Merging or Joining Spatial Data
Liz Sanderson
Liz Sanderson
Merging or joining data that has geometry can be accomplished in FME by using a transformer. Data that has geometry needs to be handled differently than when working with spreadsheet or database data. If you are merging spreadsheet or database data, see the Merging or Joining Spreadsheet or Database Data article.
Geometry in FME is grouped into three different categories:
  • Points (includes text)
  • Curves (includes lines, arcs, and paths)
  • Areas (includes polygons, donuts, and ellipses)
Depending on the geometry, you are trying to merge or join a different transformer, which is required.
Transformers
There are four main categories of spatial merging and joining transformers in FME:
  1. Proximity Join: joins based on how far one feature is from another
  2. Modifying Geometry Join: joins that will cause geometry to be changed (like a cookie cutter)
  3. Geometry Relationship Join: joins based on the relationship between the geometry (is the feature inside, outside, or touching the other feature).
  4. External Join: joins data already inside the workspace to external data.
All of these transformers will join the features' attributes, but not always by default. If applicable, enable the “Merge Attributes” parameter to ensure that the attributes are also merged.
When trying to decide which transformer is the correct one to use, follow the flowchart below to help. Please inspect your data and ask the following questions:
1) Is all of my data already inside the workspace?
  • If yes: Continue to question 2
  • If no: Either use the FeatureReader for your join or read in the data and continue to question 2
2) Do I want to alter the geometry of my data?
  • If yes: Use a transformer from the Modifying Geometry column (continue to question 3)
  • If no: Use either a Proximity or Geometry Relationship join (skip to question 4)
3) You want to alter the geometry. Do you want to clip the data to the size of the other data (cookie cutter?)
  • If yes: Use the Clipper transformer
  • If no: Use one of the overlayer transformers in this column (skip to question 5)
4) You DO NOT want to alter the geometry. Do you want to join based on a relationship (touching, completely inside, intersects, etc)?
  • If yes: Use one of the Geometry Relationship transformers (continue to question 5)
  • If no: Use one of the Proximity transformers (continue to question 5)
5) Did any of those transformers work?
  • If yes: Great!
  • If no: Read the documentation carefully to ensure it was set up correctly and suites your needs
  • If unsure: Ask a question on our community.
Download a PDF version from the 'Files' section.
Tutorials and Documentation
Transformers listed by category
Proximity
PointOnPointOverlayer
The PointOnAreaOverlayer compares points and polygons. Each point receives the attributes of the area(s) it is contained in, and each containing area receives the attributes of each point it contains.
PointOnPointOverlayer Documentation
NeighborFinder
The NeighborFinder is a spatial transformer that finds the nearest candidate feature(s) to each base feature and then merges the attributes onto the base feature.
Determining Nearest Neighbors
NeighborFinder Documentation
Matcher
The Matcher can receive any number of input feature streams. All features are compared against all other features, and matches are identified based on the parameters defined.
Data QA: Identifying Duplicate Features with FME
Calculate Strahler Stream Order Numbers
Matcher Documentation
Modifying Geometry: Clipping Splitting
PointOnLineOverlayer
The PointOnLineOverlayer compares points and lines, splitting the lines where a point falls on (or within a specified distance of) the lines.
PointOnLineOverlayer Documentation
Clipper
The Clipper transformer is a spatial transformer that performs a geometric clipping operation (sometimes called a cookie cutter). While clipping, object attributes can be spatially joined.
Example Using the Clipper Transformer
Generating Polygon Differences with the Clipper Transformer
Raster Clipping
Clipper Documentation
LineOnLineOverlayer
The LineOnLineOverlayer takes in-line features and compares them to each other.
LineOnLineOverlayer Documentation
LineOnAreaOverlayer
The LineOnAreaOverlayer compares lines and polygons, splitting the lines where they intersect with a polygon boundary.
LineOnAreaOverlayer Documentation
AreaOnAreaOverlayer
The AreaOnAreaOverlayer takes in area features. All polygons are considered against each other, and where they overlap, new polygons are created that represent both the overlapping area and the original areas with the overlap removed.
Extracting Polygon Intersections with the AreaOnAreaOverlayer
AreaOnAreaOverlayer Documentation
Fine Tuning Geometry Relationships
Point in Polygon Calculations with the PointOnAreaOverlayer
PointOnAreaOverlayer Documentation
SpatialRelator
The SpatialRelator takes in two streams of features - Requestors and Suppliers. The Requestors are the features you would like to identify information about, determining what spatial relationship(s) they have with the Supplier features.
SpatialRelator Documentation
SpatialFilter
The SpatialFilter is a spatial transformer that filters point, line, area and text features based on spatial relationships. The attributes can then be merged based on the filter.
Determining Spatial Relationships
Buffering Features for Spatial Relationship Analysis
SpatialFilter Documentation
External Data
FeatureReader
The FeatureReader reads features from any FME-supported format. This can be done midstream, which aids in quickly adding and joining data.
The FeatureReader Transformer
Performing Spatial Queries on Database Tables Using the FeatureReader
FeatureReader Documentation
Looking for spreadsheet or database transformers? See the Merging or Joining Spreadsheet or Database Data article.
