Esri ArcGIS Pro Utility Network Migration Tools
Liz Sanderson
Liz Sanderson
The Utility Network is a data model developed by Esri for modeling utilities and telecoms. The new data model allows users to model complex networks more completely, including entities such as switchgear for Electrical utilities.
For more information about the Esri Utility Network, refer to the ArcGIS Pro What is utility network? page. Information on the utility network asset package and how to download it is available on the Esri ArcGIS Utility Network Package Tools Get Started page.
To learn more about the FME Utility Network migration workspaces, review FME Training for Esri Utility Network Migration.
Files
Additional files are available on the right-hand side of this article.
FME Migration Tools
FME Workspaces help you migrate your Esri ArcGIS Geodatabase to the new Utility Network (UN) data model. This page documents the status of the migration tools for different UN data models.
Esri Utility Network Migration Tools include:
Gas - Migration Tools
The Gas Utility Network Migration Tools help you transform gas data from a geometric network to a utility network using FME or ArcGIS Pro with the Data Interoperability Extension. It includes a workbench, a schema mapper, tools, sample data, and documentation.
The provided workbench and schema mapper are pre-configured for the included sample source data. You will need to configure the workbench and schema mapper for your source data.
Water - Migration Tools
The Water Distribution Utility Network Migration Tools help you transform water distribution system data from a geometric network to a utility network using FME or ArcGIS Pro with the Data Interoperability Extension. It includes a workbench, a schema mapper, tools, sample data, and documentation.
The provided workbench, schema mapper, and sample source data are set up for a schema similar to how a water distribution system is represented as a geometric network in the Local Government Information Model (LGIM) or the water editing tools. You will need to further configure the workbench and schema mapper for your source data.
Electric - Migration Tools
The Electric Utility Network Migration Tools help you transform electric system data from a geometric network to a utility network using FME or ArcGIS Pro with the Data Interoperability Extension. It includes a workbench, assembly builder, a schema mapper, tools, sample data, and documentation.
The provided workbench, assembly builder, schema mapper, and sample source data are pre-configured for a schema similar to how an electric distribution system is typically represented as a geometric network. You will need to further configure the workbench, assembly builder, and schema mapper for your source data.
Electric Migration Downloads:
Version 3.4
  • Release of the Electric Migration workspace for Electric Asset Package V3.4: ElectricV3.4.zip
    Workspace results have passed through Stage Utility Network and Apply Asset Package in untools.
  • Documentation for the V3.4 migration workspace in included in the zip file in the Documentation folder.
Version 3.2
  • Release of the Electric Migration workspace for Electric Asset Package V3.2: Electric Migration V3 2019_12_18.fmwt.
  • Documentation for the V3.2 migration workspace: Electric Utility Network Migration Tools Documentation 2020-02-07.pdf
Version 2
  • Version 2 available on GeoNet
If you have additional questions or would like a more in-depth walkthrough of the Migration workbenches, please feel free to contact us at info@safe.com.
