more about the recommended web application servers, databases, and more in Planning an FME Server Installation.
Recommended Hardware Requirements
Pentium® 4, AMD Opteron or newer with 8GB or more of RAM and 20GB of available disk space (30 GB for FME Server). While FME products can operate on legacy hardware, additional memory, faster CPU and disk will significantly improve processing time.
You can easily scale FME Server's processing power by purchasing additional FME Engine licenses. For optimal performance, we recommend that each engine have a dedicated core. If you want to deploy FME Server without the constraints of hardware, learn more about FME Cloud.
FME 2020.x Platform Support
Windows®
  • Windows 10
  • Windows Server 2012, Server 2012 R2
Linux® x64
  • Linux Mint 19
  • Debian 10
  • Mac OS X v10.15 Catalina
  • Mac OS X v10.14 Mojave
Containerization
  • Docker
  • Kubernetes
Virtualization
FME 2019.x Platform Support
Windows®
  • Windows 10
  • Windows 8.1
  • Windows 7 (Intel Graphics Cards 3000, 4600 not supported)
  • Windows Server 2008 R2
Linux® x64
  • Ubuntu 18.04
  • Ubuntu 16.04 (Recommended Distribution)
  • Debian 9
  • Mac OS X v10.13 High Sierra
Containerization
  • Docker
Virtualization
The recommended installation option for FME Server is either Express or Distributed. If you need to perform a custom installation of FME Server, then you can learn more about the recommended web application servers, databases, and more in the FME Server Recommended Installation Scenarios.
Pentium® 4, AMD Opteron or newer with 8GB or more of RAM and 20GB of available disk space. While FME products can operate on legacy hardware, additional memory, faster CPU and disk will significantly improve processing time.
Previous Versions
For information regarding older versions of FME not listed in this article, please contact Support.
