This article provides a comprehensive list of officially released FME versions, including their build numbers, release dates, supported Python versions, and support expiration dates. If you're looking for the latest release, you can find it in the downloads section of our website. Older installers are also available for reference.
FME is supported for three years from the date of the major release. For more information, please see the Support Policy.
FME Versions
Not all builds listed below will be available on safe.com/downloads. Patch builds are fully compatible with previous builds but include important fixes. We typically remove previous builds from the downloads page to ensure customers always use the most stable version. If you need a specific build, please contact us.
Linux and Python:
FME supports a range of Python versions and will automatically use the highest version available on the system. Since different Linux distributions ship with different default Python versions, the version FME uses will vary depending on your OS. For example, Ubuntu 22.04 ships with Python 3.10 as its highest natively available version, so FME will default to Python 3.10 on that platform. If you need to leverage features from a newer Python version, you'll need to manually install it or use a custom interpreter.
Safe Software provides technical support for each FME Platform version for three years from its public release date (the “Support End Date”). Support applies to technical issues only.
Product fixes and security updates are generally released in the latest version and may require an upgrade, or are provided in other versions in accordance with Safe Software's Product Support Policy.
Versions past their Support End Date are retired and no longer supported.
| Version | Date (yyyy-mm-dd) | Build | Comments | Technical Support End Date | Shipped Python Version | Supported Python Version |
| 2026.3.1.1 | 2026-10-30 | 26670 | Canadian Timezone hotfix | September 15, 2029 |
Windows: 3.14.6 macOS: 3.14.6 |
Windows: 3.10-3.14 macOS: 3.14 Linux: 3.10-3.14 (Dependent on OS Python) |
| 2026.3.1 | 2026-10-14 | 26656 | ||||
| 2026.3 | 2026-09-15 | 26589 | Official FME 2026.3 Release | |||
| 2026.2.1 | 2026-08-11 | 26345 | June 22, 2029 |
Windows: 3.10-3.14 macOS: 3.14 Linux: 3.10-3.13 (Dependent on OS Python) |
| 2026.2 | 2026-06-22 | 26333 | Official FME 2026.2 Release |
Windows: 3.14.5 macOS: 3.14.5 |
| 2026.1.2 | 2026-05-19 | 26124 | March 17, 2029 |
Windows: 3.14.2 macOS: 3.14.3 |
| 2026.1.1 | 2026-04-21 | 26121 | ||||
| 2026.1 | 2026-03-17 | 26103 | Official FME 2026.1 Release | |||
| 2025.2.4.1 | 2026-04-16 | 25836 | November 25, 2028 |
Windows: 3.13.11 macOS: 3.13.5 |
Windows: 3.9-3.13 macOS: 3.13 Linux: 3.9-3.12 (Dependent on OS Python) |
| 2025.2.4 | 2026-03-03 | 25835 | ||||
| 2025.2.3 | 2026-02-04 | 25831 | ||||
| 2025.2.2 | 2026-01-14 | 25827 |
| 2025.2.1 | 2025-12-09 | 25815 |
Windows: 3.13.10 macOS: 3.13.5 |
| 2025.2 | 2025-11-25 | 25810 | Official FME 2025.2 Release |
Windows: 3.13.5 macOS: 3.13.5 |
| 2025.1.3.3 | 2025-11-06 | 25648 | July 8th, 2028 | |||
| 2025.1.3.2 | 2025-10-30 | 25646 | ||||
| 2025.1.3.1 | 2025-10-23 | 25645 | ||||
| 2025.1.3 | 2025-10-07 | 25643 | ||||
| 2025.1.2 | 2025-09-04 | 25630 | ||||
| 2025.1.1 | 2025-08-06 | 25615 | ||||
| 2025.1.0.1 | 2025-07-15 | 25609 |
Windows: 3.13.5 macOS: 3.13.2 |
| 2025.1 | 2025-07-08 | 25606 | Official FME 2025.1 Release | |||
| 2025.0.3 | 2025-06-05 | 25241 | March 4th, 2028 |
Windows: 3.13.2 macOS: 3.13.2 |
| 2025.0.2 | 2025-05-20 | 25237 | ||||
| 2025.0.1 | 2025-04-02 | 25220 |
Windows: 3.13.1 macOS: 3.13.1 |
| 2025.0 | 2025-03-04 | 25208 | Official FME 2025.0 Release | |||
| 2024.2.5 | 2025-05-13 | 24832 | November 5th, 2027 |
Windows: 3.12.6 macOS: 3.12.6 |
Windows: 3.8-3.12 macOS: 3.12 Linux: 3.8-3.12 (Dependent on OS Python) |
| 2024.2.4 | 2025-03-26 | 24831 | ||||
| 2024.2.3 | 2025-02-06 | 24825 | ||||
| 2024.2.2 | 2025-01-16 | 24820 | ||||
| 2024.2.1 | 2024-12-05 | 24801 | ||||
| 2024.2 | 2024-11-05 | 24783 | Official FME 2024.2 Release | |||
| 2024.1.4.0 | 2024-12-06 | 24630 | July 2nd, 2027 |
Windows: 3.12.4 macOS: 3.12.4 |
| 2024.1.3 | 2024-10-02 | 24627 | ||||
| 2024.1.2.1 | 2024-09-11 | 24624 | ||||
| 2024.1.2 | 2024-09-04 | 24622 | ||||
| 2024.1.1.1 | 2024-08-23 | 24620 | ||||
| 2024.1.1 | 2024-08-07 | 24619 | ||||
| 2024.1 | 2024-07-02 | 24612 | Official FME 2024.1 Release | |||
| 2024.0.5 | 2024-11-29 | 24224 | March 5th, 2027 |
Windows: 3.12.2 macOS: 3.12.2 |
| 2024.0.4 | 2024-07-30 | 24221 | ||||
| 2024.0.3 | 2024-06-04 | 24220 | ||||
| 2024.0.2.2 | 2024-05-24 | 24219 | ||||
| 2024.0.2.1 | 2024-05-14 | 24217 | ||||
| 2024.0.1 | 2024-04-04 | 24202 | ||||
| 2024.0 | 2024-03-05 | 24187 | Official FME 2024.0 Release | |||
| 2023.2.6 | 2025-01-08 | 23790 | December 5th, 2026 |
Windows: 3.11.6 macOS: 3.11.2 |
Windows: 3.7-3.11 macOS: 3.11 Linux: 3.6-3.11 (Dependent on OS Python) |
| 2023.2.5 | 2024-11-29 | 23788 | ||||
| 2023.2.4 | 2024-05-24 | 23785 | ||||
| 2023.2.3 | 2024-03-18 | 23783 | ||||
| 2023.2.2 | 2024-03-05 | 23781 | ||||
| 2023.2.1 | 2024-01-09 | 23774 | ||||
| 2023.2 | 2023-12-05 | 23764 | Official FME 2023.2 Release | |||
| 2023.1.2 | 2023-11-16 | 23641 |
Retired August 29th 2026 |
Windows: 3.11.4 macOS: 3.11.2 |
| 2023.1.1.1 | 2023-10-13 | 23636 | ||||
| 2023.1.1 | 2023-10-03 | 23631 | ||||
| 2023.1 | 2023-08-29 | 23619 | Official FME 2023.1 Release | |||
| 2023.0.2 | 2023-08-02 | 23338 |
Retired June 15th, 2026 |
| 2023.0.1 | 2023-07-05 | 23332 | ||||
| 2023.0.0.3 | 2023-06-15 | 23319 | Official FME 2023.0 Release |
Windows: 3.11.3 macOS: 3.11.2 |
| 2022.2.8 | 2023-08-25 | 22802 |
Retired November 8th, 2025 |
Windows: 3.10.9 macOS: 3.10.6 |
Windows: 3.6-3.10 macOS: 3.10 Linux: 3.6-3.10 (Dependent on OS Python) |
| 2022.2.7 | 2023-07-04 | 22801 | ||||
| 2022.2.6 | 2023-05-24 | 22800 | ||||
| 2022.2.5 | 2023-04-04 | 22795 | ||||
| 2022.2.4 | 2023-03-07 | 22792 | ||||
| 2022.2.3 | 2023-02-07 | 22789 | ||||
| 2022.2.2 | 2023-01-10 | 22782 |
Windows: 3.10.8 macOS: 3.10.6 |
| 2022.2.1 | 2022-12-06 | 22776 | ||||
| 2022.2 | 2022-11-08 | 22765 | Official FME 2022.2 Release | |||
| 2022.1.3 | 2022-10-04 | 22630 |
Retired July 6th, 2025 |
Windows: 3.9.13 macOS: 3.9.13 |
Windows: 3.6-3.9 macOS: 3.9 Linux: 3.6-3.9 (Dependent on OS Python) |
| 2022.1.2 | 2022-09-07 | 22627 | ||||
| 2022.1.1 | 2022-08-02 | 22623 |
Windows: 3.9.13 macOS: 3.9.9 |
| 2022.1 | 2022-07-06 | 22618 | Official FME 2022.1 Release | |||
| 2022.0.1.1 | 2022-06-21 | 22350 |
Retired May 3rd, 2025 |
Windows: 3.9.7 macOS: 3.9.9 |
| 2022.0.1 | 2022-06-08 | 22346 | ||||
| 2022.0.0.2 | 2022-05-24 | 22343 | ||||
| 2022.0.0.1 | 2022-05-10 | 22339 | ||||
| 2022.0 | 2022-05-03 | 22337 | Official FME 2022.0 Release | |||
| 2021.2.6 | 2022-08-02 | 21821 | FME 2021.2.x final update Last build to support 32-bit Windows and Python 2.7 as optional component |
Retired November 2nd, 2024 |
Windows: 3.8.9, 2.7.18 macOS: 3.8.9 |
Windows: 2.7, 3.6-3.8 macOS: 2.7, 3.8 Linux: 2.7, 3.6-3.8 (Dependent on OS Python) |
| 2021.2.5 | 2022-04-05 | 21816 | ||||
| 2021.2.4 | 2022-03-10 | 21814 | ||||
| 2021.2.3 | 2022-02-02 | 21812 | ||||
| 2021.2.2 | 2022-01-12 | 21806 | ||||
| 2021.2.1 | 2021-12-07 | 21797 | ||||
| 2021.2.01 | 2021-11-17 | 21789 | ||||
| 2021.2 | 2021-11-02 | 21784 | Official FME 2021.2 Release | |||
| 2021.1.3.1 | 2021-11-02 | 21635 |
Retired July 6th, 2024 |
| 2021.1.3 | 2021-10-05 | 21631 | ||||
| 2021.1.2 | 2021-09-08 | 21627 | ||||
| 2021.1.1 | 2021-08-03 | 21619 | ||||
| 2021.1.0.1 | 2021-07-21 | 21614 | ||||
| 2021.1 | 2021-07-06 | 21607 | Official FME 2021.1 Release | |||
| 2021.0.3.2 | 2021-07-22 | 21332 |
Retired March 9th, 2024 |
| 2021.0.3.1 | 2021-07-07 | 21330 | ||||
| 2021.0.3 | 2021-06-01 | 21326 | ||||
| 2021.0.2 | 2021-05-04 | 21321 | ||||
| 2021.0.1 | 2021-04-07 | 21313 |
Windows: 3.8.7, 2.7.18 macOS: 3.8.7 |
| 2021.0.0.1 | 2021-03-17 | 21306 | ||||
| 2021.0 | 2021-03-09 | 21302 | Official FME 2021.0 Release | |||
| 2020.2.5.1 | 2021-07-22 | 20828 |
Retired October 29th, 2023 |
Windows: 3.7.9, 2.7.18 macOS: 3.7.9 |
Windows: 2.7, 3.5-3.7 macOS: 2.7, 3.7 Linux: 2.7, 3.5-3.8 (Dependent on OS Python) |
| 2020.2.5 | 2021-05-11 | 20827 | *Last macOS update | |||
| 2020.2.4 | 2021-03-09 | 20825 | ||||
| 2020.2.3 | 2020-02-02 | 20820 | ||||
| 2020.2.2 | 2021-01-12 | 20817 | ||||
| 2020.2.1 | 2020-12-01 | 20806 | ||||
| 2020.2 | 2020-10-29 | 20787 | ||||
| 2020.1.3 | 2020-10-06 | 20632 |
Retired July 8th, 2023 |
Windows: 3.7.7, 2.7.18 macOS: 3.7.7 |
| 2020.1.2.1 | 2020-09-15 | 20624 | ||||
| 2020.1.2 | 2020-09-04 | 20620 | ||||
| 2020.1.1.1 | 2020-08-19 | 20614 | ||||
| 2020.1.1 | 2020-08-04 | 20608 | ||||
| 2020.1.0.1 | 2020-07-14 | 20596 | ||||
| 2020.1 | 2020-07-08 | 20594 | ||||
| 2020.0.3 | 2020-06-09 | 20252 |
Retired May 10th, 2023 |
Windows: 3.7.5, 2.7.17 macOS: 3.7.5 |
Windows: 2.7, 3.5-3.7 macOS: 2.7, 3.7 Linux: 2.7, 3.5-3.7 (Dependent on OS Python) |
| 2020.0.2.1 | 2020-05-13 | 20238 | ||||
| 2020.0.2 | 2020-05-05 | 20232 | ||||
| 2020.0.1 | 2020-04-09 | 20218 | ||||
| 2020.0.0.1 | 2020-03-18 | 20202 | ||||
| 2020.0 | 2020-03-10 | 20200 | ||||
| 2019.2.3.2 | 2020-03-24 | 19825 | FME 2019.2.x final update |
Retired November 7th, 2022 |
Windows: 3.7.1, 2.7.15 macOS: 3.7.1 |
| 2019.2.3.1 | 2020-02-18 | 19823 | ||||
| 2019.2.3 | 2020-02-04 | 19822 | ||||
| 2019.2.2 | 2020-01-07 | 19817 | ||||
| 2019.2.1 | 2019-12-03 | 19813 | ||||
| 2019.2 | 2019-11-07 | 19801 | ||||
| 2019.1.3.1 | 2019-10-21 | 19643 | Required 2019.0/1.x update for FME Server |
Retired July 11th, 2022 |
| 2019.1.3 | 2019-10-08 | 19642 | ||||
| 2019.1.2 | 2019-09-03 | 19630 | ||||
| 2019.1.1 | 2019-08-06 | 19617 | ||||
| 2019.1 | 2019-07-11 | 19608 | ||||
| 2019.0.2.2 | 2019-07-11 | 19264 | FME 2019.0.x final update |
Retired April 2nd, 2022 |
| 2019.0.2 | 2019-06-07 | 19260 | ||||
| 2019.0.1 | 2019-05-07 | 19253 | ||||
| 2019.0.0.1 | 2019-04-17 | 19246 | ||||
| 2019.0 | 2019-04-02 | 19238 | First build of FME for macOS with a shipped Python interpreter. | |||
| 2018.1.2.1 | 2019-04-02 | 18592 | Last build to install Python 2.7 by default on Windows |
Retired July 18th, 2021 |
Windows: 2.7.14, 3.6.2 |
Windows: 2.7, 3.4-3.6 macOS: 2.7, 3.4-3.6 Linux: 2.7, 3.4-3.6 (Dependent on OS Python) |
| 2018.1.2 | 2019-03-05 | 18590 | ||||
| 2018.1.1.2 | 2019-01-23 | 18586 | ||||
| 2018.1.1.1 | 2018-12-05 | 18578 | ||||
| 2018.1.1 | 2018-11-09 | 18567 | ||||
| 2018.1.0.3 | 2018-09-28 | 18552 | ||||
| 2018.1.0.2 | 2018-09-05 | 18547 | ||||
| 2018.1.0.1 | 2018-08-01 | 18528 | ||||
| 2018.1 | 2018-07-18 | 18520 | ||||
| 2018.0.1.1 | 2018-06-19 | 18312 |
Retired May 12th, 2021 |
| 2018.0.1 | 2018-05-23 | 18310 | ||||
| 2018.0.0.3 | 2018-05-01 | 18305 | ||||
| 2018.0.0.2 | 2018-04-17 | 18301 | ||||
| 2018.0.0.1 | 2018-03-29 | 18295 | ||||
| 2018.0 | 2018-03-12 | 18284 | ||||
| 2017.1.2.1 | 2018-01-23 | 17725 |
Retired August 1st, 2020 |
| 2017.1.2 | 2017-12-15 | 17722 | ||||
| 2017.1.1.1 | 2017-10-19 | 17652 | Windows: 2.7.10, 3.6.2 |
Windows: 2.7, 3.4-3.5 macOS: 2.7, 3.4-3.5 Linux: 2.7, 3.4-3.5 (Dependent on OS Python) |
| 2017.1.1 | 2017-10-03 | 17650 | ||||
| 2017.1 | 2017-08-01 | 17539 | ||||
| 2017.0.1.2 | 2017-06-25 | 17292 | Linux-only update |
Retired May 1st, 2020 |
| 2017.0.1.1 | 2017-05-17 | 17291 | ||||
| 2017.0.1 | 2017-05-02 | 17288 | ||||
| 2017.0.0.2 | 2017-04-03 | 17280 | ||||
| 2017.0.0.1 | 2017-03-17 | 17271 | ||||
| 2017.0 | 2017-03-01 | 17259 | First build of FME for Windows with shipped Python 3 interpreter. | |||
| 2016.1.3.3 | 2017-06-25 | 16718 | Linux-only update |
Retired April 20th, 2019 |
Windows: 2.7.10 |
Windows: 2.7, 3.4 macOS: 2.7, 3.4 Linux: 2.7, 3.4 (Dependent on OS Python) |
| 2016.1.3.2 | 2017-02-16 | 16717 | ||||
| 2016.1.3.1 | 2016-12-09 | 16716 | ||||
| 2016.1.3 | 2016-11-08 | 16709 | ||||
| 2016.1.2.1 | 2016-09-30 | 16674 | Installer update for Linux Server | |||
| 2016.1.2 | 2016-09-22 | 16673 | ||||
| 2016.1.1 | 2016-07-28 | 16609 | ||||
| 2016.1.0.1 | 2016-05-20 | 16494 | ||||
| 2016.1 | 2016-04-20 | 16492 | ||||
| 2016.0.1.2 | 2016-03-19 | 16178 | FME 2016.0. final update |
Retired January 19th, 2019 |
| 2016.0.1.1 | 2016-02-25 | 16177 | ||||
| 2016.0.1 | 2016-02-02 | 16174 | Server release | |||
| 2016.0 | 2016-01-19 | 16167 | Desktop release | |||
| 2015.1.3.2 | 2016-01-19 | 15575 | FME 2015.1 final update |
Retired January 15th, 2018 |
Windows: 2.3-2.7 macOS: 2.7 Linux: 2.7 (Dependent on OS Python) |
| 2015.1.3.1 | 2015-11-18 | 15573 | ||||
| 2015.1.3 | 2015-11-10 | 15570 | ||||
| 2015.1.2.1 | 2015-09-25 | 15539 | ||||
| 2015.1.2 | 2015-09-15 | 15538 | ||||
| 2015.1.1 | 2015-07-21 | 15515 | ||||
| 2015.1.0.3 | 2015-06-30 | 15485 | FME 2015.1.0 final update | Windows: 2.7.8 | ||
| 2015.1.0.2 | 2015-05-28 | 15482 | ||||
| 2015.1.0.1 | 2015-05-12 | 15480 | ||||
| 2015.1.0 | 2015-04-28 | 15479 | ||||
| 2015.0 | 2015-02-18 | 15253 | FME 2015.0 final update | Retired January 15th, 2018 | ||
| 2015.0 | 2015-01-26 | 15250 | FME 2015.0 Server release | |||
| 2015.0 | 2015-01-15 | 15244 | FME 2015.0 Desktop release | |||
| 2014 SP5 | 2014-12-12 | 14440 | FME 2014.x final update | Retired February 13th, 2017 | Please contact Safe Support | |
| 2014 SP4 | 2014-10-08 | 14433 | (14431 for Mac OSX) | |||
| 2014 SP3 | 2014-08-13 | 14391 | ||||
| 2014 SP2 | 2014-06-09 | 14339 | ||||
| 2014 SP1 | 2014-04-08 | 14289 - 14290 | ||||
| 2014 | 2014-02-13 | 14235 | FME 2014 combined release | |||
| 2013 SP4 | 2013-10-26 | 13547 | FME 2013.x final update | Retired January 11th, 2016 | ||
| 2013 SP3 | 2013-07-29 | 13528 | ||||
| 2013 SP2 | 2013-06-05 | 13499 | ||||
| 2013 SP1 | 2013-03-20 | 13448 - 13450 | ||||
| 2013 | 2013-01-11 | 13262 - 13264 | FME 2013 combined release | |||
| 2012 SP4 | 2012-09-28 | 12266 | FME 2012.x final update | Retired January 15th, 2015 | ||
| 2012 SP3 | 2012-07-18 | 12258 | ||||
| 2012 SP2 | 2012-04-11 | 12235 - 12238 | ||||
| 2012 SP1 | 2012-02-17 | 12224 | ||||
| 2012 | 2012-01-15 | 12212 | FME 2012 combined release | |||
| 2011 SP4 | 2011-08-31 | 6538 | Retired January 11th, 2014 | |||
| 2011 SP3 | 2011-06-30 | 6529 | ||||
| 2011 SP2 | 2011-05-19 | 6523 | ||||
| 2011 SP1 | 2011-03-03 | 6512 | ||||
| 2011 | 2011-01-11 | 6501 | FME 2011 combined release | |||
| 2010 SP4 | 2010-11-18 | 6235 | Retired January 12th, 2013 | |||
| 2010 SP3 | 2010-09-28 | 6231 | ||||
| 2010 SP2 | 2010-06-29 | 6225 | ||||
| 2010 SP1 | 2010-04-27 | 6216 | ||||
| 2010 | 2010-01-12 | 6198 - 6200 | FME 2010 combined release | |||
| 2009 | 2009-01-02 | 5658 | FME Desktop release (see table below for Server) | Retired January 2nd, 2012 | ||
| 2008 | 2008-04-08 | 5197 - 5206 | FME Desktop release (see table below for Server) | Retired April 8th, 2011 | ||
| 2007 | 2007-06-06 | 4392 - 4398 | FME Desktop release (see table below for Server) | Retired June 6th, 2010 | ||
| 2006 GB | 2006-06-28 | 2651 | Build 2692 was uploaded for ArcGIS 9.2 compatibility | Retired January 12th, 2009 | ||
| 2006 | 2006-01-12 | 2182 | ||||
| 2005 | 2005-06 | 1696 - 1702 | Retired June 1st, 2008 | |||
| 2004 ICE3 | 2004-11 | 1378 | Retired November 1st, 2007 | |||
| 2004 ICE | 2004-05 | 1314 - 1321 | ||||
| 2004 | 2003-11 | 1166 | ||||
| 2003 X2 | 2003-04 | 1024 | Retired | |||
| 2003 | 2002-11 | 894 - 896 | 894/5 were patchable to 896 | |||
| 2002 SR1 | 2002-04 | 628 | ||||
| 2002 | 2001-08 | 519 | ||||
| 2000 SR1 | 2000-09 | 444 | ||||
| 2000 | 2000-04 | 422 | ||||
| 2.3a | 1999-11 | 381 | ||||
| 2.3 | 1999-05 | 327 | ||||
| 2.2 | 1998-10 | 279 | ||||
| 2.1 | 1998-03 | 248 | ||||
| 2.0 | 1997-07 | 221 | ||||
| 1.47 | 1996-11 | 147 | ||||
FME Server (prior to FME 2010)
Note: From FME 2010, FME Server builds match FME Desktop builds.
| Version | Engine Build | Server Build | Comments |
| 2009 | 5656 | 5915 | FME Server 2009 |
| 2008 | 5209 | 5719 | FME Server 2008 |
| 2007 | 4392 | SpatialDirect 2007 |
Related Info
- Information on FME Versions and Workspace Compatibility
