Known Issues and Considerations: Behavior Changes After November 2026 FME Security Updates & Hardening
Liz Sanderson
Liz Sanderson
Feature Various
Product
FME Form
FME Flow
Description As a result of security changes introduced in FME 2026.2 and backported to specified earlier versions, the ability to specify some TCL and FME Functions in parameter and attribute values has been disabled in the fixed versions and instances that have been patched according to the instructions in the advisory. After upgrading or patching, some transformers and advanced scripting features, unlikely to be used by the majority of workspaces, may be impacted.
Workarounds Various - See articles below
Affects
FME Form versions:
  • 2026.3+
  • 2026.2, 2026.2.1
  • 2026.1.0.1, 2026.1.1.1, 2026.1.2.1
  • 2025.2.0.1, 2025.2.1.1, 2025.2.2.1, 2025.2.3.1, 2025.2.4.2
  • 2025.1.0.2, 2025.1.1.1, 2025.1.2.1, 2025.1.3.5
  • 2025.0.0.1, 2025.0.1.1, 2025.0.2.1, 2025.0.3.2
  • 2024.2.0.1, 2024.2.1.1, 2024.2.2.1, 2024.2.3.1, 2024.2.4.1, 2024.2.5.2
FME Flow versions:
  • 2026.3+
  • 2026.2
  • 2026.1.2.1
  • 2025.2.4.2
  • 2025.1.3.5
  • 2025.0.3.2
  • 2024.2.5.2
  • FME Flow instances with the hotfix patch and upgraded engine installed as described in the FME November 2026 Security Updates:
    • 2026.1.0.0 through 2026.1.2.0
    • 2025.2.0.0 through 2025.2.4.1
    • 2025.1.0.0 through 2025.1.3.4
    • 2025.0.0.0 through 2025.0.3.1
    • 2024.2.0.0 through 2024.2.5.1
Status
Workaround
Resolved
Security Hardening
Known Issues
Considerations
Support
If you have any questions or encounter an issue not mentioned in the referenced articles, please contact Support.
