FME Flow Troubleshooting: Projects
Liz Sanderson
Liz Sanderson
Full Guide: FME Flow Troubleshooting Guide
Are you encountering issues with FME Flow (formerly FME Server) Projects? Please read below for some common troubleshooting tips, questions, and resources.
In 2023, FME Server was renamed to FME Flow. Since this article discusses features present in previous versions of FME, it will refer to both names interchangeably, using the appropriate product name based on the year the feature was introduced. For more information on the rebranding, see our website.
Content Overview
Initial Troubleshooting
  • Does the FME Flow User have proper permissions to access and create FME Flow Projects? And permissions for applicable components – for example, Repositories, Resources, Web Connections?
  • Try restarting FME Flow.
  • If a Project contains API tokens, one of the following must be true to import:
    • The user belongs to the fmesuperuser group
    • The project owner conducting the import has the same user account on the target system.
  • In FME 2022.1, if a user has different roles/permissions across two machines and they create a Project with Workspace Apps, the imported Workspace Apps will be disabled as tokens are removed. After importing Workspace Apps, resave the Workspace App to generate a new token, which will enable it.
Common Issues
“Why can’t I add users to my FME Flow Project?”
To add users to any FME Flow Project, you must be a member of the fmesuperuser role. Please see the documentation for more information.
"How can I maintain the "shared with" users for my Project from one environment to another?"
When a Project with shared users is exported from one environment and imported into another, the Project must be shared again.
Are you still experiencing issues?
Please consider posting to the FME Community Forums if you are still experiencing issues that are not addressed in this article. There are also different support channels available.
Have ideas on how to improve this?
You can add ideas or product suggestions to our Ideas Exchange.
