Installing Multiple Versions of FME Form
Liz Sanderson
Liz Sanderson
Multiple versions of FME Form can be installed on the same machine. This can help you test a beta or work with workspaces from other versions. In older versions of FME, installing both 32-bit and 64-bit FME was also common.
Installing multiple versions of Form also makes it easy to keep a version that matches your Flow instance. Publishing a workspace from Form to Flow is only supported when the year and major version match and FME Form is the same as, or an older Build than, FME Flow. Generally, using the same build provides the best compatibility.
See FME Versions and Workspace Compatibility and Publishing to FME Flow for more details.
Backwards Compatibility
Safe Software works hard to maintain backward compatibility across FME versions. Please see FME Versions and Workspace Compatibility for more information on compatibility between versions.
However, if a license or library is no longer available, these features might not work in newer versions of FME. To see if a feature has been deprecated, please see FME Deprecations. If so, you can download past versions of FME from our website.
Please note that Safe Software does have a limited support window and cannot provide support for versions of FME outside of that window.
How to Install Multiple Versions
You can run the FME Form installer on a system where another FME version is already installed. The only requirement is that the alternate versions must reside in separate directories.
Another consideration is which version to associate with files. This will depend on your workflow, but generally, it is best to associate files with the most recent official release and the version that supports your most commonly used formats.
Windows
In Windows, during the installation process, on the Destination Folder step of the installation wizard, manually change the directory name from the default, which is \FME. As a best practice, add the full version or the build number. As an example: <installation location>\FME2024_0.
macOS
In macOS, the default directory is Major.Minor release, for example, FME 2022.2. If you want to install multiple builds of the same Major.Minor release, you will need to manually rename the already installed version in a Finder window under /Applications. As a best practice, change the folder's default name to include the build number. After renaming the existing installation, proceed with the new installation.
Considerations When Multiple Versions are Installed
Command Line Usage
Calling FME from the command line can be unreliable when multiple versions are installed. Keep the PATH environment variable limited to your primary FME installation, and specify the full FME executable path when possible. If multiple FME installations are in the system path, the first one will be used.
FME_HOME Setting
Unexpected results and crashes may occur if you run FME while the FME_HOME environment variable is pointing to the home directory of another version.
Custom Formats / Custom Transformers
Both versions will look in the C:\Users\<current user>\Documents\FME directory for Custom Formats and Transformers. However, this may cause problems if FME transformers used have changed between the two installed versions (or aren't available in the older one).
Changes made through Tools > FME Options > Shared Resources Directories apply to both 32- and 64-bit versions.
To make version-specific changes, you must use the following command line in the FME folder:
fme APPLY_SETTINGS SYSTEM <Shared Resource Directory>
This will differentiate between 32-bit and 64-bit, but not between 2020 and 2021, etc. Note that 32-bit FME has been deprecated as of 2022.0; see FME 32-bit Windows Support.
