The InlineQuerier Transformer
Liz Sanderson
Liz Sanderson
The InlineQuerier transformer offers a powerful capability for joining multiple datasets and then extracting the data in any desired format. It is an interesting transformer in that it utilizes a SQLite database underneath, providing you with the full power of SQL for data extraction.
If you find that you are using multiple FeatureJoiner or FeatureMerger transformers in your workspace, the InLineQuerier might be a good alternative.
Still trying to decide which join transformer is most appropriate to use? See the article Merging or Joining Spreadsheet or Database Data
When the InlineQuerier transformer is added to a workspace, it has no input or output ports.
Input ports are built on the fly as you connect source data to the transformer, and output ports are added as SQL statements are built inside the transformer. e.g.
Refer to the InlineQuerier documentation for details on the transformer. The example workspace can be downloaded from the files section on the right.
Defining Inputs
Tables
After connecting the input data to the "Connect Input" port, a list of Tables will be added to the transformer's Inputs dialog box. You can connect any reader feature type or any transformer, such as the Duplicate Remover shown above.
Table names are derived from the feature type or transformer name. You can rename the Input Tables, if necessary.
Columns
The Columns list defines the attributes used in SQL queries and is then used to define the Outputs below. This is auto-populated as each table is connected to the transformer. It pulls in all the attributes in each table. However, this is not necessary - only the Query attributes need to be explicitly defined. All other attributes and geometry will be held in an fme_feature_content attribute, which is carried through the transformer. There is a memory overhead to adding all the individual attributes, so keep these lists as short as possible.
Also, ensure the attribute's data type is correct, as incorrect data types may cause joins to fail. For example, in the image above, PID is a varchar in AddressData and a float in PropertyTax, but it is actually an integer.
The Import button will also pre-load these attribute lists for you, but it will again bring in all attributes from each table.
Performance: Reducing the number of attributes listed in the Columns parameter, as described above, can impact the performance of the InlineQuerier. FME creates a table in an in-memory SQLite database, and reducing the number of attributes in that table will reduce the memory resources required. Recall that all attributes are also preserved in fme_feature_content. Additionally, attributes listed in the Columns parameter are indexed to speed up queries. Therefore, for larger datasets with many attributes, this can result in significant indexing if all attributes are included in the Columns parameter.
Defining Outputs
Output ports are added as SQL statements are defined. There can be a single output port or multiple output ports, depending on what you are extracting from the data. Not all input tables need to be used in every SQL statement; only attributes defined in the Input Columns can be used in SQL. The Output ports can be named descriptively to help document the transformer.
SQL Query
The SQL Queries can be built using the SQL Editor and can involve a single table or multiple tables as required. Any attributes referenced in the SQL Statement must be defined in the Columns list above. All other attributes and geometry are maintained in an fme_feature_content attribute. If the result of a query includes the fme_feature_content attribute (either explicitly or through the use of a SELECT *), then the content of the original features will be included in the output feature.
SQLite is the underlying database used by InlineQuerier, so SQL statements must adhere to SQLite syntax and follow a SQLite tutorial.
The Generate button can be used to generate a single SELECT * statement for each table in the Inputs section.
Geometry
The Geometry option controls how the geometry is generated on the output features. If set to "First Feature" - then the geometry of the first source table in the SQL statement FROM will be output on the generated features. For example, if you want to join the AddressData (point geometry) to PropertyTax (no geometry) you could use:
SELECT * FROM "AddressData" a,"PropertyTax" b where a.PID = b.PID;
or
SELECT * FROM "PropertyTax" b, "AddressData" a where a.PID = b.PID;
In the first, you'll get the point geometry from the AddressData, and in the second, you'll get no-geometry from the PropertyTax
If Geometry is set to "Aggregate of All Features", the features will have geometry that is an aggregate of all encountered geometries.
Additional Resources
Using the InlineQuerier as a Replacement for Multiple FeatureMergers
Merging or Joining Spatial Data
InlineQuerier Documentation
