eMudhra intermediate CA compromise (CVE-2026-91403): Is FME Impacted?
Liz Sanderson
Liz Sanderson
Status
Affected
Fixed releases are available.
Last Updated November 25th, 2026
Safe Software is aware of the vulnerability known as the eMudhra intermediate CA compromise (CVE-2026-91403), which impacts any software that maintains its own list of trusted certificate authorities, including the Java runtime and the Python libraries that FME ships.
On October 17, 2026, a security researcher reported that the private keys of eight eMudhra intermediate certificate authority certificates (six for TLS and two for code signing) can be derived from the certificates themselves, as documented in Mozilla's incident report. Anyone holding one of those keys can issue a certificate for any hostname, and a client that still trusts the issuing chain and does not check revocation or Certificate Transparency will accept it.
On October 18, eMudhra revoked the certificates, and Google, Mozilla, Apple, and Microsoft have blocked them in their products.
On October 21, Oracle published CVE-2026-91403 for the Java runtime, which distrusts the compromised intermediates.
On October 24, Oracle published a follow-up alert, CVE-2026-114820, updating Java to remove the impacted eMudhra root certificates. Other components have their own identifiers for the same trust-store update (CVE-2026-111943 for Go, which vulnerability scanners also use as an umbrella ID for bundled trust stores, and GHSA-6q48-6c7w-9gw2 for the Python certifi package), so a scanner may report FME under more than one ID.
This is not a defect in FME code, and it applies whether or not your organization uses eMudhra certificates. What matters is which certificate authorities FME trusts when it connects to other systems. Until each trust store distrusts the compromised intermediates, that component may accept a fraudulent certificate from an attacker positioned on the network between FME and a server it connects to. Exploitation requires that network position. Revocation alone does not protect these components, because the Java runtime and the other clients listed below do not check revocation. Safe Software has no evidence of exploitation against FME.
Our investigation has confirmed that FME Engine, FME Form, FME Flow, and FME Flow Hosted are affected.
This article provides an overview of our analysis of this vulnerability and our mitigation advice for users. We will continuously update this article as we have new information to share. Fixed releases are now available; see FME Security Update November 2026, Update 2 for the full set of security fixes they include.
Summary Table
Application Affected Version(s)* Platform Remediation Workaround
FME Engine 2024.2 through 2026.3, and the 2026.4 beta. Which components are affected depends on the platform and release (see below). Windows, macOS, Linux
Upgrade to:
  • 2026.1.2.2 (build 26192)
  • 2026.2.1.3 (build 26426)
  • 2026.3.2.0 (build 26682)
Above available now at safe.com/downloads or the official 2026.4 release in December
Keep the operating system trust store current; platform-specific steps below.
No workaround for Apache Iceberg reading from Google Cloud Storage.
FME Form 2024.2 through 2026.3, and the 2026.4 beta. Confirmed on macOS; Windows and Linux follow the operating system trust store. Windows, macOS, Linux Same releases as FME Engine
Keep the operating system and its certificate bundle current
Use FME Form on trusted networks
FME Flow 2024.2 through 2026.3, and the 2026.4 beta (all releases, Windows, Linux and Docker) Windows, Linux, Docker Same releases as FME Engine. Fixes ship as new installers; there is no in-place patch.
Block the compromised intermediates in both Java keystores; steps below.
Update the Docker image
FME Flow Hosted All running instances (the FME Flow software on each instance). Safe-operated platform services are not affected. Hosted Launch a new instance on a fixed release from the FME Flow Hosted console, then migrate.
Safe has already updated the operating system trust store on supported instances
Keep Verify SSL Certificate set to Yes until migrated to a fixed build
FME AR or Deprecated FME Mobile Applications
FME AR / Realize (iOS, visionOS) 2026.1 through 2026.3: not affected in FME code; relies on the Apple system trust store.
Deprecated/Unsupported:
  • FME AR for Android 1.5.0: not affected.
  • FME Express / FME Mobile 2.4.1 (iOS): expected to be protected by Apple's block
  • FME Express / FME Mobile 2.4.1 (Android): affected.
iOS, visionOS, Android
Update FME Realize and keep iOS/visionOS current.
Discontinue the following deprecated and unsupported apps:
  • FME AR on Android
FME AR / Realize: Do not approve certificate warnings in releases before 2026.4.
FME Express / FME Mobile: None; discontinue use.
*Please note, only versions between 2024.2 and 2026.4 were assessed per our Product Support Policy. Versions older than 2024.2 were not assessed and should be assumed affected; review the remediation and workaround steps for each product below.
FME Flow Hosted (formerly FME Cloud) instances are affected. FME Flow Hosted runs the same FME Flow software on Safe-managed infrastructure, so the Java runtime and Python trust stores on each running instance accept the compromised chains. Safe has updated the operating system trust store on supported instances and confirmed that the Safe-operated services (FME Account, FME Hub, FME AI Service and the FME Flow Hosted web application) are not affected. Because the FME Flow software on an existing instance cannot be patched in place, the fix is a new instance on a fixed release. See the FME Flow Hosted section below.
FME Engine
Impact
FME Engine is the processing component in both FME Form and FME Flow. It makes outbound TLS connections through several independent stacks, each with its own trust store, so results depend on the component, the platform, and the release. Safe Software tested each component against the test hosts on the disclosure site. None of these components check certificate revocation or Certificate Transparency, so revoking the certificates did not protect them.
Component Windows macOS Linux
Java-based formats and connectors (Snowflake, Databricks, SQL Server (JDBC), Microsoft Fabric Warehouse, Azure Synapse, Amazon DynamoDB, Apache Iceberg and other JDBC formats)
2024.2: Affected (bundled Java keystore).
2025.0 and later: Uses the Windows certificate store, so affected unless the emSign ECC Root CA - G3 root has been removed from it (see Workaround).
Affected in every release (bundled Java keystore). Uses the Java runtime installed on the system. Protected once the operating system certificate bundle is updated and the Java keystore is regenerated (see Workaround).
Apache Iceberg reading from Google Cloud Storage (gs://), 2026.3 and later Affected Affected
Affected.
The Google Cloud Storage library brings its own trust store, which overrides both the Java and the operating system stores, so operating system and Java updates do not help.
Python: your own code (PythonCaller, startup and shutdown scripts, scripted parameters) and Safe Software packages that rely on the bundled certifi certificate bundle (the AWS-based packages such as Amazon S3, SQS, Athena, Amazon AI, Databricks, Cesium ion, STAC and the AWS satellite imagery formats; Kafka; MCPCaller; the Azure packages; WebSocket; WebODM) Affected Affected Affected on RHEL 9 (FME ships certifi there). Other distributions use the distribution's certifi package, so they are protected once that package is updated.
Python: Google AI and Google Cloud Pub/Sub packages (bundled grpcio) Affected Affected Affected
Python: most other Safe-authored formats and connectors (they use FME's request session) Not affected (uses the Windows certificate store; verified against all test hosts) Affected Affected on RHEL; other distributions protected once the distribution's certifi package is updated.
HTTPCaller, web connections, OpenAPICaller and the other non-Java, non-Python formats (libcurl HTTP stack) Not affected (Windows SChannel rejects the compromised chains)
2024.2 and 2025.0: Not affected
2025.1 and later: Affected (FME imports the keychain roots into OpenSSL, which does not apply Apple's blocks).
Uses the operating system certificate bundle. Protected once that bundle is updated.
Remediation
The following fixes are included in FME 2026.1.2.2 (build 26192), 2026.2.1.3 (build 26426) and 2026.3.2.0 (build 26682), released on November 19, 2026, and will be included in FME 2026.4.0 (December 2026).
  • The bundled Java runtime (Windows and macOS) is upgraded to Eclipse Temurin 21.0.13+9, which no longer trusts the roots the compromised chains lead to.
  • The bundled certifi certificate bundle is updated to 2026.10.23 or later, and the grpcio library used by the Google packages is updated.
  • Apache Iceberg's Google Cloud Storage connector is changed to use the Java trust store instead of its own.
  • The libcurl HTTP stack (OpenSSL backend on macOS and Linux) rejects any certificate chain that includes one of the compromised intermediates, whatever the operating system trust store contains.
FME releases before 2026.1 (2024.2, 2025.0, 2025.1 and 2025.2) will not receive these fixes. Users of those releases should upgrade to a fixed release and can apply the workarounds below in the meantime.
Workaround
For all systems
Keep the operating system and its certificate bundle up to date on every machine that runs FME.
Java formats
Windows (FME 2025.0 and later) (tested by Safe)
Remove the emSign ECC Root CA - G3 root from the Windows certificate store. From an administrator command prompt, run:
certutil -delstore AuthRoot 3043fa4ff257dca0c380ee2e58ea78b23fe6bbc1
Linux (Debian and Ubuntu) (tested by Safe)
Update the ca-certificates package, then regenerate the Java keystore:
sudo rm /etc/ssl/certs/java/cacerts && sudo update-ca-certificates --fresh
Update the distribution's Python certifi package at the same time.
macOS (all releases) and Windows 2024.2 (not tested by Safe)
Use Java's keytool to remove the emSign roots from the keystore bundled with FME (<FME>/jre/lib/security/cacerts). Reinstalling or upgrading FME undoes this change.
Other components
Component Workaround
Python code and packages that use the bundled certifi (Windows, macOS, RHEL) No tested workaround
Apache Iceberg reading from Google Cloud Storage No workaround. Run these workspaces only on trusted networks until the fix is installed.
Verifying a component
To check a component, connect to both of these URLs from it:
You can use an HTTPCaller, a PythonCaller, or a workspace that uses a JDBC format.
Expected result: Both connections fail with a certificate error.
If a connection succeeds: That component still trusts the compromised chains.
Test each component separately. A passing HTTPCaller test says nothing about Java or Python.
FME Form
Impact
FME Form has no TLS stack of its own. Its connections go through Qt and through FME Engine's HTTP library (libcurl), and both follow the operating system's or the distribution's trust store. FME Form does not check Certificate Transparency, and certificate revocation checking is disabled. FME Form therefore accepts the forged chains wherever its platform's trust store still accepts them. Releases 2024.2 through 2026.3 share this behavior.
  • macOS: Affected (confirmed by testing). Since FME 2025.1, the HTTP library validates certificates with OpenSSL using roots exported from the keychain, which does not apply Apple's blocks.
  • Windows: Connections validated by Windows (SChannel) reject the compromised chains, so FME Form on Windows is expected to be protected. This is predicted from the source code and has not yet been confirmed on a shipping build.
  • Linux: Follows the distribution's certificate bundle; protected once that bundle is updated.
Where a platform is affected, the exposed connections are:
  • FME Account sign-in and AI Assist (account and AI service tokens)
  • Web connections, including OAuth 2.0 token exchange and refresh and the FME Flow token used for publishing
  • The request preview in HTTPCaller and OpenAPICaller
  • FME Hub browsing and package installation. Hub packages and the AI Assist plugin are installed without a signature check, so a forged Hub response on an affected platform could lead to code execution on the user's machine.
Remediation
In FME 2026.1.2.2, 2026.2.1.3 and 2026.3.2.0, released on November 19, 2026, and in FME 2026.4.0 (December 2026), FME Form and the Engine HTTP library refuse any server whose certificate chain contains one of the compromised eMudhra intermediates, independent of the operating system trust store, and the certificate-validation defect in the OpenAPI specification fetch is fixed. Signing of FME Hub packages and pinning of Safe-operated endpoints are being pursued as longer-term hardening.
Workaround
For all systems
Mark the compromised certificates as untrusted
Administrators can mark the emSign roots and the eight compromised intermediates as untrusted in the operating system certificate store, for example:
  • The Untrusted Certificates store on Windows
  • Keychain Access on macOS
The intermediates are listed in impacted-intermediates.json on the disclosure site.
Limit exposure until a fix is installed
Use FME Form and install FME Hub packages only on networks you trust until you install a fixed release.
Verifying the HTTP path
Check the HTTP path with an HTTPCaller against the two test hosts, as described under FME Engine.
FME Flow
Impact
Safe has confirmed that FME Flow is exploitable in every release from 2024.2 through 2026.3, and in the 2026.4 beta, on Windows, Linux and Docker. FME Flow has several independent trust stores:
Core and Web Application Server Java runtime
What it's used for: Outbound connections made by the Core, including:
  • LDAPS and SMTP
  • Webhooks
  • Identity providers and OAuth
  • Flow-to-Flow and remote engine connections
  • Cloud storage
  • FME Hub
What's affected:
  • All releases: The keystore trusts the emSign ECC Root CA - G3 root.
  • 2024.2 through 2025.1: The keystore also accepts the chain cross-signed by Sectigo's AAA Certificate Services.
Engine Java runtime and Python environment
Locations:
  • Windows: <FMEFlowDir>/Server/fme/jre
  • Linux: The Java installation on the host
The Engine Java runtime is a second keystore in the FME Flow install. The Engine Python environment is separate from it. Jobs use both, and both are affected as described under FME Engine.
Docker
The core and web containers use the Java runtime from the base image, not the one bundled with the installer. That runtime is affected.
The operating system store inside the images also accepted the compromised chains at the time of testing.
Your FME Flow HTTPS certificate
Your own FME Flow HTTPS certificate is not affected unless it was issued by one of the eight revoked intermediates.
Why this is unlikely: eMudhra has stated that only one of the eight was ever deployed, and that none issued an end-entity certificate.
How to check: Compare the issuer in your certificate chain with the eight names in impacted-intermediates.json on the disclosure site.
If there's a match: The certificate is revoked and must be reissued by your certificate authority. Browsers would already be rejecting it.
Related issue: unverified outbound requests
This issue is separate from the emSign vulnerability.
FME Flow releases before 2026.4 do not verify the server certificate on some outbound requests. Updating the trust store does not protect those requests.
Fix: FME 2026.4 verifies certificates on outbound requests. This change is also being included in the fixed 2026.1, 2026.2, and 2026.3 releases.
Remediation
These releases update the bundled Java runtime to Eclipse Temurin, which no longer trusts the emSign roots.
FME Flow release Release date Java runtime
2026.1.2.2 November 19, 2026 Eclipse Temurin 17.0.21+9
2026.2.1.3 November 19, 2026 Eclipse Temurin 17.0.21+9
2026.3.2.0 November 19, 2026 Eclipse Temurin 21.0.13+9
2026.4.0 December 2026 Eclipse Temurin 21.0.13+9
If a platform build isn't available yet: Where a platform build of the updated runtime is not yet available, the release instead blocks the compromised intermediates in the runtime's blocked.certs file.
Docker: The Docker images are rebuilt on updated base images.
How to Install the Fix
The fixes are delivered as new installers only, available from the Downloads page.
  1. Install the fixed release on every machine that runs part of FME Flow, including distributed engine hosts and Remote Engines Service hosts.
  2. Migrate your configuration on the main FME Flow installation.
  3. Reinstall the other hosts at the same release.
Until then, apply the workaround below on each of them.
FME Flow releases before 2026.1 will not receive the fix. Use the workaround below and plan an upgrade.
Default behavior change after upgrading
After upgrading, FME Flow verifies TLS certificates on outbound requests. Deployments that use any of the following may need to add that certificate authority to the Java trust store:
  • Self-signed certificates
  • An internal certificate authority
  • A TLS-inspecting proxy
For details, see Default Behavior Changes in FME Security Update November 2026, Update 2.
Workaround
This workaround blocks the compromised certificates in both Java keystores without removing any root. It has been tested by Safe.
 Do not remove the AAA Certificate Services root from any keystore. Many legitimate Sectigo-issued certificates chain to it.
Block the compromised certificates
1. Download the fingerprint list
Get impacted-intermediates.json from the disclosure site. It lists 16 SHA-256 fingerprints: the eight compromised intermediates and their eight Sectigo cross-signed variants.
2. Update the Core Java runtime
Append the 16 fingerprints to blocked.certs, following the format of the entries already in the file:
<FMEFlowDir>/Utilities/jre/lib/security/blocked.certs
3. Update the Engine Java runtime
  • Windows: Append the same 16 fingerprints to:
    <FMEFlowDir>/Server/fme/jre/lib/security/blocked.certs
  • Linux: The engine uses the Java installation on the host. Update the host's certificate bundle and regenerate its Java keystore instead (see FME Engine, Workaround).
4. Restart FME Flow
After an upgrade, repeat the steps above after any FME Flow upgrade. An upgrade replaces the Java runtime and removes the edit.
Docker
You cannot make edits inside the published images. Update to a fixed image from the Downloads page.
Additional hardening
  • Set Verify SSL Certificate to Yes on webhooks and connections wherever the option exists.
  • Where possible, limit FME Flow's outbound connections to trusted networks and destinations until a fixed release is installed.
Verifying the workaround
Core runtime
  1. Trigger a connection from FME Flow with certificate verification enabled. For example, use a webhook with Verify SSL Certificate set to Yes.
  2. Point it at each of these URLs:
    • https://dv-g3b-emudhra.we-have-a-problem.com/
    • https://dv-g3b-aaa-emudhra.we-have-a-problem.com/
If either connects: The runtime is still exposed.
Engine runtime
The Core check does not exercise the Engine runtime. To test it, run a workspace that uses a JDBC format against the same two hosts.
FME Flow Hosted
Impact
FME Flow Hosted instances run the same FME Flow software as the self-hosted product. The Core Java runtime, the Engine Java runtime and the Engine Python trust stores on every running instance therefore accept the compromised chains, as described under FME Flow.
Actions Safe has taken
Operating system trust store
The operating system trust store has been updated through the daily unattended security updates on instances running a supported operating system (Ubuntu 22.04 and later). New instances receive the update at launch.
  • Protected: Connections that use the operating system store, such as HTTPCaller.
  • Not protected: The Java runtime and Python.
  • Older operating system versions: These instances do not receive the updates.
The following services have been updated and verified against the test hosts. They are not affected:
  • FME Account
  • FME Hub
  • FME AI Service
  • FME Flow Hosted web application
HTTPS certificates
The following do not chain to any eMudhra certificate authority:
  • FME Flow Hosted instances: DigiCert
  • Load balancers: Amazon
Remediation
The FME Flow software on an existing instance cannot be patched in place. You need to launch a new instance on a fixed release and move to it.
New builds are available from the FME Flow Hosted console:
  • FME Flow 2026.1.2.2
  • FME Flow 2026.2.1.3
  • FME Flow 2026.3.2.0
How to migrate
  1. Launch a new instance on a fixed release from the FME Flow Hosted console.
  2. Migrate your configuration and jobs by exporting them from the old instance and importing them into the new one.
  3. Decommission the old instance.
Older operating systems
Instances running an operating system older than Ubuntu 22.04 should be migrated as well. They do not receive the operating system trust store updates described above.
Workaround
Keep Verify SSL Certificate set to Yes on webhooks and connections, and where possible limit outbound connections to trusted destinations, until your instance has been migrated to a fixed build.
FME Realize/AR or Deprecated FME Mobile Applications
Impact
FME AR does not include FME Engine or Java.
FME AR
FME Realize (iOS and visionOS)
FME Realize uses the Apple system trust store. Apple delivers its eMudhra block without an OS update, so Apple's block should apply.
Not affected. This version has no TLS client or HTTP code.
FME Express / FME Mobile 2.4.1 (deprecated)
Android
Affected. The app trusts only the system certificate store. Exploiting this would require both a derived key and a network position.
iOS
Expected to be protected by Apple's block.
Remediation
FME Realize
Update to the latest version and keep devices on the latest iOS or visionOS.
Discontinue use. These apps are deprecated and unsupported, and no fix will be released
Workaround
FME Realize
None. Discontinue use.
FAQ
Which FME versions will receive a fix?
Under our Product Support Policy, fixes have been delivered as new releases for FME 2026.1, 2026.2, and 2026.3. They were released on November 19, 2026, and are available from the Downloads page.
FME release Fixed version Build
2026.1 2026.1.2.2 26192
2026.2 2026.2.1.3 26426
2026.3 2026.3.2.0 26682
The fixes will also be included in FME 2026.4.0 (December 2026).
No fix: FME 2024.2, 2025.0, 2025.1, and 2025.2 will not receive a fix. Users of those releases should upgrade.
Will there be a patch I can apply without reinstalling?
No. The fixes for this issue are delivered as new installers for each release line. Upgrading FME Flow means installing the new release and migrating your configuration.
You can apply the workarounds in this article to any release until the upgrade is complete. These releases also contain the other fixes described in FME Security Update November 2026, Update 2.
My vulnerability scanner reports FME against CVE-2026-91403, CVE-2026-114820, CVE-2026-111943 or GHSA-6q48-6c7w-9gw2. Are these different issues?
No. They all relate to the same incident and the same trust-store update. They are tracked under different identifiers in different components:
Identifier Applies to
CVE-2026-91403 Java runtime
CVE-2026-114820 Java runtime
CVE-2026-111943 Go (scanners also use it as a general ID for bundled trust stores)
GHSA-6q48-6c7w-9gw2 Python certifi package
All of them are covered by this article.
I use an eMudhra certificate to secure FME Flow. Do I need to do anything?
See the note under FME Flow, Impact. Your certificate remains valid unless its issuer is one of the eight revoked intermediates. In that case, your certificate authority must reissue it.
The trust-store updates in this article are needed regardless of which certificate authority issued your own certificate.
Has this vulnerability been exploited against FME?
Safe Software has no evidence of exploitation against FME or against FME Flow Hosted.
Exploitation requires an attacker positioned on the network between FME and the server it connects to.
What changed since the previous version of this article?
The initial post of October 28, 2026 reported that the investigation was in progress. This update records the outcome of that investigation for each product, the fixed releases now available, and the tested workarounds.
Will I be notified when new releases are available?
Everyone is welcome to join our mailing list to be notified of new releases available by signing up via the form on our Downloads page.
How can I be notified of security updates in the future?
If you would like to be notified of security updates from Safe Software, we encourage you to subscribe to our Security Updates email list by signing up via the form on our Security page.
Reporting Security Issues
If you believe you have discovered a vulnerability in the FME Platform, our website, or our other products, please email us as quickly as possible at security at safe dot com.
We greatly appreciate the efforts of security researchers and discoverers who share information on security issues with us, giving us a chance to improve our products and better protect our users.
Please note that we do not compensate individuals or organizations for identifying potential or confirmed security vulnerabilities.
Support
If you have questions or concerns regarding this advisory, please raise a support request. You can view our security notices on our Security Center.
