Using Append to Write Big Data to ArcGIS Online in FME
Crystal Fitzpatrick
Crystal Fitzpatrick
As of FME 2024.0, support for Esri ArcGIS Online (AGOL), ArcGIS Enterprise Portal, and ArcGIS Server Feature Service formats has transitioned to a unified approach using the new Esri ArcGIS Feature Service (Format). This format replaces the legacy reader/writer formats for each of the three services.
Starting in FME 2026.3, the legacy formats will be hidden in the Quick Add menu. Instead, equivalent functionality is now provided by the downloadable Esri ArcGIS Connector package, available on FME Hub. The package also includes new web services and key transformers such as the ArcGISOnlineConnector, ArcGISAttachmentConnector, and ArcGISBranchVersionManager. The package can be installed directly through the Quick Add menu in FME Workbench. Once installed, the new Esri Feature Service format will appear in the Gallery as a unified method for interacting with all three types of Esri ArcGIS Feature Services.
For details on this transition, including guidance on updating existing workspaces, please refer to the article: Working with Esri ArcGIS Feature Services in FME.
In FME, you can connect to Esri ArcGIS Online in many ways, including readers, writers, and transformers, which the tutorial Getting Started with ArcGIS Online and Portal covers in detail. If you are updating data in ArcGIS Online, then the ArcGIS Online Feature Service Writer is your friend. But what about if you have tens or hundreds of thousands of records? Behind the scenes, the writer uses the ArcGIS REST API to add 1000 rows at a time, which can be a performance bottleneck.
In this article, we will walk through how to use the Esri Append REST API to connect to ArcGIS Online, which is useful for writing large datasets containing tens of thousands of records or more.
Append is a faster API but can be more complicated. It is best suited for regular ArcGIS Online updates where the number of rows is in the tens or hundreds of thousands. The principle of using Append is to:
  • Truncate existing data
  • Append data to a dataset from a table
Before we truncate, we also need to prepare our data:
  • Delete any old, uploaded data
  • Generate a zip file, then upload
This article has been updated for FME 2026.2 or later. If you are using an earlier version of FME, please use the attached workspace esri_truncate_append_rest_api_demo.fmwt.
About the Author
This is a guest article by Andrew Shakes (FME Certified Professional) of KiwiRail, New Zealand. KiwiRail maintains the New Zealand rail network and operates freight and scenic trains. KiwiRail uses train timetables in the Auckland and Wellington metro rail networks to manage track maintenance and upgrade projects. These normally forecast a few months ahead, but KiwiRail plans projects years in advance. KiwiRail uses FME to forecast timetables two years ahead, which creates many rows of data. ArcGIS Online is used to query and visualize the information, but train timetables change regularly, so they need to be updated.
Files
Additional files are available on the right-hand side of this article.
Step-by-Step Instructions
The FME workspace created in this example includes a few main parts: deleting outdated data in ArcGIS Online, generating and uploading a table, performing Truncate and Append operations, and monitoring the append using looping. Download the attached workspace template to follow along.
Part 1: Delete old uploaded data (if needed)​​​​​​​
Before uploading a file to ArcGIS Online, it pays to remove any copies you have previously uploaded to avoid duplication errors or making your administrator grumpy with lots of old, bulky zip file content. You can do this at the end of your update process, but it's good practice to run it at the beginning in case the Append process fails and prevents your clean-up process from running.
We will assume we have run the process before, so there’s an existing uploaded file we need to remove. This portion of the workspace looks like this and includes two ArcGISOnlineConnector transformers:
1. Create a Web Connection to ArcGIS Online
If you haven’t already done so, follow these steps to set up a Web Connection to ArcGIS Online.
Ensure the web connection you are using is authorized to delete content. This example opted for using an admin connection (with all the content owned by the admin) just to be sure.
2. Add a Creator
Add a Creator transformer to start off the workspace.
3. Add an ArcGISOnlineConnector
Add an ArcGISOnlineConnector. In the parameters,
  • ArcGIS Connection: <your connection>
  • Action: List
  • Content Source: User
  • User Content Folder: /AT_rail_services_demo
    • Click on the ellipsis and navigate to the folder you created
  • Include Subfolders: No
  • Attributes to Add:
    • _file_or_folder
    • _full_path
    • _id
    • _name
    • _private_url
4. Add a Tester
Add a Tester and connect it to the output port of the ArcGISOnlineConnector. The Tester checks whether the existing ArcGIS Online layer name (Title) matches the one you’re uploading (you may need to come back and set these parameters later).
  • Left Value: _name
  • Operator: =
  • Right Value: AT_predicted_services
5. Add a Second ArcGISOnlineConnector
Add a second ArcGISOnlineConnector, and connect it to the Passed port on the Tester. In the parameters:
  • Action: Delete
  • Path: _id
  • Delete Permanently: No
6. Add a FeatureJoiner
It's good practice to author your workspace to handle cases where no previous file exists. You can use a FeatureJoiner with a Left Join to ensure the process continues regardless, but delete the old copy if one exists.
Connect the output port of the second ArcGISOnlineConnector to the "Right" port, and the initiator port of the first ArcGISOnlineConnector to the "Left" port.
To clean up the workspace and fix the overlapping lines, right-click the Left input port of the FeatureJoiner and select 'Move Down'.
Set the parameters to:
  • Join Mode: Left
  • Join On:
    • Left: _creation_instance
    • Right: _creation_instance
7. Add an AttributeKeeper
Add an AttributeKeeper and connect it to the FeatureJoiner's Joined port.
  • Attributes to Keep: _creation_instance
This will clean up the workspace by keeping only the necessary attributes.
Part 2: Generate a table, then upload
Now that the workspace has deleted the old upload, it’s time to prepare and upload the new zip file.
In this example, a train timetable is processed from Auckland Transport’s open data GTFS to make it a bit easier to work with in ArcGIS Online – I’ve simplified this into a semicolon-delimited CSV file, which is attached to this article. There are over 300,000 rows when we predict 2 years ahead.
The Append REST documentation supports CSV uploads, but I prefer Esri’s File Geodatabase format because it handles schema mapping automatically, which can be tricky through the API.
1. Add a CSV Reader
Add a CSV reader, and read in the source CSV file attached to this article.
  • Format: CSV (Comma Separated Value)
  • Dataset: \AT_rail_services_demo.csv
2. Add a FeatureWriter
To write the rows read from the CSV to a file geodatabase, add a FeatureWriter.
  • Format: Esri Geodatabase (OpenFile Geodb)
  • Dataset: \GDB_AT_Timetable.gdb
  • Feature Class or Table Name: AGOL_AT_gtfs_uploads
  • Parameters:
    • Overwrite Existing Geodatabase: enabled
It’s good practice to enable 'Overwrite Existing Geodatabase’ in the feature writer parameters, so you are certain it isn’t uploading an old version of the data.
  • Make sure the schema of the feature type matches the ArcGIS Online layer
  • Make sure the geodatabase is zipped, and the geodatabase name matches the zip file name, so ArcGIS Online is happy to consume it
  • Give the feature type (GDB feature class) a different name from the layer name, so you don’t get it confused. I’ve called mine AT_predicted_services
Zip file name Geodatabase name Feature type Title (layer name)
GDB_AT_Timetable.zip GDB_AT_Timetable.gdb AGOL_AT_gtfs_uploads AT_predicted_services
This part of the workspace looks like this:
3. Add a FeatureMerger
Add a FeatureMerger, and connect the FeatureWriter to Requestor and the AttributeKeeper to Supplier.
In the parameters, set both the Requestor and Supplier to 1. This merges the output of the delete process with the output of the File Geodatabase writer so the upload will wait until both have finished.
4. Add an ArcGISOnlineConnector
Add a third ArcGISOnlineConnector and connect it to the Merged port of the FeatureMerger to upload the zip file.
  • Request:
    • Action: Upload
  • Data Source:
    • Upload: File
    • File to Upload: $(UploadGDB)
  • Metadata:
    • Title: AT_predicted_services
    • Item Type: File Geodatabase
    • Tags: BOL, AT
  • Content Destination:
    • If Item Exists: Reject
  • Output Attributes:
      • _id_private_url
Tips:
  • Upload a zipped File Geodatabase.
  • Create a specific folder in your ArcGIS Online Content for the zip file.
  • Go back to your first (deleted) ArcGISOnlineConnector to set the same folder.
  • While you are there, also check the Tester has the same name as the Title.
  • At least 1 tag is mandatory.
Part 3: Using the Esri Truncate and Append REST APIs
The Truncate REST API is much faster than using the ArcGIS Online Feature Service writer's delete feature operation. Like a database operation, it truncates all the records in the table instantly.
After truncating, we will append the table contents by calling the Append REST API. The Append operation should take less than a minute to append 300,000 rows.
1. Add an HTTPCaller
After the last ArcGISOnlineConnector, add an HTTPCaller and connect it to the Output port of the ArcGISOnlineConnector.
Configure it as follows to truncate the table.
Be careful to truncate the correct table. It uses an administration URL in ArcGIS Online – different from the portal URLs used for append, delete, or add features that you may be familiar with. You will need to use an admin connection to truncate.
If needed, check out the Esri Truncate documentation.
In the example, we use the same admin web connection, which lets us execute the Truncate API.
  • Request URL: <your organization URL>
  • HTTP Method: POST
  • Use Authentication: Enabled
  • Authentication Method: Web Connection
  • Web Connection: <your web connection>
  • Query String Parameters:
    • Name: t
    • Value: json
  • Body:
    • Upload Data: Specific Upload Body
Tips:
In this example, we’re truncating feature layer number 1 (it may be number 0 in yours).
2. Add a Second HTTPCaller
Add another HTTPCaller to call the Append REST API. Use the same parameters as the previous HTTPCaller, except update the Query String Parameters and the Request URL
Name Value
t json
appendItemId @value(id)
appendUploadFormat filegdb
layers 1
The append operation is actioned on the (parent) feature service, with the layer number specified in the ‘layers’ query string. In this example, it is layer number 1, but it is normally layer 0 if you have a single layer.
Part 4: Monitor the Append Operation
Configure the FME workspace to monitor the append operation to identify any issues. The final part of the workspace looks like this:
1. Add a JSONExtractor
Add a JSONExtractor and connect it to the HTTPCaller output port to retrieve the job URL for monitoring progress.
  • Input Source: JSON Document
  • JSON Document: _response_body
  • Extract Queries:
    • Target Attribute: jobURL
    • JSON Query: json["statusUrl"]
2. Create or Copy the Loop_checking_the_job_status loop Block from the esri truncate append rest api demo 2026.2+ workspace
This loop checks the status every second using an HTTPCaller. Don’t forget to set a time limit in the AttributeCreator.
The loop looks like this:
The HTTPCaller within the loop requests status updates from the job URL every second.
  • Request URL: @value(jobUrl)
  • HTTP Method: GET
    • Name: t
    • Value: json
  • Advanced:
    • Concurrent Requests: 1
Set the Concurrency/Looping Options to 1 Maximum Number of Concurrent HTTP Requests.
The JSONExtractor retrieves the appendstatus, then a Tester checks if the status is completed, failed, or the time limit is exceeded.
Logic Left Value Operator Right Value
  @Value(appendstatus) = Completed
OR @Value(appendstatus) = Failed
OR @Value(CurrentTime) >= @Value(TimeLimit)
Make sure you add +1 second before looping back. This is done in the ExpressionEvaluator.
Lastly, ensure that the Decelerator is connected to the Loop Output and that the ExpressionEvaluator is connected to the Loop Input.
3. Add a TestFilter
Add a TestFilter to check appendstatus for logging and, if needed, terminating the workspace. Connect it to the Tester's Passed port. Configure it as follows.
  Test Output Port
If @Value(appendstatus) = Completed Completed
Else If @Value(appendstatus) = Failed Failed
Else If @Value(appendstatus) = InProgress Time out
Else   <UNFILTERED>
4. Add a Logger and a Terminator
After the TestFilter "Completed" port, add a Logger to log that the workspace was successful. After the "Failed" and "Time out" ports, add a Terminator to stop the workspace and log that the workspace failed to append.
You are ready to run the workspace.
Data Attribution
The data used here originates from data made available by Auckland Transport. It contains information licensed under the Creative Commons License 4.0.
