Writing to Smallworld Multiple Geometries
Liz Sanderson
Liz Sanderson
Welcome to the FME for Smallworld 5 tutorial. In the previous section, Importing into Smallworld, you wrote to the Smallworld cable object, which only has a single geometry or spatial column. Many Smallworld objects have multiple spatial columns with different geometries (chain, area, point, text). This article covers importing data into your Smallworld 5 database, including instructions on importing data into multiple geometry objects.
Load Supply Point Multiple Spatial Columns
In this example, you will load the Supply Point object, which contains both a point (location) and text (label) geometry.
Step-by-step Instructions
1. Generate Workspace
You’re going to generate the workspace in the same way you did in the previous section. Open FME Workbench. On the Workbench Start tab, choose the Generate option.
As of FME 2025.2, the Coordinate System parameter is now configured within the Parameters dialog of each reader/writer format. For more information, including details about the change and affected transformers, please see Coordinate System Parameter Location Change.
  • Reader:
    • Format: Autodesk AutoCAD RealDWG DWG/DXF
    • Dataset: electric-networkproposed.dwg
    • Parameters:
      • Group Entities By: Attribute Schema
      • Expand Blocks into Entities: UNCHECK
      • Coordinate System: OSGB-GPS-2015-OSTN15
  • Writer:
    • Format: Smallworld 4/5
    • Service: FME
    • Alternative: |fme_training
(Be sure to use the | symbol as the first character for Alternative)
In the Generate Workspace dialog, place a check mark on the “Import feature type definitions” checkbox.
Click OK.
2. Import Writer Feature Types from Smallworld
The “Import Writer Feature Types” dialog will appear. Click on the Parameters button, and select:
  • Table List: electricity.supply_point
Click OK to close the import feature types dialog.
3. Select AutoCAD Layers
The Select Feature Types dialog will open. This is the AutoCAD layer selection.
  • Select electricity_supply_point
And click OK to generate the workspace.
4. Save Workspace
Save the workspace locally at:
<My Documents>\My FME Workspaces\Smallworld5.fmw
5. Connect Reader and Writer Feature Types
Connect the electricity_supply_point reader feature type to the new electricity.supply_point writer feature type.
Expand the attribute lists for the reader and the writer.
The FME Smallworld 5 writer handles Smallworld geometries in a completely different way to Smallworld 4. The Smallworld 4 versions of the workspaces are all attached at the bottom of this article for reference. Geometry types are no longer exposed as attributes and no longer use the sworld_geometry{} list attributes. Old workspaces are still compatible in Smallworld 5.1.
6. Redirect to Inspection Application
When creating more complex workflows, test them before loading the data into the database. In Workbench, go to the Navigator window -> Workspace Parameters -> Order and Redirect -> click on Writer Redirect -> select 'Redirect to Data Inspector'. All your output will be redirected to the Data Inspector as you build your workspace.
Additionally, as you build your workspace, consider adding Data Inspector transformers to inspect the intermediate results.
7. Filter the Proposed Supply Points
You only need to insert the proposed supply points. Add a Tester transformer to filter the status attribute, retaining the “Proposed” supply points. If you run the reader first the cached values will appear in the tester.
8. Filter the Point & Text Geometries
Add a GeometryFilter and expose the Point and Text Geometries. This will split the point geometries and the text geometries into two different streams.
9. Set Geometry Name
Supply Points in the Smallworld Cambridge database have two spatial columns for location and annotation, and these are named 'location' and 'label', respectively.
Add a GeometryPropertySetter for the point and text geometries and set the appropriate geometry name.
Properties to Set: Geometry Label
Geometry Label for Point: Location
Geometry Label for Text: Label
Point:
Text:
The text label is set to the ID value by Smallworld when the object is inserted - in this case, the 'ID' value.
10. Set Attribute Values and Database Operation
Add an AttributeCreator transformer to your workspace and connect it between the Tester transformer and the GeometryFilter. In the AttributeCreator, add the attributes:
Output Attribute: fme_db_operation
Value: INSERT
insert new records only
Output Attribute: customer_class
Value: New Customer
So we can recognize the new records
11. Combine the Location and Label Geometries - Aggregator
The Aggregator transformer produces a new geometry structure: an FME aggregate. An aggregate is a feature that has multiple geometries sharing the same attributes. In this case, the aggregate will consist of a text (for the label) and a point (for the location) of the supply point (a heterogeneous aggregate). The aggregator requires a key for the aggregation (the Group By parameter). For many CAD-to-GIS problems, there may be no key attribute, so you might use a NeighborFinder transformer to make a spatial join. We’re lucky – this DWG file has an ID field we can use.
Add an Aggregator transformer and connect both of the GeometryPropertySetter transformers. Set ports to the Aggregator input port.
12. Set Aggregator Parameters
In the parameters dialog for the Aggregator, enter these settings
Group By: id
Aggregation Mode: Geometry - Assemble One Level
Attribute Accumulation Mode: Merge Incoming Attributes
Aggregation Type: Heterogeneous Collection
The Aggregator transformer merges your point (location) and text (label) features using the 'id' attribute as the key. The Mode sets the type of merge used for geometry – in this case, a simple (one-level) geometry structure.
In Smallworld 4, you would build the sworld_geoemtry{} list in the Aggregator transformer. This is no longer needed for Smallworld 5. Older workspaces with the sworld_geoemtry{} list configuration will still run and load the data correctly. Examples of the Smallworld 4 workspaces are attached at the end of this article.
13. Save and Run
Run the workspace and inspect the results in Data Inspector.
On the Writer menu, unset Redirect to Inspection Application and run again.
Inspect the updated data in the Professional - Smallworld Core GIS application. If necessary, use Smallworld Versioning to roll back to the last checkpoint and correct your workspace.
Save the workspace - it should look something like this:
Summary
In this exercise, you’ve read point and text features from the AutoCAD dataset and then merged them with the Aggregator transformer. The Aggregator transformer also builds the multiple geometries used by the Smallworld writer to populate the multiple spatial columns in your Smallworld Cambridge database.
Smallworld 4 Examples
FME creates the multiple geometry features for the Smallworld 5 writer differently than it does for Smallworld 4. Smallworld 5 makes it much easier. The example below shows how to accomplish this for Smallworld 4. Smallworld 5 still supports this older approach, so if you have existing workspaces, they will be compatible with Smallworld 5 and should run without any changes.
