Manipulation of Tabular Data
Liz Sanderson
Liz Sanderson
This article describes the different tools you have available to manipulate tabular data using FME. This can include: transposing a table (table rotation), summary statistics and totals, pivot tables, and crosstab. These operations are common in spreadsheet applications such as Excel.
If your target format is Microsoft Excel, you might want to use some of FME's Microsoft Excel writer capabilities to write to a template file. The template file can include pre-defined pivot tables, charts, named ranges, etc. Refer to the Tutorial: Getting Started with Excel article series for more information.
Manipulating Tabular Data
We often think of tabular data in the context of a spreadsheet such as Excel, but table manipulation can also be performed on a Microsoft Access table, a CSV file, or any other tabular or database data. Common operations are:
  • Transpose: switching the columns and rows – sometimes referred to as table rotation.
  • Summary Statistics: calculation of totals and averages for the table data.
  • Pivot: also referred to as a crosstab. Pivot tables are used to analyze categorical datasets.
Articles
Calculating a Running Total or Cumulative Sum
You can generate simple statistics using the StatisticsCalculator. The StatisticsCalculator can also be used to generate a Cumulative Sum for a series of features
The Aggregator can also be used to generate simple statistics. The Aggregator will calculate weighted averages if the features have area geometries.
Transpose a Table Using FME
Transposing a table involves switching the columns of a table into rows – in most cases, without any data manipulation or summarization
Pivot Tables and FME
A pivot table, also known as a cross-tab, allows a user to change the structure of a spreadsheet to summarize data. This article shows how to create a pivot table with both the AttributePivoter and the StatisticsCalculator transformers.
