FME and IBM Maximo
Liz Sanderson
Liz Sanderson
Maximo is an Enterprise Asset Management System from IBM.
FME can connect to Maximo using a web connection and several transformers available on FME Hub. Using these transformers, you can query, add, and modify Maximo records. You can also use events in Maximo to trigger FME processes.
Requirements
  • Admin Access to Maximo or an API key requested from your administrator
  • Licensed version of FME
  • Web access to download the Maximo transformers from FME Hub
Articles
Using the Maximo Connector and Transformers in FME
Covers how add a Maximo web connection in FME and using the MaximoObjectQuerier, MaximoObjectCreator, and MaximoObjectUpdater transformers.
Monitoring Maximo with FME
Using FME to monitor Maximo notifications when objects are modified, added, or deleted using the KafkaConnector.
