Brotli Decoder (CVE-2026-111497): Is FME Impacted?
Liz Sanderson
Liz Sanderson
Safe Software is aware of the vulnerability known as CVE-2026-111497 impacting the Brotli decoder in Google Brotli versions 1.0.3 through 1.2.0. The vulnerability is an out-of-bounds write that can be triggered when a vulnerable decoder processes a crafted Brotli-compressed stream. It has been rated Critical (CVSS 4.0 score 9.2) by Google, the issuing CNA, and public proof-of-concept exploits are available. Google has published fixed versions 1.0.10, 1.1.1, and 1.2.1.
This vulnerability was first widely reported through the Node.js project, and is sometimes described as a Node.js vulnerability. FME products do not ship Node.js. The October 2026 Node.js security releases are covered in a separate article: Node.js Vulnerabilities (October 2026): Is FME Impacted?
This article provides an overview of our analysis of this vulnerability and our mitigation advice for users. We will update this article as we learn more.
Impact Summary
Application Affected Version(s) Platform Remediation Workaround
FME Engine FME 2024.2 through FME 2026.3 Windows, macOS, Linux
Updated builds of FME 2026.1, 2026.2, and 2026.3 are in progress.
A patch for DuckDB reading is pending a vendor fix.
See FME Form / FME Flow sections
FME Form FME 2024.2 through FME 2026.3.
Affected directly (FME Workbench) and through the included FME Engine.
Windows, macOS, Linux Same fix as FME Engine: updated builds of FME 2026.1, 2026.2, and 2026.3 See FME Form section
FME Flow
FME 2024.2 through FME 2026.3 affected through inclusion of FME Engine.
Windows, Linux  See FME Engine See FME Flow section
FME Flow Hosted FME 2024.2 through FME 2026.3 affected through inclusion of FME Engine. Linux
OS package: installed automatically via Ubuntu security updates; restart FME Flow or reboot to apply.
A patch for DuckDB reading is pending a vendor fix and will be incorporated into FME 2026.1, 2026.2, and 2026.3
See FME Flow Hosted section
FME Realize or Deprecated FME Mobile Applications Not affected in FME code; relies on the device OS Brotli decoder (see below) — None required None required
FME Form
Impact
FME Form is affected in two ways. FME Workbench links the vulnerable Brotli library directly through its HTTP client, and FME Form also includes FME Engine, which uses the same library. On Windows and macOS, FME 2024.2 through FME 2026.4 bundle Brotli 1.1.0. On Linux, FME uses the Brotli library provided by the operating system, except for the DuckDB library, which bundles its own copy.
FME Workbench is affected on its own, without a workspace running, because its HTTP client decodes Brotli-encoded responses. A malicious or compromised server could use such a response to crash the FME Workbench process, disclose process memory, or potentially execute arbitrary code. Two features are exposed:
  • The transformer request preview for the HTTPCaller and OpenAPICaller transformers fetches the URL entered by the user. A malicious or compromised endpoint that returns a Brotli-encoded response can trigger the vulnerability.
  • Creating or refreshing web connections that use OAuth 2.0 or token-based authentication request access tokens through the affected HTTP client.
FME Engine is affected while it runs a workspace. An attacker who can supply a crafted Brotli-compressed stream to a workspace through any of the following paths could crash the FME Engine process, disclose process memory, or potentially execute arbitrary code:
  • HTTP requests made from a workspace through FME's libcurl-based HTTP client, including the HTTPCaller and OpenAPICaller transformers, when a remote server returns a Brotli-encoded (Content-Encoding: br) response.
  • Refreshing web connections that use OAuth 2.0 or token-based authentication request access tokens through the affected HTTP client.
  • The DuckDB reader and writer, which bundle their own copy of Brotli
  • The Parquet format, when reading Parquet files with Brotli-compressed columns
Remediation
Safe Software is preparing updated builds of FME 2026.1, FME 2026.2 and FME 2026.3 that upgrade the shared Brotli library to 1.2.1. Customers on earlier releases should plan to upgrade to one of these releases once available. The DuckDB library bundles its own copy of Brotli. The DuckDB project has merged a fix, but has not yet published a release that contains it. We will update this article when a fixed DuckDB release is available and included in FME.
On Linux, FME Engine uses the operating system's Brotli library for its HTTP client and the Parquet format. Ensure the operating system's Brotli package is updated to 1.0.10, 1.1.1, or 1.2.1 or later through your distribution's package manager. This does not cover the DuckDB library, which bundles its own copy of Brotli and requires the FME update.
Workaround
Until a fixed version of FME is available, we recommend limiting FME's exposure to untrusted Brotli-compressed data:
  • Only use the HTTPCaller transformer against trusted endpoints.
  • Only create web connections to services you trust.
  • Only read Parquet and DuckDB data from trusted sources.
  • Where possible, use a proxy or firewall to block Brotli-encoded responses to FME hosts.
  • In FME Workbench, avoid using the transformer request preview against URLs you do not trust.
  • Only connect FME AI Assist to AI and MCP servers that you trust.
FME Flow
Impact
FME Flow includes FME Engine, so the impact described above for FME Form applies to the FME Engines running under FME Flow. On Windows, FME Flow's engines use the bundled Brotli 1.1.0; on Linux, they use the operating system's Brotli library.
The FME Flow web application and its services do not ship Node.js, and FME Flow's own code does not use Brotli. FME Flow is affected only through the FME Engines it runs, so the FME Engine fix also resolves the issue for FME Flow.
Because FME Flow runs workspaces submitted by users and on schedules, the practical risk depends on whether those workspaces fetch data from untrusted endpoints or read untrusted Parquet or DuckDB data. An FME Flow instance reachable only from an internal network is protected from external attackers, but a workspace that reaches out to an attacker-controlled server can still trigger the vulnerability.
Remediation
The FME Engine fix applies to FME Flow through its engines. Updated builds of FME Flow 2026.1, 2026.2, and 2026.3 will include the fix.
On Linux, FME Engine uses the operating system's Brotli library for its HTTP client and the Parquet format. Ensure the operating system's Brotli package is updated to 1.0.10, 1.1.1, or 1.2.1 or later. This does not cover the DuckDB library, which bundles its own copy of Brotli and requires the FME update.
Workaround
The FME Form workarounds apply to workspaces run on FME Flow. In addition:
  • Review scheduled and automation-triggered workspaces that use HTTPCaller or read Parquet or DuckDB data from external sources.
  • Where possible, use an outbound proxy or firewall to block Brotli-encoded responses to FME Flow engine hosts.
FME Flow Hosted
Impact
FME Flow Hosted instances run FME Flow on Ubuntu Linux and are affected through the FME Engines they run. On Linux, FME Engine uses the operating system’s Brotli package for its HTTP client and the Parquet format, so exposure through those paths depends on whether the instance has installed Ubuntu’s security update for Brotli: base images ship the unpatched package, and running instances install security updates automatically. The DuckDB library bundles its own copy of Brotli, so every FME Flow Hosted instance is affected through DuckDB until the FME Engine update is applied.
Remediation
Two updates are needed: one for the operating system’s Brotli package and one for the copy bundled with DuckDB.
Operating system: Ubuntu’s fixed Brotli package is installed automatically on FME Flow Hosted instances through security updates. Restart FME Flow or reboot the instance after the update to apply it. Instances running an end-of-life Ubuntu release (earlier than 22.04) do not receive the fix and should be upgraded to a supported release.
DuckDB: the DuckDB fix is being backported to FME 2026.1, 2026.2 and 2026.3, pending a fixed DuckDB release.
Workaround
Until the DuckDB fix is applied, follow the FME Flow workarounds above, in particular, only reading DuckDB data from trusted sources. Restarting FME Flow after the Ubuntu security update closes the HTTP client and Parquet paths without waiting for the FME update.
FME AR or Deprecated FME Mobile Applications
Impact
FME AR does not include FME Engine, and none of its code or dependencies bundle Brotli. The app makes HTTP requests through the operating system's networking (URLSession on iOS), which has its own Brotli decoder maintained by Apple. Apple has not yet published a statement on CVE-2026-111497. Keep your device's operating system up to date.
Remediation
None required.
Workaround
None required.
FAQ
Is FME affected by the October 2026 Node.js security releases?
No. FME Form, FME Engine, and FME Flow do not ship Node.js. CVE-2026-111497 was first widely reported through Node.js, but it is a vulnerability in the Brotli library, which Node.js bundles. FME is affected through its own copy of Brotli in FME Engine, not through Node.js. The Node.js security releases are addressed in a separate article: Node.js Vulnerabilities (October 2026): Is FME Impacted?
I found Node.js-related files in the FME Python folder. Is that Node.js?
No. FME ships the Python package dukpy in FME_HOME/python/python3XX/dukpy/. dukpy embeds Duktape, a small JavaScript interpreter, and includes shims that imitate a few Node.js APIs. It is not Node.js and does not include the Node.js runtime.
My FME Flow is only accessible on an internal network. Am I safe?
An internally accessible FME Flow is protected from attackers outside your network. However, a workspace that calls out to an external server (for example, with HTTPCaller) or reads external Parquet or DuckDB data can still receive a crafted Brotli stream. We recommend applying the workarounds above until a fixed version is available.
Does updating my operating system's Brotli package fix FME?
On Linux, partly. FME Engine uses the operating system's Brotli library for its HTTP client and the Parquet format, so updating the operating system's Brotli package to 1.0.10, 1.1.1, or 1.2.1 or later closes those paths. The DuckDB library bundles its own copy of Brotli and is not fixed by the operating system update; an FME update is required for it. On Windows and macOS, no: FME Engine bundles its own copy of Brotli, so an FME update is required.
How can I be notified of security updates in the future?
If you would like to be notified of security updates from Safe Software, we encourage you to subscribe to our Security Updates email list by signing up via the form on our Security page.
Reporting Security Issues
If you believe you have discovered a vulnerability in the FME Platform, our website, or our other products, please email us as quickly as possible at security at safe dot com.
We greatly appreciate the efforts of security researchers and discoverers who share information on security issues with us, giving us a chance to improve our products and better protect our users.
Please note that we do not compensate individuals or organizations for identifying potential or confirmed security vulnerabilities.
Support
If you have questions or concerns regarding this advisory, please raise a support request. You can view all of our security notices on our Security Center.
