How to Convert ECW to GeoTIFF
Liz Sanderson
Liz Sanderson
ECW files, or Enhanced Compressed Wavelets, are compressed image files specializing in satellite or aerial imagery. ECW is a lossy compression, also known as irreversible compression, meaning that during compression some of the image is discarded to greatly reduce file size.
FME can read and write ECW files, using the ER Mapper ECW Reader/Writer. For more in-depth information about the ER Mapper ECW Reader/Writer, please visit the documentation.
In this example, we will mosaic four orthophotos together of Queen Elizabeth Park in Vancouver, BC. The orthophotos also contain the surrounding area, which we are not interested in. Using the Clipper transformer and a shapefile containing park boundaries, we will clip the mosaicked orthophoto and output only the park area to a GeoTIFF.
Step-by-step Instructions
1. Add an ER Mapper ECW Reader to a Blank Workspace
In a blank FME workspace, add an ER Mapper ECW Reader and add all four of the .ecw datasets (BCVAN15_O17.ecw, BCVAN15_P17.ecw, BCVAN15_O18.ecw, BCVAN15_P18.ecw). Set the Coordinate System to UTM83-10, then click OK to add the reader.
As of FME 2025.2, the Coordinate System parameter is now configured within the Parameters dialog of each reader/writer format. For more information, including details about the change and affected transformers, please see Coordinate System Parameter Location Change.
Add an ER Mapper ECW Reader and add the four orthophotos
In the parameters, change Feature Type Name(s) to From File Name(s) so we can distinguish which feature type corresponds to which.
Setting Feature Type Name(s)
2. Mosaic the Orthophotos Together
Add a RasterMosaicker transformer to the workspace and connect all four BCVAN15 feature types to it. We will just use the default parameters for this example.
Connect the RasterMosaicker to the four orthophotos
3. Add the Polygon Shapefile
We will need to define a boundary to clip our rasters to. To do this, add a Shapefile writer and browse to the parks_polygon.shp.
4. Test for Queen Elizabeth Park
Our orthophotos are of Queen Elizabeth Park in Vancouver, to find the correct parks polygon for the park we can use the Tester transformer. Add a Tester to the canvas and connect it to the parks_polygon reader. In the Tester parameters, set the Left Value to PARK_NAME, the operator to "=", and the Right Value to Queen Elizabeth Park (remember that the tester is case-sensitive).
5. Clip the Mosaicked Orthophotos to the Park Polygon
Using the Clipper transformer, connect the Clipper Input port to the Passed output port on the Tester and the Clippee Input port to the Output port on the RasterMosaicker. In the parameters, change the Clipper Type to Single Clipper
6. Write to GeoTIFF
Add a GeoTIFF Writer to the canvas, then select a location to save the file. Set the Raster File Definition to Automatic. In the Feature Type Window, set the Raster File Name to QueenElizabethPark and click ok.
GeoTIFF Writer with Raster File Definition set to Automatic
ECW to GeoTIFF workspace
7. Run the Workspace and View the Output
Run the translation and view the output file in an image viewer. You can also view the image in the Data Inspector and configure a background map to ensure it is georeferenced.
Output GeoTIFF viewed in an image viewer
Data Attribution
