FME Version
If you're looking to connect to Autodesk Construction Cloud or BIM 360 Hub through the AutodeskDocsConnector, please see Adding FME through the Autodesk App Store for Use in the AutodeskDocsConnector for a simpler and recommended method to connect. Both of these methods will allow you to connect to your ACC and BIM 360.
There are two methods to set up a web connection for use in the AutodeskDocsConnector to access Autodesk Docs: one through Autodesk Construction Cloud (ACC), and the other through BIM 360 Hub.
This article will walk through the two different ways on how to set up an Autodesk Docs web connection. This web connection is provided as part of the Autodesk Docs package which is available on the FME Hub and contains the Autodesk Docs (safe.autodesk-docs) web service definition.
Note: This service definition, safe.autodesk-docs, is provided by Safe Software for demonstration purposes and ease of use. The client id and client secret may become deactivated at any time. For production use, we recommend users obtain their own Client ID and Client Secret from the web service provider.
Note: The AutodeskDocsConnector replaces the deprecated AutodeskBIM360DocsConnector. The new package is a renaming of the old AutodeskBIM360DocsConnector to highlight that the transformer connects to both BIM 360 Docs and Autodesk Docs within Autodesk Construction Cloud.
How to create an Autodesk Docs Web Connection
To get the web connections working for your organization with your own Client ID and secret, you will need:
- Access to Autodesk Forge — If you don’t have access to Forge, share these instructions with your Administrator who can set the application up for you.
- Access to Autodesk BIM 360 Hub or Autodesk Construction Cloud
Set up your application in Autodesk Forge
In order to configure the web service correctly, you will need to retrieve/configure an app in Autodesk Forge and BIM 360.
The final step is to gather the above information and edit the web service in FME:
Configure the web service in FME
Forge App
For Application Type, ensure you are selecting the ‘Traditional Web App’.
At a minimum, the app must have access to BIM 360 and Data Management APIs.
Redirect URI/Callback URL
When configuring the Forge App, you will need to also configure the callback URL, which will be used for the Redirect URI.
In FME, you will need to set the Redirect URI so that it is consistent between FME and the Forge App.
Client ID & Client Secret
Once you have created the app, the details of the app will have the Client ID & Client Secret. Take notes of these for use in BIM 360 Hub and in FME.
Autodesk Construction Cloud or BIM 360 Hub: Custom Integration
It is also required to add the chosen Forge App as a custom integration on the BIM 360 Hub page or via Autodesk Construction Cloud.
Setting up with ACC will require an extra navigation step detailed below before continuing with the BIM 360 Hub instruction. If you wish to set up using the BIM 360 Hub only, skip to the BIM 360 Hub.
Custom Integration Via Autodesk Construction Cloud
As an admin, sign in to Autodesk Construction Cloud by going to https://construction.autodesk.com/ and navigate to Account Admin > BIM 360 admin > Settings > Custom Integrations
After selecting Settings, continue with the instructions below to set up the Custom Integrations.
Custom Integration Via BIM 360 Hub
To set up via BIM 360 Hub, an admin can do this by going to https://admin.b360.autodesk.com/ and login with their credentials, then navigating to Settings > Custom Integrations > Add Custom Integration
Setting up the Custom Integration
Here you can select what access the custom integration will have:
Then enter the client ID of the connected Forge App.
In FME Workbench, open up the Manage Web Services dialog. You can get to this from FME Options > Web Connections > Manage Services
You will need to edit the Autodesk Docs (safe.autodesk-docs) web service:
Complete your web service configuration by entering in your Client ID and Secret, and the Redirect URI matches the callback URL that is specified for your application in Forge:
Save your web service and create a new web connection from FME Options or the AutodeskDocsConnector:
You can now begin using your web connection with the AutodeskDocsConnector.
Comments
0 comments
