Known Issue: FME fails to create a portal web connection to ArcGIS Enterprise 11.1
Rahul S
Rahul S
Known Issue ID
FMEFORM-28714
Feature
ArcGIS Portal Service Web Connection
Product
FME Form (formerly FME Desktop)
Versions Affected
2023.0.0.1
2023.0.0.0
2022.2.6
Status
Resolved
2023.0.1
2022.2.7
Issue
In FME 2022.2.6 and 2023.0.0.1, the process fails with the following error message when creating a web connection to ArcGIS Enterprise 11.1.
Unable to retrieve access token
Request to update access token failed. HTTP Error: HTTP/1.1 500 Internal Server Error
Workaround
Use the “Generate Token” authentication method for ArcGIS Portal Feature Service Reader and Writer.
Resolution
  • Upgrade to FME 2022.2.7 (Build 22801 or greater), FME 2023.0.1 (Build 23315 or greater)
  • Remove the old web service definition (as shown below).
  • The next step is to create a new web service from Esri ArcGIS Portal (Template)instructed in this article.
All the previously generated web services for ArcGIS Portal 11.1 will continue to fail.
You will have to use the updated template of the Esri ArcGIS Portal (Template) web service to create a successful web connection to ArcGIS portal 11.1 and newer versions.
