Converting from CSV to Spatial Geometry (Vector)
Liz Sanderson
Liz Sanderson
Converting from CSV to vector features, points, lines, or polygons is easy in FME when the dataset includes spatial information like coordinates or addresses. This tutorial explores three methods to generate point features from CSV data:
  • Using the CSV Reader parameters
  • The VertexCreator transformer
  • Geocoding addresses
It also demonstrates how to construct line and polygon features using LineBuilder.
These techniques apply to any table-based dataset that includes spatial attributes.
Step-by-step Instructions
This tutorial is divided into three parts: point, line, and polygon features.
Part 1: Point Features
Method 1: Using the Reader Parameters
1. Add a CSV Reader
As of FME 2025.2, the Coordinate System parameter is now configured within the Parameters dialog of each reader/writer format. For more information, including details about the change and affected transformers, please see Coordinate System Parameter Location Change.
  • In a blank workspace, click the Add Reader icon and add a reader with the following parameters:
      • Format: CSV (Comma Separated Value)
      • Dataset: /rapid_transit_stations.csv
    Click the Parameters button to set the coordinate system:
      • Attribute Definition: Manual
      • Name: x
      • Type: x_coordinate
      • Name: y
      • Type: y_coordinate
      • Create Point Geometry from Attributes: Enabled
      • X Coordinate Attribute: x
      • Y Coordinate Attribute: y
      • Coordinate System: UTM83-10
    ReaderCSV
    Click OK to add the reader to the workspace.
    ReaderCSV
    If you open the reader parameters before clicking OK, under Attribute Definition, note that the x and y attributes have their types set to x_coordinate and y_coordinate automatically by FME. If these are not set correctly, switch the Attribute Definition to Manual, then manually change the Type.
    AttributeType
Method 2: Using the VertexCreator Transformer
1. Add a CSV Reader
In a blank workspace, add a reader to the canvas. In the Add Reader parameters:
  • Dataset: rapid_transit_stations.csv
Then click OK.
2. Add a VertexCreator
If the CSV was added without setting coordinate parameters, or if geometry was removed, use VertexCreator. Add a VertexCreator transformer and connect it to the CSV reader. In the parameters:
  • X Value: x
  • Y Value: y
Then click OK. Each row becomes a point feature with preserved attributes.
Method 3: Geocoding Addresses
1. Add a CSV Reader
For datasets without coordinates, use a geocoding service. Add a reader to the canvas and set the following:
  • Dataset: CulturalSpaces2016.csv
Then click OK.
2. Add a Geocoder
Next, add a Geocoder transformer. In the parameters:
  • Geocoding Service: Google
  • Connection:
    • Authorization Type: API Key
    • API Key: <your key>
  • Geocoding Parameters:
    • Mode: Forward
    • Street Address: ADDRESS
For more instructions on working with the Geocoder, see Geocoding Addresses.
Before running the workspace, right-click on the Geocoder and set Workspace: Rejected Feature Handling to Continue. This ensures the workspace runs even if some rows lack valid addresses. After running, point features will appear for all geocoded addresses.
Results
Part 2: Line Features
1. Add a CSV Reader
To convert CSV data into line features, add a reader to the workspace. In the Add Reader dialog, set:
  • Dataset: data_transit_lines.csv
Then click OK.
2. Add a LineBuilder
Connect a LineBuilder transformer to the reader feature type. In the parameters, set:
  • Group Processing: Enabled
    • Group By: LINE
Then click OK.
This groups points by their line name. If lines don’t appear as expected, sort the data first using a Sorter transformer.
Results
Part 3: Polygon Features
1. Add a CSV Reader
  • Converting CSV to polygons is similar to creating lines. Add a reader to the workspace. In the Add Reader dialog, set:
      • Dataset: /Neighborhoods.csv
      • Name: x
      • Name: y
      • Y Coordinate Attribute: x
      • Coordinate System: LL84
    ReaderCSV
    ReaderCSV
    • Group By: NeighborhoodName
Then click OK.
If the last point in each group matches the first, FME automatically forms a polygon.
Results
Data Attribution
