Errors due to missing Microsoft Visual C++ Redistributable
Liz Sanderson
Liz Sanderson
Considerations
When launching FME Workbench, FME Data Inspector, or FME Quick Translator on Windows Desktop delivered via Citrix, users may encounter startup failures or installation errors. Symptoms include:
  • A runtime error:
    Runtime Error! Program: Y:\Apps\FME\fmeworkbench.exe R6030 - CRT not initialized or
    The application was unable to start correctly (0xc0000142).
    Click OK to close the application.
  • DLL loading failure warnings:
    DLL 'C:\Program Files (x86)\FME\xxxx.dll' was found but could not be loaded.
  • Reader initialization errors:
    This FME edition does not recognize the 'xxxxxxxxx' reader.
  • Installation failure:
    "Setup Wizard ended prematurely because of an error"
These symptoms can occur during application launch or installation and are often environment-specific.
Why This Happens
These issues are typically caused by the Microsoft Visual C++ Redistributable not being installed correctly alongside FME Form. Common reasons include:
  • User Account Control (UAC) blocking installer components
  • Corrupted FME installer download
  • Outdated Windows Installer
  • An older version of Visual C++ Redistributable is being loaded
How to Resolve It
1. Install or Repair Visual C++ Redistributables
The required redistributables (both X64 and X86) are available on the FME installation media or directly from Microsoft. The redistributable is backward-compatible; the latest version is suitable for all FME releases.
FME Version Microsoft Redistributables
2024.0 VS2013, VS2015-VS2022
2023.0 VS2013, VS2015-VS2022
2022.0 VS2010, VS2012, VS2013, VS2015-VS2022
2021.0 VS2010, VS2012, VS2013, VS2015-VS2022
2020.0 VS2010, VS2012, VS2013, VS2015-VS2022
2019.0 VS2005, VS2008, VS2010, VS2012, VS2013, VS2015-VS2022
2018.0 VS2005, VS2008, VS2010, VS2012, VS2013, VS2015-VS2022
2017.0 VS2005, VS2008, VS2010, VS2012, VS2013, VS2015-VS2022
2016.0 VS2005, VS2008, VS2010, VS2012, VS2013, VS2015-VS2022
2015.0 VS2005, VS2008, VS2010, VS2012, VS2013
2.  Additional Troubleshooting
If installing the redistributable does not solve the issue:
  1. Ensure Windows Installer is up to date via Windows Update or from Microsoft's download page
  2. Re-download the FME installer to avoid corruption.
  3. Uninstall any previous FME installations.
  4. Run the installer as an administrator: right-click and select Run as administrator.
Step 3: If the Issue Persists
Additional Notes
Validating the Installer
To check if the installer file is corrupted:
  • Use Hash My Files to generate MD5 and SHA1 values.
  • Send the hash values, file size, and filename to Support.
Installer Logging
To create a detailed install log:
bash CopyEdit msiexec /i "C:\tmp\fme-desktop-b12258-win-x86.msi" /l*v install.log
Submit the generated install.log to the Support Team for review.
