FME Flow cannot load Resources in the Web UI
Liz Sanderson
Liz Sanderson
Consideration
When FME Flow is configured for Active Directory authentication using a preauth service account, users with valid accounts and correct permissions may be unable to view the list of resources in FME Flow Web UI > Manage > Resources. This occurs even after reviewing Safe Software's Troubleshooting Authentication Services documentation.
The following entry appears in <FME Flow System Share>\resources\logs\core\current\fmesharedresource.log:
(Active Directory) Authenticating user "FMESERVICE@SAFE.COM" using SASL mechanism "GSSAPI" with KDC address "DNS.SAFE.COM" and realm "SAFE.COM"...
(Active Directory) Successfully established a new connection to DNS.SAFE.COM.
(Single Sign-On) Disabled single sign-on authentication.
(Login Module) Authenticating token "23b385c617625eefb4f7ea8d91746aa572b889a9" clientAddress "".
(Active Directory) Successfully established a new connection to DNS.SAFE.COM.Failed login by user 23b385c617625eefb4f7ea8d91746aa572b889a9 due to insufficient credentials.
Why This Happens
This behavior is caused by a setting on the Active Directory service account used for preauthentication:
  • The Windows Active Directory account can be configured with the "Do not require Kerberos preauthentication" option enabled.
  • When this option is enabled on the account specified as SECURITY_AD_PREAUTH_USERNAME (for example, FMESERVICE), FME Flow cannot complete the GSSAPI SASL authentication handshake with the domain controller.
  • As a result, users are treated as having insufficient credentials, even though their own account and permissions are correct.
How to Resolve It
  1. Open Active Directory Users and Computers (or the equivalent Active Directory management tool) on the domain controller.
  2. Locate the service account specified as SECURITY_AD_PREAUTH_USERNAME in fmeCommonConfig.txt (for example, FMESERVICE).
  3. Open the Properties dialog for the account and click the Account tab.
  4. Under Account options, ensure "Do not require Kerberos preauthentication" is unchecked.
  5. Click OK to save the changes.
If this does not resolve the issue, search the FME Community for similar topics or submit a support ticket.
Additional Resources
