FME Flow Troubleshooting: Schedules
Liz Sanderson
Liz Sanderson
Full Guide: FME Flow Troubleshooting Guide
Are you encountering issues creating, editing, or running FME Flow Schedules? Please read below for some common troubleshooting tips, questions, and resources.
Content Overview
Initial Troubleshooting
  • The FME Flow Schedules will run as the user who last edited, regardless of the owner.
  • Make sure that any files or resources accessed by the scheduled workspace are visible to both the User in FME Flow and the account running the FME Flow Windows Services.
  • Log Files for FME Flow Schedules can be accessed in the web interface or FME Flow System Share location (specified at installation).
    • Via web interface: Resources > Logs > Core > current/old > fmescheduler.log
    • Example of default location: C:\ProgramData\Safe Software\FME Flow\resources\logs\core\current|old\fmescheudler.log
  • Check the log file to confirm that your schedule is executing correctly and to see if any errors are reported.
  • If you're having trouble with your CRON expression, please review the Writing CRON Expressions to Schedule FME Flow Jobs article for reference. It is recommended that you run your CRON expression through one of the online validators such as http://www.cronmaker.com or http://www.freeformatter.com to check if your expression is valid.
Common Issues
“My FME Flow Schedule does not respect Daylight Saving Time.”
This is a known issue if you have created a Schedule and configured it to ‘Repeat on Interval’. You may consider leveraging a CRON Expression instead.
“My schedules aren't running.”
Check that you have engines available to run the jobs.
Check the job history, running and queuing pages to check that the schedules are being ran successfully.
Is the schedule definitely enabled and configured correctly?
Check the log files to see if there are any errors.
“Schedules are running twice, but only one exists in the web interface.”
This is an uncommon issue that may occur in Active-Passive Failover FME Flow environments. An improper or incomplete failover operation may cause duplication of FME Flow Schedules. While uncommon, the common root cause is a very short network interruption that starts a failover operation but does not allow it to complete.
If you find yourself in this scenario, completely shut down FME Flow and systematically bring each component back online. In more rare cases, it might be necessary to manually remove records from the fme_schedule_task table in the backend database.
"I want to use the FME Flow REST API to enable a Schedule."
You can do so by using an HTTPCaller transformer to enable and disable an existing schedule. Please see the answer on this Community Post for an example.
As of FME Flow 2025.1, the V3 REST API has been deprecated. The current API will remain accessible, but no new features or general bug fixes will be implemented. Starting with FME Flow 2026.1, the V3 API will be removed. We encourage all users to prepare their systems for this change.
The V4 REST API offers enhanced security and usability, including new and reorganized endpoints, as well as the removal of certain endpoints. For information on migrating from V3 to V4, please see the FME Flow REST API V4 documentation and click on the heading Migrating from REST API V4.
"I only want to schedule a workspace to run on weekdays only."
Please see this Community Post for a solution.
Are you still experiencing issues?
Please consider posting to the FME Community Q&A if you are still experiencing issues that are not addressed in this article. There are also different support channels available.
Have ideas on how to improve this?
You can add ideas or product suggestions to our Ideas Exchange.
