Writing KML with Basic Styling
Liz Sanderson
Liz Sanderson
The KML format supports tags that define the style and symbology of the features within a dataset. In FME, these tags can be set using KML-specific transformers, including the KMLStyler.
Video
Convert data from multiple sources (in this case, MapInfo TAB and MIF/MID) to KML for loading in Google Earth and other earth browsers. You'll see how to automatically set tags to define the style and symbology, set up the KML tree, and control the schema / attributes. This video was recorded with an older version of FME. The interface will be different but the concepts are the same.
Step-by-step Instructions
Part 1: Style Polygons
1. Open FME Workbench
In a blank workspace, add a MapInfo TAB (MITAB) reader, browse to the city_parks.tab file that is included in the downloads. Click OK to add the reader.
2. Rename Attributes
When we view the attribute names in Google Earth, we don’t want any underscores or any other data-specific naming conventions. Add an AttributeRenamer transformer to the canvas. Select name_alt as the Input Attribute and then type “alt name” as the Output Attribute.
3. Set KML Properties
We can also control how the attributes appear in the navigation tree in Google Earth, as well as the pop-up description balloons when you click on a feature. Add a KMLPropertySetter to the canvas and connect it to the AttributeRenamer. In the parameters, set up the following:
  • Name: name
  • Summary: Park
  • Attribute Table Title: Park Names
4. Style Polygons
We want to style the park polygons with a black border and a green fill, to do this we will use the KMLStyler. Add a KMLStyler to the canvas and connect it to the KMLPropertySetter. For Color, select black (0,0,0), then for Fill Color, select lime green (0,255,0), or any other green. Finally, change the Fill Opacity to 0.7.
5. Write to KML
With the properties and style set, we can now write to KML. Add a Google KML writer to the canvas. Browse to a location to save the file and name the dataset ParksAndNests.kml. Set the Feature Type Definition to Automatic.
In the Feature Type dialog, set the Feature Type Name to Parks and click OK. Connect the Writer feature type to the KML Styler.
Part 2: Style Points
1. Add a MapInfo MIF/MID Reader
In the same workspace as Part 1, add a MapInfo MIF/MID reader to the canvas. Browse to the BirdNestPoints.mif file and then set the Coord. System to TX83-CF. Click OK to add the reader.
As of FME 2025.2, the Coordinate System parameter is now configured within the Parameters dialog of each reader/writer format. For more information, including details about the change and affected transformers, please see Coordinate System Parameter Location Change.
2. Set KML Properties
Now, to set the KML properties for the navigation tree and description balloon. Add a KMLPropertySetter to the canvas and connect it to the BirdNestPoints reader feature type. In the parameters, set up the following:
  • Name: Nest_ID
  • Summary: Bird nest in the city of InteropolisPark
  • Attribute Table Title: Bird Nest
3. Style Points
Point features are locations of interest that have a specific point, but not a defined size, such as mountain peaks or historical markers. In KML, point features are assigned an icon as a map symbol. FME includes a set of built-in icons specifically designed for KML format translations and viewing. Add a KMLStyler to the canvas and connect it to the KMLPropertySetter_2. In the parameters, expand the Icon, then click on the ellipsis next to Name. You can select whichever icon you wish, but we will be using C2. We can leave the rest of the parameters as the default.
4. Write to KML
With the properties and style set, we can now add to our KML file. On the top menu bar, select Writers > Add Feature Type to add our Nests feature type to the ParksAndNests.kml file.
In the Feature Type dialog, set the Feature Type Name to BirdNests and click OK. Connect the BirdNests writer feature type to the KMLStyler_2.
5. Run the Workspace
Save and run the workspace. View the output in Google Earth, you should now have both the parks and the bird nests in the same KML file.
Data Attribution
The data used in this article originates from open data made available by the City of Austin, Texas. It contains data licensed under the Public Domain Dedication License, as provided by the City of Austin.
