How to Convert Microsoft Excel to Esri Shapefile
Liz Sanderson
Liz Sanderson
In this tutorial, we will perform a very common transformation: taking non-spatial data in a Microsoft Excel file (*.xlsx) and converting it to an Esri Shapefile (*.shp). The Excel file contains x_coordinate and y_coordinate values for each row, which will be converted to points as the data is read. We will also merge data from multiple sheets, or feature types, into our output shapefile.
Video
This video was created with FME version 2016.0. Some of the steps might be slightly different, but the overall process is the same for newer versions of FME.
Step-By-Step Instructions
1. Add Microsoft Excel Reader
Open a blank FME Workspace and add a new reader. In the Reader dialog, type 'Microsoft Excel' and then browse to the PublicArt.xlsx file. Since this is a non-spatial or tabular format, we will need to add a coordinate system in the Coord. System box type LL84. Now, to ensure that our attributes containing the latitude and longitude of the points are read correctly, click the Parameters button.
As of FME 2025.2, the Coordinate System parameter is now configured within the Parameters dialog of each reader/writer format. For more information, including details about the change and affected transformers, please see Coordinate System Parameter Location Change.
For FME 2025.2 or newer, click on the Parameters button to set the coordinate system to LL84 under the Spatial section.
Under the Attributes section, ensure that Longitude is set to x_coordinate and Latitude is set to y_coordinate. Newer versions of FME will automatically perform this task, but it is always a good idea to verify.
We also want to ensure that we read all the sheets within the Microsoft Excel workbook. At the top, double-check to confirm that all sheets are enabled under 'Sheets to Read'. Once all of the parameters have been confirmed, click OK twice to add the reader.
The six sheets from the Excel file have now been placed on the canvas.
2. Inspect Data
To ensure that the data was read correctly, let’s inspect one of the feature types. Click on the Downtown reader feature type on the canvas to open the mini toolbar. Then, on the mini toolbar, click the View Source Data button to view the data in the Visual Preview Window.
In the Data Preview (formerly Visual Preview) window (or FME Data Inspector), open the Graphics View and ensure that there are points. If you want to double-check that the latitude and longitude are correct, you can add a background map and confirm that the points appear inside the Vancouver, British Columbia, city limits.
3. Set the Output (Writer) Format to Esri Shapefile
Next, we need to add a writer to the canvas. Click on "Add Writer" and, in the "Add Writer" dialog box, select "Esri Shapefile" for the format. Then, for the Dataset, browse to a folder to save the shapefile, and then click OK to add the writer.
After clicking OK, a Select Feature Type dialog will appear. Select any one of the feature types; which one you choose doesn’t matter, as they all have the same schema.
4. Update Writer Properties
Open up the writer feature type parameters (in this example, we used West End). In the parameters, change the Shapefile Name to Public Art and then change the Geometry to shapefile_point. Click OK.
Connect the PublicArt writer feature type to all of the reader feature types. It should be six reader feature types going into one writer feature type.
5. Run the Workspace
The workspace is now ready to be run. Run the workspace by clicking on the green play button.
6. View the Output Dataset
To view the output dataset, click on the PublicArt writer feature type to open the mini toolbar, then click on the View Written Data button.
In Visual Preview, you should have 185 features that contain all the public art in Vancouver.
Advanced
Since we are writing all the Excel sheets into one Esri shapefile, and they all have the same schema, when we added the reader, we could have set the Workflow Options to Single Merged Feature Type. This would have resulted in only one reader feature type on the canvas with all of the sheets merged into one. By doing this, it will also enable the fme_feature_type attribute (found in the Format Attributes tab of the reader feature type parameters), which contains each of the neighborhood names.
Next, add an AttributeManager and rename fme_feature_type to NeighName. The final step will be to add NeighName to the writer feature type user attributes. Refer to the Advanced-ExcelToShapefile.fmw workspace, included in the downloads, for more details.
Data Attribution
