Hand-Written Mapping File .fme Deprecation
Liz Sanderson
Liz Sanderson
As of FME 2025.1, hand-written mapping files with the .fme extension can no longer be run in FME or by using the FME Engine command-line interface. These files were the primary means of defining an FME translation prior to the introduction of FME Workbench and do not contain a workspace XML component.
Workaround
If these mapping files are still in use, please update workflows to use a translation authored in FME Workbench prior to upgrading to FME 2025.1.
Support
If you are still using mapping files or have any further questions, please contact Support.
