ArcGIS Licensing Error: Unable to Perform Licensing Related Tasks
Liz Sanderson
Liz Sanderson
Considerations
When attempting to read or write an ArcGIS Geodatabase format in FME Form, you may encounter licensing-related errors such as:
Unable to perform any licensing related tasks. Please check your Esri ArcGIS Compatibility workspace parameter, found in Navigator -> Workspace Parameters -> Translation. This 64-bit version of FME requires ArcGIS Desktop along with 64-bit Background Geoprocessing; ArcGIS Pro; or ArcGIS Enterprise. Refer to this this article http://fme.ly/qua for more details
or
Unable to perform any licensing-related tasks. Please ensure that ArcGIS Desktop/Engine Runtime is correctly installed
or
INFORM|The Esri Product license used by this machine does not include licenses for the 'ArcInfo' licensing level
ERROR |Unable to perform licensing-related tasks. Please ensure that ArcGIS is correctly installed
or
The Product License has not been initialized.
These messages typically appear when adding a Geodatabase reader or writer, or when running a workspace that uses Esri-based formats.
Why This Happens
ArcGIS Geodatabase formats in FME rely on a properly installed and licensed Esri product. If licensing or installation requirements are not met, FME cannot access the required Esri libraries.
Common causes include:
  • The ArcGIS license has expired
  • The ArcGIS License Manager is unavailable
  • The Esri product license has not been initialized on the system
  • The installed license level is insufficient for the Geodatabase format being used
  • ArcGIS is installed, but not licensed correctly
  • ArcGIS and FME Form are installed on different machines
  • Environment variables are incorrectly set
  • Multiple Esri products are installed, and FME is referencing the wrong one
  • FME is detecting ArcGIS Background Geoprocessing (64-bit) instead of ArcGIS Pro
Because FME integrates directly with Esri software for certain Geodatabase formats, it must be able to locate and validate a supported ArcGIS installation at runtime.
How to Resolve It
Work through the following checks to confirm that ArcGIS is installed and licensed correctly.
1. Verify the ArcGIS License Is Active
Open the ArcGIS Administrator application. Confirm that the license is current and properly authorized. Ensure the correct license level is available for your workflow.
If you use a concurrent license, confirm that the ArcGIS License Manager is running. Ensure the machine can connect to the license server.
2. Confirm the Required License Level
Some Geodatabase formats require a specific ArcGIS license level. Verify that the system includes the required ArcGIS license type. If needed, configure the ESRI_SOFTWARE_CLASS environment variable to align the ArcGIS license level with FME Form.
If you see a message referencing the ArcInfo licensing level, confirm that your license includes that level.
3. Confirm ArcGIS Is Installed Correctly
Ensure ArcGIS is installed on the same machine as FME Form, and confirm the installation used the All Users option. Open ArcGIS Administrator and verify that the license has been initialized.
ArcGISPro Licensing
If the product license has not been initialized, complete the authorization process in ArcGIS Administrator.
4. Review Recent Software Changes
If the issue started after an upgrade, check whether ArcGIS or FME Form was recently updated.
Confirm compatibility between the installed ArcGIS version and FME Form. Review system environment variables for leftover values from previous installations, in particular, verify ESRI_SOFTWARE_CLASS.
If multiple Esri products are installed, confirm that FME Form is referencing the intended product. If using ArcGIS Background Geoprocessing (64-bit), ensure FME Form does not detect it as ArcGIS Pro.
5. Review the Esri ArcGIS Compatibility Workspace Parameter
In FME Workbench:
  • Open Navigator
  • Go to Workspace Parameters > Translation
  • Review the Esri ArcGIS Compatibility parameter
  • Ensure it matches the ArcGIS product you have installed
Esri is sunsetting ArcMap in March of 2026, and ArcMap will therefore no longer be supported by FME 2026.1. As such, the ArcGIS setting will be renamed in FME Form.
- 2025.2 and older: Esri ArcMap
- 2026.1 and newer: Esri ArcGIS Server Legacy (ArcMap Compatible)
Additional Notes
  • ArcGIS Geodatabase formats require a valid Esri installation; they do not function independently of ArcGIS
  • Changes to system passwords or licensing infrastructure may also affect license validation
  • Restarting the machine after licensing changes can help ensure all components refresh correctly
Additional Resources
If you continue to experience issues after completing the steps above, contact Support with your FME Form version, ArcGIS version, and the full error message from the Translation Log.
