Which FME Flow Service Should I Use?
Liz Sanderson
Liz Sanderson
If you’ve ever published a workspace from FME Form (formerly FME Desktop) to FME Flow (formerly FME Server), you’ve probably noticed that there is a dialog to register the workspace to a Service.
In total, there are five different services to choose from. This article will discuss the most commonly used Services; Data Download, Data Streaming, and Job Submitter service. For information on the KML Network Link or the Notification Service, see the linked documentation.
Service Action Typical Use Case
Data Download Returns results as a downloadable zip file. Used in self-serve scenarios. Users can request data and have the results returned directly through a link.
Data Streaming Streams the results directly back to the client.
Used in custom web applications and self-serve cases where the data is streamed back to the requesting client such as a web browser. Common for creating data feeds, web services, and dynamic parameters in Flow Apps.
Note: Only certain formats support data streaming.
Job Submitter Simply runs the workspace. Used when the results of a workspace don't need to be returned. Common for automations and workspaces where it's unnecessary to return results back to the user.
KML Network Link Service Accepts and carries out transformation requests as specified by a workspace, returning the results as a KML Network Link. Used when working in Google Earth.
Notification Service Pushes data to and from FME Flow in the form of messages when an event occurs. Used when working with FME Flow's notifications, topics, publishers, or subscriptions.
Data Download Service
The Data Download Service writes the output to a zip file and presents the user with a link to that file making it ideal for self-serve and data delivery to users. A typical application would be an organization that frequently provides data to either staff or customers. With a Data Download system, the user can fetch their own data immediately rather than having to put in a request with manual action required. This frees up the team to focus their time and efforts on more meaningful tasks and reducing wait times for the end-user.
An example of the Data Download Service can be found in our FME Flow Demos where a user can download data selected on a web map.
To test this out for yourself, follow the instructions below:
1. Run Workspace
Log into FME Flow and navigate to the Run Workspace page.
On the Run Workspace page, select the Samples repository. Then, under Workspace select earthquakesextrusion.fmw. Finally, in the Service drop-down, select Data Download.
Select Run at the bottom of the page to run the workspace under the Data Download Service.
2. Inspect Output
Once the workspace has been completed, you should see a URL that can be selected. This URL will download a zip file. This zip file contains a KML file which will automatically be opened in Google Earth (if installed) when selected.
Data Streaming Service
The Data Streaming Service is like the Data Download because they both provide users with direct access to files. However, the Data Streaming service streams the file directly back to the user or client.
If the Data Streaming URL for a workspace is posted into a web browser, the data will be automatically downloaded and opened in whatever application the browser associates with that file type (some data might open directly in the web browser itself). This FME Flow Demo is an example of Data Streaming. Notice that the results of the workspace are streamed directly back to the web page.
Did you know that you can create FME Flow Apps with dynamic parameters with the help of Data Streaming workspaces? Follow this tutorial for more information: Dynamic Parameter Configurations in FME Flow Apps
Additionally, when a Data Streaming workspace is run through a webhook URL, this allows external applications to run the workspace and receive the results for further processing or display. For more information, follow the article on Submitting a Job through an FME Flow Webhook URL.
For the Data Streaming URL to work properly, it has to be writing data that is file-based, not folder-based. Some of the common formats to stream include:
  • JSON
  • XML
  • GeoJSON
  • HTML
  • RSS
  • GeoRSS
  • KML
  • PDF
  • PNG
  • JPEG
To test out the Data Streaming Service, follow the instructions below:
1. Run Workspace
On the Run Workspace page, select the Samples repository. Then, under Workspace select earthquakesextrusion.fmw. Finally, in the Service drop-down, select Data Streaming.
Select Run at the bottom of the page to run the workspace under the Data Streaming Service.
2. Inspect Output
You should see a file is downloaded directly to your desktop. If you open the file, it should open the data directly in Google Earth. If we were streaming a file that could be opened in a browser such as an HTML file, then it would open directly in the browser.
Job Submitter Service
The Job Submitter service is the simplest way to run a workspace in FME Flow. The workspace is run to completion and writes any outputs to specified destinations, similar to running a workspace in FME Workbench.
To test out the Job Submitter service, follow the instructions below:
1. Run Workspace
On the Run Workspace page, select the Samples repository. Then, under Workspace select earthquakesextrusion.fmw. Finally, in the Service drop-down, select Job Submitter.
The resulting file is sent to the destination specified in the KML writer for the workspace.
2. Find Destination
If your destination dataset is not a user parameter, to find where the data will be sent, we can open the workspace in FME Form. If it was a user parameter, skip to step 3.
If the workspace is saved on your machine, browse to the workspace file location to open it in FME Workbench. Otherwise, you will have to download the workspace to your machine. From the Run Workspace page, click Workspace Actions then Download the workspace. Once downloaded, open the workspace in FME Workbench.
Next, in the Navigator window, expand the Quakes writer information. The location of the output file is in the Destination parameter.
Alternatively, this information is also recorded in the job log. To view the job log, click View Details on the job completion confirmation page in step one, then scroll down to see the paginated log.
3. Inspect Output
If you set your destination in a user parameter, browse to that file location to confirm the file was output.
If you did not set the destination in a user parameter, browse to the file location identified in either the Workspace or Log. In this case, engineresults. To do this, on the side menu navigate to Files & Connections > Resources. In the Resources folder navigate to System > temp > engineresults. If you have lots of files, search for Quakes.kml.
