Memory Management is mostly an automatic process that the FME engine carries out during a translation. However, there are log file messages related to memory management that can be useful to inspect. For other performance tuning tips & tricks, see Performance Tuning FME.
FME Memory Configuration
At the start of the translation, FME determines the available memory and plans how to use it to achieve optimal performance. Two lines in the log file indicate these plans:
INFORM|FME Configuration: Start freeing memory when the process exceeds 71.99 GB
INFORM|FME Configuration: Stop freeing memory when the process is below 53.99This refers to virtual memory (the system's mix of physical memory and disk space). In the above example, FME plans to use as many resources as required, up to a limit of 71.99 GB. At that point, it will swap, moving data out of memory and onto the temporary disk folder.
When it has released enough memory to go below 53.99GB of usage, it will again start using memory instead of caching to disk. Because caching to disk is expensive, it's best for performance if FME can stay within the maximum limits. If it cannot do so, then it will record its actions in the log.
Optimizing Memory Usage
If you see either of these messages in the FME log:
INFORM|ResourceManager: Optimizing Memory Usage. Please wait...
INFORM|Failed to free sufficient memory to reach the process usage limit...they are evidence that FME has to optimize its memory use. The first message reports that FME has reached its upper limit and is now releasing memory by caching to disk.
The second message warns that FME has not been able to release enough memory to reach the lower limit. This may be because additional applications are starting to use the memory that FME is expected to use. If your FME task is completed in the expected time frame with the above error messages, real problems can occur for a number of reasons:
- Insufficient resources:
- Insufficient Specification: Your computer may simply lack the resources (memory and disk space) required to process the data.
- Competing Applications: Check the task manager to see if other applications are using resources or if you have other FME jobs running (particularly if you are seeing this in FME Flow). Where possible, don't start new applications once FME is running. They may take up resources that FME expected to use.
- Memory Fragmentation: Fragmentation occurs over time as applications start and stop. If your system memory has become fragmented, it's harder for FME to allocate contiguous memory. You can identify this if your job runs fine after a system restart, but later in the day starts reporting memory optimization issues. Recourse: restart your computer.
- Workspace Issues:
- Workspace Complexity: Multiple blocking transformers (Group By) can lead to excessive memory usage. If possible, you might need to increase your resources or redesign your workspace.
- Debugging Options: Turn off data caching (formerly known as feature caching) or other debugging tools, such as Inspector or Logger transformers.
Using the AttributeKeeper transformer to keep only attributes needed during the workflow or for the output drastically improves performance.
If you consistently see the 'Optimizing Memory Usage' message for the same FME workspace, please share the workspace and data with Safe Support so we can investigate the issue.
FME Flow Engine Parameters
The FME Process Monitor periodically restarts FME Flow Engines to control any growing memory concerns. Two parameters control the frequency of FME Flow Engine restarts to clear the memory they may build up:
- MAX_TRANSACTION_RESULT_SUCCESSES - maximum number of successful result transactions to accept from the service before shutting down or restarting the service.
- MAX_TRANSACTION_RESULT_FAILURES - maximum number of failed result transactions to accept from the service before shutting down or restarting the service.
For example:
MAX_TRANSACTION_RESULT_SUCCESSES=100 will reset Engines after 100 successful jobs.
MAX_TRANSACTION_RESULT_FAILURES=10 will reset Engines after 10 failed jobs.
These settings are found in the FMEFlow/Server/fmeFlowConfig.txt file. FME Flow must be restarted for any changes to take effect.
